Environment
BSP5.5
Apalis-iMX8
EVA board
U-Boot parameters such as “console” and “badrate” have not been applied to the kernel.
The U-Boot script is strange.
Probably the effect of the boot method being Distroboot.
Best regards.
Environment
BSP5.5
Apalis-iMX8
EVA board
Best regards.
Please describe the problem!
What files have you modified?
How do you check?
You can check the kernel parameters below.
cat / proc / cmdline
However, the kernel parameters do not include ttyLP1.
The console and baudrate parameters are not reflected.
Enter the following command in U-Boot.
setenv console ttyLP3 earlycon
saveenv
reset
Normally it can be changed to UART2, but it is not reflected.
Best regards.
Hi @developer0916 , have you tried tdxargs
It is possible to change it by changing tdxargs,
But should console, baudrate, etc. work?
The existence of unused settings is misleading.
This is a small issue.
Best regards.
Starting with BSP 5, all the custom Kernel Parameters should be added under tdxargs
. So both console
with the baudrate should be set under tdxargs.
Here is the complete list: The kernel’s command-line parameters — The Linux Kernel documentation
Try:
setenv tdxargs '${tdxargs} console=<port>,<baudrate>'
saveenv
Kind regards,
Alvaro.
