UART -> Ixora -> IMX8QM -> LinuxMultimediaReferenceImage
I’m trying to acess the UART from the userspace using the following:
Pin 27 UART3_RXD
Pin 28 UART3_TXD
Using the following flow of thought:
root@apalis-imx8-14903975:~# ls -l /dev/apalis-uart*
lrwxrwxrwx 1 root root 6 Jan 26 15:22 /dev/apalis-uart1 -> ttyLP1
lrwxrwxrwx 1 root root 6 Jan 26 15:22 /dev/apalis-uart2 -> ttyLP3
lrwxrwxrwx 1 root root 6 Jan 26 15:22 /dev/apalis-uart3 -> ttyLP0
lrwxrwxrwx 1 root root 6 Jan 26 15:22 /dev/apalis-uart4 -> ttyLP2
root@apalis-imx8-14903975:~# stty -F  /dev/ttyLP0 115200
root@apalis-imx8-14903975:~# cat  /dev/ttyLP0
However I cannot get any messages from my Teensy 4.0 board 3.3v logic.
Is access to the UART ports available through this method in this reference image?
Thank you,
William
Non issue, this works @9600, my error
My forum eagerness should be dismissed, although I guess I’m adding quick info
