I’m getting a strange behavior on my Hello World C program that writes and read from /dev/ttyLP1 serial port.
I could open and write to the serial, but I get “resource temporarily unavailable” on reading.
I’ve already tested (echo) the device with the command “microcom -X /dev/ttyLP1 -s 9600” and works fine with a short circuit on the TX and RX pins.
My code:
#include <iostream>
#include <fcntl.h> /* File Control Definitions */
#include <termios.h> /* POSIX Terminal Control Definitions */
#include <unistd.h> /* UNIX Standard Definitions */
#include <errno.h> /* ERROR Number Definitions */
#include <string.h>
int main(int argc, char** argv)
int fd;
char data,buf[100];
/*------------------------------- Opening the Serial Port -------------------------------*/
fd = open("/dev/ttyLP1",O_RDWR | O_NOCTTY | O_NDELAY); /* ttyUSB0 is the FT232 based USB2SERIAL Converter */
/* O_RDWR Read/Write access to serial port */
/* O_NOCTTY - No terminal will control the process */
/* O_NDELAY -Non Blocking Mode,Does not care about- */
/* -the status of DCD line,Open() returns immediatly */
if(fd == -1){
printf("\n Error! in Opening ttyUSB0 ");
return -1;
/*---------- Setting the Attributes of the serial port using termios structure --------- */
struct termios SerialPortSettings; /* Create the structure */
tcgetattr(fd, &SerialPortSettings); /* Get the current attributes of the Serial port */
cfsetispeed(&SerialPortSettings,B9600); /* Set Read Speed as 9600 */
cfsetospeed(&SerialPortSettings,B9600); /* Set Write Speed as 9600 */
SerialPortSettings.c_cflag &= ~PARENB; /* Disables the Parity Enable bit(PARENB),So No Parity */
SerialPortSettings.c_cflag &= ~CSTOPB; /* CSTOPB = 2 Stop bits,here it is cleared so 1 Stop bit */
SerialPortSettings.c_cflag &= ~CSIZE; /* Clears the mask for setting the data size */
SerialPortSettings.c_cflag |= CS8; /* Set the data bits = 8 */
SerialPortSettings.c_cflag &= ~CRTSCTS; /* No Hardware flow Control */
SerialPortSettings.c_cflag |= CREAD | CLOCAL; /* Enable receiver,Ignore Modem Control lines */
SerialPortSettings.c_iflag &= ~(IXON | IXOFF | IXANY); /* Disable XON/XOFF flow control both i/p and o/p */
SerialPortSettings.c_iflag &= ~(ICANON | ECHO | ECHOE | ISIG); /* Non Cannonical mode */
SerialPortSettings.c_oflag &= ~OPOST; /*No Output Processing*/
if((tcsetattr(fd,TCSANOW,&SerialPortSettings)) != 0){ /* Set the attributes to the termios structure*/
printf("\n ERROR ! in Setting attributes");
return -1;
}else{
printf("\n BaudRate = 9600 \n StopBits = 1 \n Parity = none\n");
tcflush(fd, TCIFLUSH); /* Discards old data in the rx buffer */
// Write buf example
buf[0] = 0xAA;
buf[1] = 0xBB;
// Write only 2 bytes
int ret = write(fd,(char *)buf,2);
if(ret == -1){
printf("errno: %s\n",strerror(errno));
return -1;
}else{
printf("wrote %d bytes\n",ret);
memset((void *)buf,'0',sizeof(buf));
sleep(1);
if (read(fd,buf,sizeof(buf)) == -1){
return -1;
for(int i=0;i<2;i++)
printf("0x%X ",buf[i]);
return 0;
The output:
BaudRate = 9600
StopBits = 1
Parity = none
wrote 2 bytes
errno: Resource temporarily unavailable
Am I missing any configuration? I have already looked at
