I’m trying to write into uboot env-var using fw_setenv in script.
but I’m facing this problem
Write error on /dev/mmcblk0boot0: Operation not permitted
Error: can't write fw_env to flash
Do i miss something?
By default in Linux /dev/mmcblk0boot0 is read only.
Have a look at the following script which in our demo images to unlocks mmcblk0boot0 before writing to the U-Boot environment.
Ok I know how to solve this problem.
Is there any solution with this issue? I have same problem.
“Write error on /dev/mmcblk0boot0: Operation not permitted\nfsync failed on /dev/mmcblk0boot0: Input/output error\nError: can’t write fw_env to flash\n”
Colibri iMX7D 1GB v1.1A
Colibri Evaluation Board
HI @neotr
Could you provide the hardware and software of your module?
What are you trying to do?
Thank you, i fixed the problem.
Perfect. Thanks for the feedback.
