We are using the Apalis iMX6 Quad 1GB on a custom carrier board.
I’ve been porting our firmware from BSP 2.8 to BSP 5.5 and ran into the following problem when testing our UART2 (/dev/ttymxc1) port. Writing to the port works without issue (verified with a logic analyzer), however, reading from the port gives wrong/random data. The response data that is sent from the remote device shows up properly on the logic analyzer though.
What is especially strange is when I cat from /dev/ttymxc1 I get the following output (I am expecting 6 bytes from the remote device):
cat /dev/ttymxc1
@è!�b���������X!�b����������� et�����������nding 6
nr_mlock 0
nr_page_table_pages 126
nr_kernel_stack 904
nr_bounce 0
nr_free_cma 48883
nr_inactive_anon 1173
nr_active_anon 2008
nr_inactive_file 10284
nr_active_file 5521
nr_unevictable 0
nr_slab_reclaimable 1762
nr_slab_unreclaimable 3023
nr_isolated_anon 0
nr_isolated_file 0
workingset_nodes 0
workingset_refault 0
workingset_activate 0
workingset_restore 0
workingset_nodereclaim 0
nr_anon_pages 1951
nr_mapped 3572
nr_file_pages 17045
nr_dirty 6
nr_writeback 0
nr_writeback_temp 0
nr_shmem 1242
nr_shmem_hugepages 0
nr_shmem_pmdmapped 0
nr_file_hugepages 0
nr_file_pmdmapped 0
nr_anon_transparent_hugepages 0
nr_unstable 0
nr_vmscan_write 0
nr_vmscan_immediate_reclaim 0
nr_dirtied 129
nr_written 121
nr_kernel_misc_reclaimable 0
nr_dirty_threshold 41883
nr_dirty_background_threshold 20916
pgpgin 68820
pgpgout 42840
pswpin 0
pswpout 0
pgalloc_normal 118433
pgalloc_high 0
pgalloc_movable 0
allocstall_normal 0
allocstall_high 0
allocstall_movable 0
pgskip_normal 0
pgskip_high 0
pgskip_movable 0
pgfree 363201
pgactivate 4510
pgdeactivate 0
pglazyfree 0
pgfault 133192
pgmajfault 537
pglazyfreed 0
pgrefill 0
pgsteal_kswapd 0
pgsteal_direct 0
pgscan_kswapd 0
pgscan_direct 0
pgscan_direct_throttle 0
pginodesteal 0
slabs_scanned 0
kswapd_inodesteal 0
kswapd_low_wmark_hit_quickly 0
kswapd_high_wmark_hit_quickly 0
pageoutrun 0
pgrotated 0
drop_pagecache 0
drop_slab 0
oom_kill 0
pgmigrate_success 0
pgmigrate_fail 0
compact_migrate_scanned 0
compact_free_scanned 0
compact_isolated 49171
compact_stall 0
compact_fail 0
compact_success 0
compact_daemon_wake 0
compact_daemon_migrate_scanned 0
compact_daemon_free_scanned 0
unevictable_pgs_culled 0
unevictable_pgs_scanned 0
unevictable_pgs_rescued 0
unevictable_pgs_mlocked 0
unevictable_pgs_munlocked 0
unevictable_pgs_cleared 0
unevictable_pgs_stranded 0
swap_ra 0
swap_ra_hit 0
0 0 0 0 0 16 0 0 0 0 0 22 0 0 0 0 0 0 0 0 0 0 2 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 0 0 0 20 34 0 0 0 0 0 0 0 0 0 0 0 0 0 0 35 0 0 0 0 0 0
IpExt: InNoRoutes InTruncatedPkts InMcastPkts OutMcastPkts InBcastPkts OutBcastPkts InOctets OutOctets InMcastOctets OutMcastOctets InBcastOctets OutBcastOctets InCsumErrors InNoECTPkts InECT1Pkts InECT0Pkts InCEPkts ReasmOverlaps
IpExt: 0 0 229 25 27 0 167686 19251 145389 3336 5164 0 0 418 0 0 0 0
0 0 0 0 GPC 113 Level mmdc_1
75: 0 0 0 0 GPC 114 Level mmdc_1
76: 1 0 0 0 GPC 9 Level galcore:0
77: 1 0 0 0 GPC 10 Level galcore:2d
78: 1 0 0 0 GPC 11 Level galcore:vg
79: 0 0 0 0 GPC 8 Level 2800000.ipu
80: 0 0 0 0 GPC 7 Level 2800000.ipu
85: 0 0 0 0 gpio-mxc 4 Edge Wake-Up
111: 1 0 0 0 gpio-mxc 30 Level 2188000.ethernet-1:07
209: 0 0 0 0 gpio-mxc 0 Edge edt-ft5306
305: 22 0 0 0 GPC 105 Level 2101000.jr0
306: 0 0 0 0 GPC 106 Level 2102000.jr1
IPI0: 0 0 0 0 CPU wakeup interrupts
IPI1: 102 100 113 62 Timer broadcast interrupts
IPI2: 1280 3628 1138 970 Rescheduling interrupts
IPI3: 293 780 740 795 Function call interrupts
IPI4: 0 0 I5: 2237 1658 331 824 IRQ work interrupts
IPI6: 0 0 0 0 completion interrupts
Err: 0
etries: 4
Tick Device: mode: 1
Per CPU device: 3
Here are the relevant parts of our device tree
pinctrl_custom_uart2: custom_uart2 {
fsl,pins = <
MX6QDL_PAD_SD4_DAT4__UART2_TX_DATA 0x1b0b1
MX6QDL_PAD_SD4_DAT7__UART2_RX_DATA 0x1b0b1
&uart2 {
pinctrl-0 = <&pinctrl_custom_uart2>;
/delete-property/uart-has-rtscts;
/delete-property/fsl,uart-has-rtscts;
# dmesg | grep ttymxc1
[ 1.318103] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 69, base_baud = 5000000) is a IMX
# fw_printenv | grep tty
console=ttymxc0
Any idea what I am missing here? Is this some kind of dma issue?
