Hi all!
I’m trying to make a uboot stand alone application following manual items (5.12.1 e 5.12.3) without success.
http://www.denx.de/wiki/view/DULG/UBootStandalone
I’m using yocto:
bitbake u-boot-toradex
Generating hello_world , hello_world.bin , hello_world.srec files automatically in u-boot/apalis_imx6_it_defconfig/examples/standalone folder.
I’ve used lots of configs combination because I don’t know correct memory entry point and load address.
The files are saved in pendrive and I’m using the following commands :
usb start fatload usb 0:0 0x12000000 hello_world.bin go 0x12000000
## Starting application at 0x12000000 ... undefined instruction pc : [<8df58bc4>] lr : [<8ff5f29b>] ..........
Following manual item 5.12.3 , I’ve also created an image file from executable ELF hello_world:
../../tools/mkimage -A arm -T standalone -C none -a 0x0c100000 -e 0x0c100000 -n hello_world -d hello_world hello_world.img
Resulting in:
Image Name: hello_world Created: Tue Jun 13 18:30:14 2017 Image Type: ARM Linux Standalone Program (uncompressed) Data Size: 546 Bytes
= 0.53 kB = 0.00 MB Load Address: 0c100000 Entry Point: 0c100000
fatload usb 0:0 0x12000000 hello_world.img reading hello_world.img 73232 bytes read in 32 ms (2.2 MiB/s) ART HMI # bootm 12000000
## Booting kernel from Legacy Image at 12000000 ... Image Name: hello_world Image Type: ARM Linux Standalone Program (uncompressed) Data Size: 73168 Bytes = 71.5 KiB Load Address: 0c100000 Entry Point: 0c100000 Verifying Checksum ... OK Loading Standalone Program ...
After that it returns to u-boot without executing the program.
How can I proceed?
Which are the correct addresses to use for load and execution entry point ?
Appreciate any tips!
Fabiano
