I have successfully updated the U-Boot splash screen and disabled all the output on console, but the U-Boot version is still printed (it’s printed before the U-Boot output).
U-Boot 2016.11-2.7.2+g60021a4 (Aug 14 2017 - 10:13:21 +0200)
CPU: Freescale i.MX6DL rev1.3 at 792 MHz
Reset cause: POR
I2C: ready
DRAM: 512 MiB
PMIC: device id: 0x10, revision id: 0x21, programmed
MMC: FSL_SDHC: 0, FSL_SDHC: 1
auto-detected panel vga-rgb
Display: vga-rgb (640x480)
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX6 DualLite 512MB V1.0A, Serial# 05061678
Net: using PHY at 0
FEC [PRIME]
Hit any key to stop autoboot: 0 0
I’m not sure what exactly you mean by “printed” resp. where that is. Are you talking about the serial debug console or any graphical display and if so what kind?
By “printed” I mean text output on the serial console.
I have disabled the console on my lcd display (console is tty1 I believe), but it still shows the “U-Boot 2016.11-2.7.2+g60021a4 (Aug 14 2017 - 10:13:21 +0200)” output.
