uvi
March 19, 2018, 9:44am
#1
Hello all,
I would like to turn off my backlight in LCD rouchscreen display, while the qt application should run in background.
I tried with /etc/power/state with standby and freeze. but it restarts my application.
is there any possiblity to turn off backlight.
Thank you
Uvi
uvi
March 19, 2018, 12:47pm
#2
thank you for the suggestion. I found the answer to implement the backlight power on/off.
how did you implement your solution?
How is your display connected to your Apalis device? Backlight control is usually implemented with an on/off switch which you can control via a GPIO, and/or through dimming with PWM.
Ok, thanks for the information.
uvi
March 19, 2018, 2:57pm
#6
i found the backlight BLK_ON gpio pin from the datasheet and implemented it in the device-tree.
