Hello Toradex Community,
I am using imx6ull Aster Carrier Board with TDX Wayland with XWayland Upstream 6.7.0-devel-20240710125113+build.0 (kirkstone) Colibri-iMX6ULL-eMMC_Reference-Multimedia-Image-upstream tdx-reference-multimedia-image (OS)
I’m facing an issue with OpenVPN on my i.MX6ULL board. After configuring OpenVPN, I notice that the tun0 interface is not appearing when I run ifconfig. tun kernel module is already loaded and service file of openvpn client is also active.
It seems like you’ve already taken some important steps, such as ensuring the tun kernel module is loaded and the OpenVPN client service is active. However, the absence of the tun0 interface in ifconfig suggests that there might be an issue with the OpenVPN configuration or the service startup.
Here are a few steps you can take to troubleshoot and resolve the issue:
Check OpenVPN Logs:
The OpenVPN logs can provide detailed information about what might be going wrong. You can check the logs using:
sudo journalctl -u openvpn@client
Look for any error messages or warnings that might indicate why the tun0 interface is not being created.
Verify Configuration Files:
Ensure that the client.conf file is correctly configured. Pay special attention to the following lines:
dev tun
ca /etc/openvpn/ca.crt
cert /etc/openvpn/client.crt
key /etc/openvpn/client.key
remote <server_ip> <port>
Make sure the paths to the certificate and key files are correct and that the remote line points to the correct server IP and port.
Check Network Configuration:
Ensure that IP forwarding is enabled on your system. You can check this by running:
sudo sysctl net.ipv4.ip_forward
If it is not enabled, you can enable it by adding the following line to /etc/sysctl.conf:
net.ipv4.ip_forward = 1
Then reload the sysctl configuration:
sudo sysctl -p
Restart OpenVPN Service:
Sometimes, simply restarting the OpenVPN service can resolve the issue:
sudo systemctl restart openvpn@client
Check for Conflicting Network Interfaces:
Ensure that there are no other network interfaces that might be conflicting with tun0.
Manual Interface Creation:
As a last resort, you can try to manually create the tun0 interface to see if it helps:
sudo ip tuntap add dev tun0 mode tun
sudo ip link set tun0 up
If none of these steps resolve the issue, please provide more details from the OpenVPN logs, and any error messages you encounter. This will help in diagnosing the problem further.
Hi @Prial ,
We were unable to continue up on this ticket. If the issue still persists, please feel free to open a new thread so we can assist you further.
As this ticket has become outdated, we will be closing it for now.
