We are building U-BOOT from source code based on the following materials.
When obtaining the U-BOOT source, the following error occurs.
I’m having trouble figuring out the cause.
Thank you for your reply.
The following section is only necessary if using an upstream-based module. If you are using a downstream-based module, please, go to the Configure U-Boot section.
The above description does not mention the fetch operation.
I will try fetching as per your answer.
