U-Boot patched with bugfix "link not estblished reliably" has strange behaviour w.r.t. pci functionality
We merged your patched U-Boot with the bugfix “physical link not established reliably” into our U-Boot.
On one single TK1 SOM assembled into the Apalis Eval Board when I execute pci enum the first time an error occurs and u-boot resets. When I abort the autoboot after the reset and execute pci enum again another error occurs.
Apalis TK1 # pci enum
data abort
pc : [<fff423e8>]          lr : [<fff6f9b0>]
reloc pc : [<801133e8>]    lr : [<801409b0>]
sp : fda11840  ip : 00000001     fp : fda21258
r10: 00000000  r9 : fda1eee0     r8 : fda1f0b0
r7 : fda213c4  r6 : fffaaa74     r5 : fff96da8  r4 : fffaf16c
r3 : 7009f000  r2 : 1c880077     r1 : fff96da8  r0 : fffaaa74
Flags: NzCv  IRQs off  FIQs off  Mode SVC_32
Resetting CPU ...
resetting ...
U-Boot 2016.11-00119-g992e9f344b (Aug 23 2017 - 11:10:22 +0200)
TEGRA124
DRAM:  2 GiB
MMC:   Tegra SD/MMC: 0, Tegra SD/MMC: 1, Tegra SD/MMC: 2
In:    serial
Out:   serial
Err:   serial
Model: Toradex Apalis TK1 2GB V1.1A, Serial# 02911982
Initializing leds...
Net:   No ethernet found.
ERROR: failed to enable LDO9: -22
at board/toradex/apalis-tk1/apalis-tk1.c:221/tegra_pcie_board_port_reset()
On the same SOM assembled into our custom baseboard I had a slightly different behaviour. When I execute pci enum the first time an error occurs and u-boot resets. When I abort the autoboot after the reset and execute pci enum again the pci devices can be detected and listed as usual.
Apalis TK1 # pci
No such bus
data abort
r3 : 7009f000  r2 : 16880077     r1 : fff96da8  r0 : fffaaa74
Resetting CPU ...
resetting ...
TEGRA124
DRAM:  2 GiB
In:    serial
Out:   serial
Err:   serial
Apalis TK1 # pci
Scanning PCI devices on bus 0
BusDevFun  VendorId   DeviceId   Device Class       Sub-Class
_____________________________________________________________
00.02.00   0x10de     0x0e13     Bridge device           0x04
Apalis TK1 #
Do you have an idea what the root cause of this behaviour could be?
While I vaguely recall having seen this once before I don’t think it ever happened with any clean build. As mentioned before we also run validation & verification tests with U-Boot in regards to gigabit Ethernet resp. PCIe enumeration and have never seen any such issue.
If this is indeed reproducible could you elaborate on the exact versions of things (both hardware as well as software) this is happening?
BTW: Meanwhile we did release 2.7b4.
I don’t think that it relates to your image. I just thought that you could have observed this behaviour during development as well (e.g. flash procedure did not work properly). Thanks for the notification.
Yes, as mentioned above I did. However I do not know what exactly caused it.
