I changed my ulimits for message queues by editing the ‘/etc/security/limits.conf’ to
* hard msgqueue unlimited
* soft msgqueue unlimited
When I login per COM port I get the expected output for ‘ulimit -q’ as ‘unlimited’ for root and for a normal user.
But when I connect per ssh, my settings of limits.conf aren’t recognized and I get ‘819200’ for ‘ulimit -q’ for root and user logins.
I checked ‘/etc/pam.d/su’ and ‘/etc/pam.d/login’ and in both files the entry
session required pam_limits.so
is present.
What did I miss? Do I have to modify ‘/etc/pam.d/dropbear’?
Markus
Hello @Mowlwurf ,
Could you try setting the UsePrivilegeSeparation no
in /etc/ssh/sshd_config
It could also be that upon login it was reset from etc/security/limits.d/90-nproc.conf for all non-root users. That also helps sometimes.
Hope one of the solutions works.
Janani
Hi Janani,
thanks for your response. Unfortunately none of your files mentioned are present on my system.
I used the tdx-reference-minimal-image recipe as the basis for my own image. Therefore dropbear is used as ssh server.
Hello @Mowlwurf ,
I don’t have much experience with Dropbear as a SSH server. I could ask my colleagues about this and meanwhile here is something I found:
https://serverfault.com/questions/569288/ulimit-n-not-changing-values-limits-conf-has-no-effect
Janani
