U-boot transfer speed from eMMC on Colibri T30
Hi.
I came across something rather strange. We have a custom update method where we can load a u-boot image from eMMC to RAM in u-boot and update the module. But we noticed very slow speeds in certain cases on the Colibri T30 module.
Example:
The first 1-128Mb takes 6.7seconds to read.
The 129th MB takes 3 seconds to read.
The 130th MB takes 3 seconds to read.
etc...
MX-4 T30 # load mmc 0:4 0x80408000 /boot/10M
10485760 bytes read in 617 ms (16.2 MiB/s)
MX-4 T30 # load mmc 0:4 0x80408000 /boot/50M
52428800 bytes read in 2685 ms (18.6 MiB/s)
MX-4 T30 # load mmc 0:4 0x80408000 /boot/100M
104857600 bytes read in 5294 ms (18.9 MiB/s)
104857600 bytes read in 5293 ms (18.9 MiB/s)
MX-4 T30 # load mmc 0:4 0x80408000 /boot/120M
125829120 bytes read in 6317 ms (19 MiB/s)
MX-4 T30 # load mmc 0:4 0x80408000 /boot/125M
131072000 bytes read in 6638 ms (18.8 MiB/s)
MX-4 T30 # load mmc 0:4 0x80408000 /boot/127M
133169152 bytes read in 6704 ms (18.9 MiB/s)
MX-4 T30 # load mmc 0:4 0x80408000 /boot/128M
134217728 bytes read in 6748 ms (19 MiB/s)
MX-4 T30 # load mmc 0:4 0x80408000 /boot/129M
135266304 bytes read in 9178 ms (14.1 MiB/s)
MX-4 T30 # load mmc 0:4 0x80408000 /boot/130M
136314880 bytes read in 12502 ms (10.4 MiB/s)
MX-4 T30 # load mmc 0:4 0x80408000 /boot/140M
146800640 bytes read in 45437 ms (3.1 MiB/s)
MX-4 T30 # load mmc 0:4 0x80408000 /boot/150M
157286400 bytes read in 78252 ms (1.9 MiB/s)
If the file is larger then 128 MB it starts to slow down, 128 MB does feel very aligned and that we are crossing some boundary in RAM or somewhere else.
I also know that you split up the rootfs image in your update.sh to 64MB chunks but I could not find an explanation why this is done, and is probably related to my issue.
Any thoughts?
Hi Mirza
I can see the same effect. My speed is a bit slower likely because I used an older module with a slower eMMC.
Colibri T30 # load mmc 0:2 $loadaddr /home/root/256M 6400000
104857600 bytes read in 9459 ms (10.6 MiB/s)
Colibri T30 # load mmc 0:2 $loadaddr /home/root/256M 8000000
134217728 bytes read in 11332 ms (11.3 MiB/s)
Colibri T30 # load mmc 0:2 $loadaddr /home/root/256M 8100000
135266304 bytes read in 13969 ms (9.2 MiB/s)
Colibri T30 # load mmc 0:2 $loadaddr /home/root/256M 8c00000
146800640 bytes read in 53206 ms (2.6 MiB/s)
When I do the same from a FAT formatted SD card:
Colibri T30 # load mmc 1:1 $loadaddr 256M 6400000
reading 256M
104857600 bytes read in 6664 ms (15 MiB/s)
Colibri T30 # load mmc 1:1 $loadaddr 256M 8000000
reading 256M
134217728 bytes read in 8525 ms (15 MiB/s)
Colibri T30 # load mmc 1:1 $loadaddr 256M 8100000
reading 256M
135266304 bytes read in 8591 ms (15 MiB/s)
Colibri T30 # load mmc 1:1 $loadaddr 256M 8c00000
reading 256M
146800640 bytes read in 9341 ms (15 MiB/s)
When I do the same from a ext3 formatted SD card:
Colibri T30 # load mmc 1:3 $loadaddr 256M a00000
10485760 bytes read in 660 ms (15.2 MiB/s)
Colibri T30 # load mmc 1:3 $loadaddr 256M 6400000
104857600 bytes read in 6145 ms (16.3 MiB/s)
Colibri T30 # load mmc 1:3 $loadaddr 256M 8000000
134217728 bytes read in 7848 ms (16.3 MiB/s)
Colibri T30 # load mmc 1:3 $loadaddr 256M 8100000
135266304 bytes read in 10404 ms (12.4 MiB/s)
Colibri T30 # load mmc 1:3 $loadaddr 256M 8c00000
146800640 bytes read in 48279 ms (2.9 MiB/s)
Both ext3 partitions on the eMMC and the SD card are formatted with a block size of 1024 bytes.
So my conclusion is that the U-Boot extfs drivers performs slower when a certain limit is reached.
We update the rootfs in junks of 64MB because the rootfs might get bigger than the available RAM. 64MB is small enough for all our modules.
Max
I made some more tests on the platform Mirza talked about above.
I tested an external SD-card and USB-stick, and ext4 with different block-sizes clearly have problem at some point.
4Gb SD-card with ext4, (mkfs.ext4 -b 1024) (decrease performance when reading file >16M !)
MX-4 T30 # load mmc 1:1 0x80408000 10M
10485760 bytes read in 529 ms (18.9 MiB/s)
MX-4 T30 # load mmc 1:1 0x80408000 12M
12582912 bytes read in 651 ms (18.4 MiB/s)
MX-4 T30 # load mmc 1:1 0x80408000 14M
14680064 bytes read in 757 ms (18.5 MiB/s)
MX-4 T30 # load mmc 1:1 0x80408000 16M
16777216 bytes read in 863 ms (18.5 MiB/s)
MX-4 T30 # load mmc 1:1 0x80408000 18M
18874368 bytes read in 62864 ms (293 KiB/s)
MX-4 T30 # load mmc 1:1 0x80408000 20M
20971520 bytes read in 70528 ms (290 KiB/s)
4Gb SD-card with ext4, (mkfs.ext4 -b 4096) (decrease performance when reading file >512M !)
MX-4 T30 # load mmc 1:1 0x80408000 128M
134217728 bytes read in 6300 ms (20.3 MiB/s)
MX-4 T30 # load mmc 1:1 0x80408000 129M
135266304 bytes read in 6311 ms (20.4 MiB/s)
MX-4 T30 # load mmc 1:1 0x80408000 150M
157286400 bytes read in 7286 ms (20.6 MiB/s)
MX-4 T30 # load mmc 1:1 0x80408000 200M
209715200 bytes read in 9678 ms (20.7 MiB/s)
MX-4 T30 # load mmc 1:1 0x80408000 300M
314572800 bytes read in 14527 ms (20.7 MiB/s)
MX-4 T30 # load mmc 1:1 0x80408000 400M
419430400 bytes read in 19326 ms (20.7 MiB/s)
MX-4 T30 # load mmc 1:1 0x80408000 512M
536870912 bytes read in 24751 ms (20.7 MiB/s)
MX-4 T30 # load mmc 1:1 0x80408000 520M
545259520 bytes read in 478606 ms (1.1 MiB/s)
4Gb SD-card with ext3, (mkfs.ext3 -b 1024) (decrease performance when reading file >128M !)
16777216 bytes read in 1242 ms (12.9 MiB/s)
MX-4 T30 # load mmc 1:1 0x80408000 17M
17825792 bytes read in 1331 ms (12.8 MiB/s)
134217728 bytes read in 9750 ms (13.1 MiB/s)
135266304 bytes read in 12372 ms (10.4 MiB/s)
4Gb SD-card with ext3, (mkfs.ext3 -b 4096) (No problem at all)
134217728 bytes read in 6273 ms (20.4 MiB/s)
135266304 bytes read in 6338 ms (20.4 MiB/s)
536870912 bytes read in 25015 ms (20.5 MiB/s)
MX-4 T30 # load mmc 1:1 0x80408000 513M
537919488 bytes read in 25085 ms (20.4 MiB/s)
545259520 bytes read in 25435 ms (20.4 MiB/s)
USB-stick vfat-formatted (No problem at all)
MX-4 T30 # fatload usb 0:1 0x80408000 100M
reading 100M
104857600 bytes read in 3593 ms (27.8 MiB/s)
MX-4 T30 # fatload usb 0:1 0x80408000 128M
reading 128M
134217728 bytes read in 4600 ms (27.8 MiB/s)
MX-4 T30 # fatload usb 0:1 0x80408000 130M
reading 130M
157286400 bytes read in 5378 ms (27.9 MiB/s)
MX-4 T30 # fatload usb 0:1 0x80408000 200M
reading 200M
209715200 bytes read in 7172 ms (27.9 MiB/s)
MX-4 T30 # fatload usb 0:1 0x80408000 300M
reading 300M
314572800 bytes read in 10745 ms (27.9 MiB/s)
MX-4 T30 # fatload usb 0:1 0x80408000 400M
reading 400M
419430400 bytes read in 14320 ms (27.9 MiB/s)
MX-4 T30 # fatload usb 0:1 0x80408000 512M
reading 512M
536870912 bytes read in 18337 ms (27.9 MiB/s)
MX-4 T30 # fatload usb 0:1 0x80408000 600M
reading 600M
629145600 bytes read in 21471 ms (27.9 MiB/s)
