For the Verdin i.MX 95 Evaluation Kit (PN: 05241104), when I inspect the U-Boot configs/ directory, I can see the following configuration files:
configs/imx95_15x15_evk_defconfig
configs/imx95_19x19_evk_defconfig
configs/imx95_a0_19x19_evk_defconfig
configs/imx95_evk.config
configs/toradex-smarc-imx95_defconfig
Which of these configurations should be selected for the Verdin i.MX 95 Evaluation Kit, or what would be the recommended and fastest path to generate a working U-Boot configuration for this kit?
Additionally, does Toradex provide any kit-specific documentation or guidelines for building and running U-Boot on the Verdin i.MX 95 Evaluation Kit (PN: 05241104)?
I can see you’re working with the Verdin i.MX 95 Evaluation Kit (PN: 05241104) and need guidance on U-Boot configuration.
Available Kit Information
The Verdin i.MX 95 Evaluation Kit features the NXP i.MX 95 with 6x Arm Cortex-A55 cores and comes with a modified Verdin form factor(1). However, I don’t have specific information about which U-Boot configuration file to use for this particular kit from the available sources.
Recommended Next Steps
To get the correct U-Boot configuration and kit-specific documentation for the Verdin i.MX 95 Evaluation Kit, I recommend checking these resources:
Community - for specific U-Boot configuration guidance
GitHub - for accessing Toradex repositories and configuration files
The sources mention that the kit is shipping now(1) and there are blog posts about development work(2), but specific U-Boot configuration details aren’t included in the available documentation.
Would you like me to provide a general answer based on my knowledge about typical Toradex U-Boot configurations, or would you prefer to check the recommended resources first for the most accurate and up-to-date information?
We have the Getting Started guide, which will help you with the first steps.
Regarding the U-boot itself, we don’t have specific documentation. If you need further assistance, I recommend reaching out on NXP’s forum, as the BSP for iMX95 EVK is maintained by them.
