I want to flash an image for Colibri IMX8DX 1GB WB (Aster Carrier board V1.1B) from USB Stick, but my USB is not detected by the console:
Colibri iMX8X # usb reset
resetting USB…
USB0: Port not available.
USB1: XHCI-imx8 init hccr 0x000000005b130000 and hcor 0x000000005b130080 hc_length 128
Register 2000820 NbrPorts 2
Starting the controller
USB XHCI 1.00
scanning bus 1 for devices… 1 USB Device(s) found
scanning usb for storage devices… 0 Storage Device(s) found
The u-boot version is:
U-Boot 2018.03-toradex_imx_v2018.03_4.14.98_2.3.0_bringup+g52f89f8382 (Apr 15 2021 - 16:08:15 +0000)
I already tried other usb stick, but I always get the same result.
Is there anything that I could do to enable it?
I already checked the Toradex Easy Installer, but I really want to flash my image from the bootloader. If I need to flash it multiple times I don’t think that the Toradex Easy Installer it’s going to be convenient.
We neither have nor support any other flashing method for Colibri iMX8X apart from the Toradex Easy Installer. I’m flashing a few images every day using the Toradex Easy Installer and find it quite convenient. You may try to implement flashing from the bootloader yourself. You can find its source code here.
