I am trying to bring up our new carrier board which contains two RS485 interfaces.
The first interface is connected to UARTC and the second to UARTD.
RS485 #1
DE/nRE = SODIMM 30
RX = SODIMM 19
TX = SODIMM 21
RS485 #2
DE/nRE = SODIMM 94
RX = SODIMM 29
TX = SODIMM 37
I have modified the device to use the DE/nRE pins as GPIOs within the driver and set the corresponding rts-gpios property:
//RS485 #1
&uart3 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_uart3>;
rts-gpios = <&gpio1 10 GPIO_ACTIVE_HIGH>;
/delete-property/uart-has-rtscts;
linux,rs485-enabled-at-boot-time;
//RS485 #2
&uart4 {
pinctrl-0 = <&pinctrl_uart4>;
assigned-clocks = <&clks IMX7D_UART4_ROOT_SRC>;
assigned-clock-parents = <&clks IMX7D_OSC_24M_CLK>;
fsl,dte-mode;
rts-gpios = <&gpio4 13 GPIO_ACTIVE_HIGH>;
The first RS485 work as expected and I am able to communicate but the kernel shows an error during the initialisation of UART4. It points out that it cannot get GPIO1_10, although it is not present in the UART4 pin configuration.
[ 0.106154] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 47, base_baud = 1500000) is a IMX
[ 0.827399] console [ttymxc0] enabled
[ 0.831719] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 48, base_baud = 1500000) is a IMX
[ 0.841123] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 49, base_baud = 1500000) is a IMX
[ 0.850287] imx7d-pinctrl 30330000.iomuxc: pin MX7D_PAD_GPIO1_IO10 already requested by 30330000.iomuxc; cannot claim for 30a60000.serial
[ 0.862691] imx7d-pinctrl 30330000.iomuxc: pin-7 (30a60000.serial) status -22
[ 0.869861] imx7d-pinctrl 30330000.iomuxc: could not request pin 7 (MX7D_PAD_GPIO1_IO10) from group uart4-grp on device 30330000.iomuxc
[ 0.882155] imx-uart 30a60000.serial: Error applying setting, reverse things back
[ 0.889682] imx-uart: probe of 30a60000.serial failed with error -22
[ 0.903316] loop: module loaded
[ 0.921824] libphy: Fixed MDIO Bus: probed
[ 0.929056] pps pps0: new PPS source ptp0
Am I missing something?
Thx M
