I put the module in recovery mode by shorting 2 pads on the module. I was able to load the uboot to the module and run it by executing “sudo ./update.sh -d” command on host. At uboot prompt, I entered “run setupdate;run update” with Toradex Linux Image V2.6. and everything seemed working fine with an output message:
“successfully updated U-Boot, power-cycle and enter “run setupdate; run migrate” to complete update”.
Then I put the module back to normal mode and powered the module up.but it failed to boot. There is a very similar issue posted in the forum: Can't flash uboot Colibri iMX6 in recovery mode - Technical Support - Toradex Community . I have double checked that my SD card was not damaged.
Then I put the module in recovery mode and loaded & ran uboot again. The uboot was able to start kernel.
Here is an output of boot_info
root@colibri-imx6:~# cat /sys/devices/soc0/soc.0/2100000.aips-bus/2198000.usdhc/mmc_host/mmc0/mmc0\:0001/boot_info
[ 47.417629] mmc0: BKOPS_EN bit is not set
boot_info:0x07;
ALT_BOOT_MODE:1 - Supports alternate boot method
DDR_BOOT_MODE:1 - Supports alternate dual data rate during boot
HS_BOOTMODE:1 - Supports high speed timing during boot
boot_size:2048KB
boot_partition:0x48;
BOOT_ACK:1 - Boot acknowledge sent during boot operation
BOOT_PARTITION-ENABLE: 1 - Boot partition 1 enabled
boot_bus:0x16
BOOT_MODE:2 - Use dual data rate in boot operation
RESET_BOOT_BUS_WIDTH:1 - Retain boot bus width and boot mode after boot operation
BOOT_BUS_WIDTH:2 - x8 (sdr/ddr) bus width in boot operation mode
The I tried to copy uboot and enable boot partition:
root@colibri-imx6:~# dd if=u-boot.imx of=/dev/mmcblk0boot0 bs=512 seek=2
598+0 records in
598+0 records out
root@colibri-imx6:~# echo 1 > /sys/block/mmcblk0boot0/force_ro
root@colibri-imx6:~# echo 10 > /sys/devices/soc0/soc.0/2100000.aips-bus/2198000.usdhc/mmc_host/mmc0/mmc0\:0001/boot_bus_config
root@colibri-imx6:~# echo 8 > /sys/devices/soc0/soc.0/2100000.aips-bus/2198000.usdhc/mmc_host/mmc0/mmc0\:0001/boot_config
It seems my boot partition got corrupted:
[ 688.964287] Unable to handle kernel paging request at virtual address 92c89f0c
[ 688.971526] pgd = 8e74c000
[ 688.974237] [92c89f0c] *pgd=00000000
[ 688.977833] Internal error: Oops: 805 [#2] SMP ARM
[ 688.982626] Modules linked in:
[ 688.985703] CPU: 0 PID: 815 Comm: cat Tainted: G D 3.14.52-00011-g9f2723e #2
[ 688.993625] task: 8e15b600 ti: 8f332000 task.ti: 8f332000
[ 688.999036] PC is at mmc_read_ext_csd+0x358/0x7dc
[ 689.003744] LR is at 0x8e1c7800
[ 689.006891] pc : [<80454c40>] lr : [<8e1c7800>] psr: 600f0113
[ 689.006891] sp : 8f3339e8 ip : 92c89c00 fp : 8f333a14
[ 689.018372] r10: 00000000 r9 : 8f333a6c r8 : 8e489c00
[ 689.023600] r7 : 00000001 r6 : 00000001 r5 : 8e8c7600 r4 : 8e489c00
[ 689.030130] r3 : 00200000 r2 : 00000000 r1 : 807bad80 r0 : 04800000
[ 689.036662] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
[ 689.043974] Control: 10c5387d Table: 1e74c059 DAC: 00000015
[ 689.049723] Process cat (pid: 815, stack limit = 0x8f332238)
[ 689.055384] Stack: (0x8f3339e8 to 0x8f334000)
[ 689.059749] 39e0: 000055b0 8e489c08 0000b288 8f333a70 8067ffec 8e489c00
[ 689.067933] 3a00: 8f333a6c 00000000 8f333adc 8f333a18 80455d18 804548f4 00000001 00000000
[ 689.704765] Code: e2827001 e30a1d80 e084c000 e348107b (e58c330c)
[ 689.710864] ---[ end trace fa92dd4f8b345141 ]---
Segmentation fault
I am now stuck at this fault and don’t know how I should proceed. What am I doing wrong? Any help would be appreciated.
William
