i am trying to patch u-boot lcd resolution and timing. (imx7d emmc , YOCTO and toradex 7.2.0)
Is u-boot-toradex using the dtsi with u-boot in the name
u-boot-toradex/2024.07/git/arch/arm/dts/imx7d-colibri-emmc-eval-v3-u-boot.dtsi
or only using imx7d-colibri-emmc-eval-v3.dts and its includes ?
Best Regards - Paul
Hello Paul,
Thank you for your question!
On the i.MX 7D eMMC platform with Torizon/Yocto using the Toradex U-Boot (u-boot-toradex), the U-Boot build system is set up to use special device tree source include files with -u-boot.dtsi in their names when present. These files are designed to override or provide settings specific to U-Boot that differ from what the Linux kernel would need.
How this works for your board:
- The primary device tree file for U-Boot would be
imx7d-colibri-emmc-eval-v3.dts.
- If the
.dts file contains a line such as #include "imx7d-colibri-emmc-eval-v3-u-boot.dtsi" or if the build system is configured to automatically include the corresponding -u-boot.dtsi, then those settings will be applied for U-Boot only.
- This mechanism helps maintain separation between kernel-specific and U-Boot-specific hardware settings, such as LCD timing.
To sum up:
Yes, U-Boot Toradex uses both the main .dts and, if present and included, the corresponding -u-boot.dtsi files for your i.MX7D Colibri eMMC board. You can place your LCD timing and resolution changes in either location, but placing U-Boot-specific changes in the *-u-boot.dtsi file ensures they won’t affect the Linux kernel’s device tree.
For more details:
If you need guidance with making the LCD timing patch, feel free to ask!
Hi AI
imx7d-colibri-emmc-eval-v3.dts source does not include the u-boot.dtsi unless there is a bitbake recipe changing something
– edit –
Assuming that the *u-boot.dtsi was a mistake I’ll be testing a patch of imx7d-colibri-emmc-eval-v3.dts on monday.
Regrads - Paul
Dear @BDSKPEF,
Thank you for sharing the hurdle you are facing with us. May I ask if the display is working otherwise? Is there simply just a resolution issue or does the display remain dark? What specific interface are you using? Is it connected via parallel RGB? Is there anything you can see during booting or in u-boot?
Collin
Hi Collin,
the display is black during u-boot , it does not show anything before the kernel splash screen.
Display is set in kernel by dtbo with same definition as the u-boot devicetree patch.
We are using the Colibri evaluation board LVDS connector.
Actually, there is no signal on LCD_PCLK_WR before the kernel splash shows.
The problem might simply relate to the discontinuation of splash support in u-boot-toradex, which i am trying to (re)configure in the u-boot .config. (Ill go through the posts related to this again
Best Regards - Paul
@ToradexAI
The standard uboot-imx from github will use the directly referenced dts/dtsi files and on top of that include all files with the same names extended with “-u-boot” .
So that build system is configured as mentioned in the quote.
This leaves the question wether the YOCTO build does the same ?
Thanks for your response.
Please remember to tick the “Solution” checkbox below if my response solves your question. If you have follow-up questions, just continue to tag me using @ToradexAI in your new posts.
Hello Paul,
Great follow-up question!
When building U-Boot for the i.MX 7D with Yocto (especially with Toradex BSP 7.x.y releases), the Yocto-based build system uses the upstream U-Boot source, which adopts the same device tree handling behavior as the mainline U-Boot:
For each <board>.dts, the build system looks for a corresponding *-u-boot.dtsi and, if present, includes it automatically—even if the .dts does not explicitly reference it.
This mechanism is upstream U-Boot behavior and is not changed by either Yocto or Toradex meta layers.
So, when you build U-Boot using Yocto recipes provided by Toradex (e.g., u-boot-toradex_%.bbappend), the device tree inclusion logic remains as follows:
- The build will process your main
.dts file for the board.
- If a
*-u-boot.dtsi file matching the .dts basename exists, its changes are automatically overlaid for the U-Boot build.
- You do not need to directly reference the
*-u-boot.dtsi in your .dts or modify the recipe to make this work.
Practical implication:
If you want settings (e.g., LCD resolution/timing) to apply only for U-Boot, place those changes in the relevant *-u-boot.dtsi.
If they should apply to both U-Boot and kernel, use the board’s main .dts or shared .dtsi.
References:
Let me know if you would like more guidance about LCD configuration or U-Boot splash support.
