I reproduced it today and the steps are as follows:
I extracted the contents of December’s torizon-core-docker-verdin-imx8mp-TEZI-6.1.0-[blahblahh]-build.4.tar to a USB drive and installed it via TEZI.
sshed in and deal with the mandatory password change
Created a tcbuild.yaml specifying the same .tar I extracted above, with the only customization(s) being the image name/description, and the following DTS overlays.
- device-trees/overlays/verdin-imx8mp_mezzanine-lvds-single-channel_overlay.dts
- device-trees/overlays/verdin-imx8mp_mezzanine-touch-atmel-mxt_overlay.dts
- my_dts/lvds-panel.dts
where my_dts/lvds-panel.dts is a carbon copy of the DTS for the toradex 10" display. (just copied in preparation for a different display. This DTS works just fine on the 5.6.x build)
Build image with torizoncore-builder build - success.
Unpack with images unpack output - success
deploy with deploy command to the just-flashed development board. (Completes successfully, reboots the device)
SoM reboots. Display never comes up, and SSH connection times out Device reboots three times and then rolls back the attempted update. The serial log from the console USB port looks like this - starting from the login prompt on the running 6.1.x delpoy.
verdin-imx8mp-07091509 login:
[ 41.925578] watchdog: watchdog0: watchdog did not stop!
[ 42.172245] imx2-wdt 30280000.watchdog: Device shutdown: Expect reboot!
[ 42.179469] reboot: Restarting system
U-Boot SPL 2022.04-6.1.0-devel+git.944a4ccb70e4 (Jan 01 1970 - 00:00:00 +0000)
DDRINFO: start DRAM init
DDRINFO: DRAM rate 4000MTS
Training FAILED
Quad die, dual rank failed, attempting dual die, single rank configuration.
DDRINFO:ddrphy calibration done
DDRINFO: ddrmix config done
SEC0: RNG instantiated
Normal Boot
WDT: Started watchdog@30280000 with servicing (60s timeout)
Trying to boot from BOOTROM
Boot Stage: Primary boot
Find img info 0x&4802d000, size 888
Download 916480, Total size 917264
NOTICE: BL31: v2.6(release):lf_v2.6-g9202efc9aa
NOTICE: BL31: Built : 00:00:00, Jan 1 1970
U-Boot 2022.04-6.1.0-devel+git.944a4ccb70e4 (Jan 01 1970 - 00:00:00 +0000)
CPU: i.MX8MP[8] rev1.1 1600 MHz (running at 1200 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 40C
Reset cause: POR
DRAM: 4 GiB
Core: 89 devices, 23 uclasses, devicetree: separate
MMC: FSL_SDHC: 1, FSL_SDHC: 2
In: serial@30880000
Out: serial@30880000
Err: serial@30880000
Model: Toradex 0058 Verdin iMX8M Plus Quad 4GB WB IT V1.0E
Serial#: 07091509
Carrier: Toradex Verdin Development Board V1.1C, Serial# 10952597
Net: eth1: ethernet@30be0000, eth0: ethernet@30bf0000 [PRIME]
Saving Environment to MMC... Writing to MMC(2)... OK
Normal Boot
switch to partitions #0, OK
mmc2(part 0) is current device
Scanning mmc 2:1...
Found U-Boot script /boot.scr
973 bytes read in 0 ms
## Executing script at 50280000
5413 bytes read in 2 ms (2.6 MiB/s)
88435 bytes read in 4 ms (21.1 MiB/s)
139 bytes read in 2 ms (67.4 KiB/s)
Applying Overlay: verdin-imx8mp_mezzanine-lvds-single-channel_overlay.dtbo
1424 bytes read in 3 ms (462.9 KiB/s)
Applying Overlay: verdin-imx8mp_mezzanine-touch-atmel-mxt_overlay.dtbo
288 bytes read in 2 ms (140.6 KiB/s)
Applying Overlay: lvds-panel.dtbo
666 bytes read in 2 ms (325.2 KiB/s)
13376273 bytes read in 42 ms (303.7 MiB/s)
10536287 bytes read in 34 ms (295.5 MiB/s)
Uncompressing Kernel Image
## Flattened Device Tree blob at 50200000
Booting using the fdt blob at 0x50200000
Loading Device Tree to 00000000ffac8000, end 00000000ffb00fff ... OK
Starting kernel ...
[ 0.925180] caam_jr 30901000.jr: failed to flush job ring 0
[ 1.008797] imx6q-pcie 33800000.pcie: Failed to get CLKREQ reset control
Starting version 250.5+
Training FAILED
Normal Boot
Reset cause: POR
DRAM: 4 GiB
In: serial@30880000
Serial#: 07091509
Normal Boot
Scanning mmc 2:1...
973 bytes read in 1 ms (950.2 KiB/s)
88435 bytes read in 3 ms (28.1 MiB/s)
1424 bytes read in 2 ms (695.3 KiB/s)
666 bytes read in 3 ms (216.8 KiB/s)
13376273 bytes read in 43 ms (296.7 MiB/s)
10536287 bytes read in 33 ms (304.5 MiB/s)
Starting kernel ...
[ 0.923127] caam_jr 30901000.jr: failed to flush job ring 0
[ 1.006276] imx6q-pcie 33800000.pcie: Failed to get CLKREQ reset control
Training FAILED
Normal Boot
Reset cause: POR
DRAM: 4 GiB
In: serial@30880000
Serial#: 07091509
Normal Boot
Scanning mmc 2:1...
Starting kernel ...
[ 0.924067] caam_jr 30901000.jr: failed to flush job ring 0
[ 1.010241] imx6q-pcie 33800000.pcie: Failed to get CLKREQ reset control
Training FAILED
Normal Boot
Reset cause: POR
DRAM: 4 GiB
In: serial@30880000
Serial#: 07091509
Normal Boot
Warning: Bootlimit (3) exceeded. Using altbootcmd.
Scanning mmc 2:1...
Rollback enabled. Booting previously deployed version.
90443 bytes read in 3 ms (28.8 MiB/s)
118 bytes read in 2 ms (57.6 KiB/s)
Applying Overlay: verdin-imx8mp_hdmi_overlay.dtbo
2219 bytes read in 2 ms (1.1 MiB/s)
Applying Overlay: verdin-imx8mp_dsi-to-hdmi_overlay.dtbo
3165 bytes read in 4 ms (772.5 KiB/s)
Applying Overlay: verdin-imx8mp_spidev_overlay.dtbo
561 bytes read in 3 ms (182.6 KiB/s)
13376273 bytes read in 44 ms (289.9 MiB/s)
10536287 bytes read in 37 ms (271.6 MiB/s)
Loading Device Tree to 00000000ffac7000, end 00000000ffb00fff ... OK
Starting kernel ...
[ 2.869855] systemd[1]: Current system time is further ahead 15y after build time, but cannot correct: Invalid argument
[ 5.306089] fsl-aud2htx 30cb0000.aud2htx: failed to pcm register
[ 17.037744] The last update failed and you are in a rollback state.
[ 17.044372] Unfortunately the logs are unavailable, probably because the update failed before starting userspace applications.
TorizonCore 6.1.0-devel-202212+build.4 verdin-imx8mp-07091509 ttymxc2
