I wish to hide the cursor (maybe by using setterm -cursor off) but the Yocto version I bitbaked doesn’t have this command.
How can I include this in the Yocto or, alternatively, disable the terminal by default when building my distribution?
Greetings @Ilan_Figueiredo!
You can try removing the framebuffer console support on the kernel completely. Please follow these instructions to do so.
I am having issues finding in which layer is the CONFIG_FRAMEBUFFER_CONSOLE set. The only thing I would like to preserve is the Splash Image, which I plan to change.
The CONFIG_FRAMEBUFFER_CONSOLE option you disable in the .config (defconfig) of the kernel
Hi @Ilan_Figueiredo,
If you want to add this change in your Yocto Build layer, then you have to add a custom defconfig referenced by a linux-toradex_%.bbappend in a recipes-kernel/linux directory, similar as shown here.
André Curvello
I’ve managed to suppress the terminal and bitbake a new kernel with a modified Device Tree and I am working on incorporating our application as a service in systemd.
I’ve managed to reduce a good deal of the kernel, however the application still takes too long to start. The goal is to have it running within 2 seconds (or at least 2 seconds after the bootload), but printing a logo before the application start would suffice for a first version.
I am dealing with some issues in the U-Boot too (Issue changing U-Boot Splash - Technical Support - Toradex Community). Meanwhile, I am trying to improve my recipe. Would changing the systemd for another initializer improve the booting speed?
@Ilan_Figueiredo
Glad that you were able to solve the terminal issue.
We have a blog on boot time optimization: Embedded Linux Boot Time Optimization - Toradex Modules. It’s quite old but you surely can get some pointers from there. The first thing I would do would be to analyze the boot process (with e.g. systemd-analyze and other tools) to see what’s taking longer to start.
My feeling is that changing your init for something like SysV could improve your boot time, but not necessarily. I think you might be able to achieve the boot time you want with systemd, but if you don’t, you might try SysV or even a custom init such as described in the blog I linked earlier.
If you want to discuss this boot time issue further, feel free to create a new topic so we can try to solve this.
One more issue. I have managed to disable the console and still run a graphical application without the X11. However, I need to use a splash screen on turn on and I am struggling to create a slash in either U-Boot or Linux.
Can you create another thread for the splash screen issues?
André Curvello
