this is the script used to by u-boot in my image using the toradex bsp 6.7 on apalis imx8qm:
51+1 records in
51+1 records out
3285 bytes (3.3 kB, 3.2 KiB) copied, 0.000143364 s, 22.9 MB/s
SPDX-License-Identifier: GPL-2.0+ OR MIT
Copyright 2020 Toradex
Toradex boot script.
With Mender integration.
Only supports booting from mmc
if test ${devtype} = “ubi”; then
echo “This script is not meant to distro boot from raw NAND flash.”
exit
test -n ${m4boot} || env set m4boot ‘;’
test -n ${fdtfile} || env set fdtfile ${fdt_file}
test -n ${kernel_image} || env set kernel_image fitImage
test -n ${overlays_file} || env set overlays_file “overlays.txt”
test -n ${overlays_prefix} || env set overlays_prefix “overlays/”
Set dynamic commands
env set load_prefix ‘boot/’
env set load_cmd ‘load ${mender_uboot_root}’
env set load_cmd_boot ‘load ${mender_uboot_root}’
env set set_bootcmd_kernel ‘env set bootcmd_kernel “${load_cmd} \${kernel_addr_load} \${load_prefix}\${kernel_image}”’
env set set_load_overlays_file ‘env set load_overlays_file “${load_cmd_boot} \${loadaddr} \${overlays_file}; env import -t \${loadaddr} \${filesize}”’
env set fdt_resize ‘fdt addr ${fdt_addr_r} && fdt resize 0x20000’
env set set_bootcmd_dtb ‘env set bootcmd_dtb “echo Loading DeviceTree: \${fdtfile}; ${load_cmd} \${fdt_addr_r} \${load_prefix}\${fdtfile}”’
env set set_apply_overlays ‘env set apply_overlays “for overlay_file in \${fdt_overlays}; do echo Applying Overlay: \${overlay_file} && ${load_cmd_boot} \${loadaddr} \${overlays_prefix}\${overlay_file} && fdt apply \${loadaddr}; env set overlay_file; done; true”’
env set bootcmd_boot ‘echo “Bootargs: ${bootargs}” && booti ${kernel_addr_r} - ${fdt_addr_r}’
if test -n ${setup}; then
run setup
else
env set setupargs console=tty1 console=${console},${baudrate} consoleblank=0
if test ${kernel_image} = “fitImage”; then
env set kernel_addr_load ${ramdisk_addr_r}
env set bootcmd_unzip ‘;’
else
if test -n ${kernel_comp_addr_r}; then
use booti automatic decompression
env set kernel_addr_load ${loadaddr}
else
if test ${kernel_image} = “Image.gz”; then
env set bootcmd_unzip ‘unzip ${kernel_addr_load} ${kernel_addr_r}’
else
env set kernel_addr_load ${kernel_addr_r}
fi
fi
env set rootfsargs_set ‘env set rootfsargs root=${mender_kernel_root} ro rootwait’
env set bootcmd_args ‘run rootfsargs_set && env set bootargs ${defargs} ${rootfsargs} ${setupargs} ${vidargs} ${tdxargs}’
if test ${skip_fdt_overlays} != 1; then
env set bootcmd_overlays ‘run load_overlays_file && run fdt_resize && run apply_overlays’
else
env set bootcmd_overlays true
env set bootcmd_prepare ‘run set_bootcmd_kernel; run set_bootcmd_dtb; run set_load_overlays_file; run set_apply_overlays’
env set bootcmd_run ‘run m4boot; run bootcmd_dtb && run bootcmd_overlays && run bootcmd_args && run bootcmd_kernel && run bootcmd_unzip && run bootcmd_boot; echo “Booting from ${devtype} failed!” && false’
env set bootcmd_run ‘run m4boot; run bootcmd_dtb && run bootcmd_overlays && run bootcmd_args && run bootcmd_kernel && run bootcmd_unzip && run bootcmd_boot; echo “Booting from ${devtype} failed!”’
run bootcmd_prepare
run mender_setup
run bootcmd_run
the script is from u-boot distro boot influenced by mender,so i want to know if this script can load a fit image, because the bootcmd_boot command is hardcoded to booti even if its a fitimage only the load adress changes
