Ubuntu 18.10/glibc 2.28: Image build fails
I just set up a new virtual machine with Ubuntu 18.10, checked out the Linux 2.8b5 sources and tried to build it.
However I get the following error:
ERROR: m4-native-1.4.18-r0 do_compile: oe_runmake failed
ERROR: m4-native-1.4.18-r0 do_compile: Function failed: do_compile (log file is located at /home/christian/sources/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/temp/log.do_compile.4802)
ERROR: Logfile of failure stored in: /home/christian/sources/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/temp/log.do_compile.4802
Log data follows:
| DEBUG: Executing shell function do_compile
| NOTE: make -j 4 infodir=/home/christian/sources/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/recipe-sysroot-native/usr/share/info
| make  all-recursive
| make[1]: Entering directory '/home/christian/sources/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/build'
| Making all in .
| make[2]: Entering directory '/home/christian/sources/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/build'
| make[2]: Nothing to be done for 'all-am'.
| make[2]: Leaving directory '/home/christian/sources/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/build'
| Making all in examples
| make[2]: Entering directory '/home/christian/sources/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/build/examples'
| make[2]: Nothing to be done for 'all'.
| make[2]: Leaving directory '/home/christian/sources/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/build/examples'
| Making all in lib
| make[2]: Entering directory '/home/christian/sources/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/build/lib'
| make  all-am
| make[3]: Entering directory '/home/christian/sources/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/build/lib'
| gcc   -I. -I../../m4-1.4.18/lib   -isystem/home/christian/sources/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/recipe-sysroot-native/usr/include  -isystem/home/christian/sources/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/recipe-sysroot-native/usr/include -O2 -pipe -c -o freadahead.o ../../m4-1.4.18/lib/freadahead.c
| gcc   -I. -I../../m4-1.4.18/lib   -isystem/home/christian/sources/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/recipe-sysroot-native/usr/include  -isystem/home/christian/sources/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/recipe-sysroot-native/usr/include -O2 -pipe -c -o fseeko.o ../../m4-1.4.18/lib/fseeko.c
| gcc   -I. -I../../m4-1.4.18/lib   -isystem/home/christian/sources/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/recipe-sysroot-native/usr/include  -isystem/home/christian/sources/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/recipe-sysroot-native/usr/include -O2 -pipe -c -o vasprintf.o ../../m4-1.4.18/lib/vasprintf.c
| rm -f t-charset.alias charset.alias && \
| /bin/bash ../../m4-1.4.18/lib/config.charset 'x86_64-pc-linux-gnu' > t-charset.alias && \
| mv t-charset.alias charset.alias
| rm -f t-ref-add.sed ref-add.sed && \
| sed -e '/^#/d' -e 's/@''PACKAGE''@/m4/g' ../../m4-1.4.18/lib/ref-add.sin > t-ref-add.sed && \
| mv t-ref-add.sed ref-add.sed
| rm -f t-ref-del.sed ref-del.sed && \
| sed -e '/^#/d' -e 's/@''PACKAGE''@/m4/g' ../../m4-1.4.18/lib/ref-del.sin > t-ref-del.sed && \
| mv t-ref-del.sed ref-del.sed
| ../../m4-1.4.18/lib/freadahead.c: In function ‘freadahead’:
| ../../m4-1.4.18/lib/freadahead.c:92:3: error: #error "Please port gnulib freadahead.c to your platform! Look at the definition of fflush, fread, ungetc on your system, then report this to bug-gnulib."
| ../../m4-1.4.18/lib/fseeko.c: In function ‘rpl_fseeko’:
| ../../m4-1.4.18/lib/fseeko.c:110:4: error: #error "Please port gnulib fseeko.c to your platform! Look at the code in fseeko.c, then report this to bug-gnulib."
| make[3]: *** [Makefile:1915: freadahead.o] Error 1
| make[3]: *** Waiting for unfinished jobs....
| make[3]: *** [Makefile:1915: fseeko.o] Error 1
| make[3]: Leaving directory '/home/christian/sources/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/build/lib'
| make[2]: *** [Makefile:1674: all] Error 2
| make[2]: Leaving directory '/home/christian/sources/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/build/lib'
| make[1]: *** [Makefile:1572: all-recursive] Error 1
| make[1]: Leaving directory '/home/christian/sources/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/build'
| make: *** [Makefile:1528: all] Error 2
| ERROR: oe_runmake failed
| ERROR: Function failed: do_compile (log file is located at /home/christian/sources/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/temp/log.do_compile.4802)
ERROR: Task (/home/christian/sources/oe-core/build/../layers/openembedded-core/meta/recipes-devtools/m4/m4-native_1.4.18.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 139 tasks of which 131 didn't need to be rerun and 1 failed.
NOTE: Writing buildhistory
According to a little google research, this problem is related to the new glibc 2.28 included in Ubuntu 18.10. I also tried it on a Ubuntu 18.04, where it works as expected.
The Toradex BSP 2.8b4 didn’t seem to have a problem with glibc 2.28 (but, as far as I remember, the first versions of BSP 2.8 had also problems)
Is there any way to fix this issue? (Preferably by Toradex with a new BSP release :D)
BR Christian
hi @cheesi
Ubuntu 18.10 is not supported by Yocto, so please use any supported version
Yeah, sure. Use one of supported distributions which are listed here.
Best regards, Jaski
Hi
While Jaski’s advise to use a supported distribution is sound, you might try building with uninative. If it really helps I do not know.
e.g. add the following to local.conf:
require conf/distro/include/yocto-uninative.inc
Note that this will likely rebuild everything.
Max
Thanks! Didn’t know about that.
This answer not solves the problem
Try to use the following patch as a workaround:
https://git.yoctoproject.org/cgit.cgi/poky/plain/meta/recipes-devtools/m4/m4/m4-1.4.18-glibc-change-work-around.patch
The patch works for me.
Also, you can look at this issue: buildroot compilation fails with glibc-2.28 · Issue #74 · sifive/freedom-u-sdk · GitHub
Thanks for letting us know. However, as @jaski.tx pointed out building any Yocto Project version with a non approved distro is not adviced. BSP 3.0 will be based on Thud which of course will have all such fixes and lists such distro as approved.
I have an interesting case here where the same error occurs when building BSP 2.8 using crops/poky:ubuntu-16.04 container. Running ldd --version shows ldd (Ubuntu GLIBC 2.23-0ubuntu11.3) 2.23 so host requirements should be fine.
console-latest.log (55.6 KB)
log.do_compile.28695 (78.1 KB)
Hi @dremsol
This thread is from more than 6 years ago, it’s not active.
Anyway, the BSP 2.8 EOL was in 2021. We are not supporting it anymore, you should install a more up-to-date version.
