I think I’ve found a problem in the u-boot sources you are providing.
I am using u-boot 2016.11 (BSP-2.8) downloaded from your git repo
git clone -b 2016.11-toradex git://git.toradex.com/u-boot-toradex.git
I noticed that after the configuration
make colibri_imx6_defconfig
The resulting default u-boot environment (the one statically compiled into u-boot) is not the same that you are using by default into your Easy Installer images.
In fact, if after a fresh recovery of the bootloader using the new image just recompiled by the process above, you set the default environment using the u-boot command below…
Colibri iMX6 # env default -a
You have a couple of wrong settings in the file ./include/configs/colibri_imx6.h
- “boot_file=zImage\0”
- "vidargs=video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24 "
So because the images you are generating are still in the old format uImage the system is not able to boot.
Colibri iMX6 # print boot_file
boot_file=zImage
I would have expected to get a bootloader with exactly the same settings you are providing in the default images.
