After a long debugging session with the AI, in which it determined that recovery mode does not work on my board, it recommended trying to boat tezi from a usb thumb drive. Following its instructions, I have attempted to do that many ways, all ending in failure. Could you let me know if
a) it is possible to boot tezi from a usb drive on my Dahlia imx8mp system?
b) If so, what would be the instructions for doing so?
Based on the available documentation, I can answer your questions about booting Toradex Easy Installer from USB on your Dahlia iMX8MP system:
a) Is it possible to boot TEZI from USB on Dahlia iMX8MP?
Yes, it is possible, but with important limitations. The sources indicate that this approach depends heavily on the compatibility between the U-Boot version running on your device and the Easy Installer image on the USB drive (1).
b) Instructions for booting TEZI from USB
Method 1: Manual U-Boot Configuration
The community documentation suggests this approach (1):
Prepare the USB drive:
Download the Toradex Easy Installer image
Extract the contents to the root directory of your USB drive (FAT32 format)
For booting into recovery mode, can you verify the cable you are using? Also can you let me know what steps you are taking, as well as any terminal outputs? Also are you on a windows computer or linux?
It’s fairly rare for a board not to go into recovery mode.
The cable is fine, I can see the expected output on the attached terminal during U-Boot and the Linux bootup. The recovery procedure used to work with this board. I’ve used it with the tezi installer to load Linux software before. I’ve gone through the recovery procedure many times: hold down the recovery button, push the power on button and release, waited a good ten seconds, release the recovery button, check for a new usb on my Linux workstation (which never appears), then tried running the tezi installer, and it just hangs waiting for the usb. I’ve tried unplugging everything but the usb cable from the Dahlia for this procedure, still doesn’t work.
Also, there is no terminal output after the “recovery” power-on and recovery button release in the terminal where I usually get the U-Boot and Linux boot messages.
Can you also confirm which usb-c port you are using? It should be the X3 - directly next to the standard USB ports.
Can you try once more, where you unplug all power sources (including usb and barrel). And Try and enter recovery mode, and see if the a new USB device shows up with lsusb command? (not running the recover-linux file).
Also can you tell me which Toradex Easy Installer version/build you are trying?
Followed your instructions, and in the process, noticed an apparmor error in the workstation logs. It looks like apparmor prevents the normal usb connection! It wasn’t a problem when I ran tezi before as I had disabled it in order to do a Yocto build, but I have rebooted since.
