Hello Team ,
I have Verdin 8mp board.
I have verdin development board
I want to autostart my application. I am doing create-production-image. I am getting error response
- Executing task: pwsh -nop /home/stryker/cam/.conf/createDockerComposeProduction.ps1 /home/stryker/cam torizon v0.0.0 registry-1.docker.io cam -imx8
Docker registry password: ************
Rebuilding torizon/cam:v0.0.0 …
Executing task: apply-torizon-packages-arm64 <
Applying torizonPackages.json …
Applying to Dockerfile.debug …
Dockerfile.debug
Applying to Dockerfile …
Dockerfile
torizonPackages.json applied
Executing task: build-container-torizon-release-arm64 <
WARN[0000] /home/stryker/cam/docker-compose.yml: the attributeversionis obsolete, it will be ignored, please remove it to avoid potential confusion
[+] Building 1.9s (14/14) FINISHED docker:default
=> [cam internal] load build definition from Dockerfile 0.0s
=> => transferring dockerfile: 1.55kB 0.0s
=> [cam internal] load metadata for docker.io/torizon/debian:3.5.0 1.8s
=> [cam auth] torizon/debian:pull token for registry-1.docker.io 0.0s
=> [cam internal] load .dockerignore 0.0s
=> => transferring context: 117B 0.0s
=> [cam 1/7] FROM docker.io/torizon/debian:3.5.0@sha256:f8f8f3446231a51c7e91f1d93b0e1beb553576d01e09df53bc98298755233e7a 0.0s
=> [cam internal] load build context 0.0s
=> => transferring context: 97B 0.0s
=> CACHED [cam 2/7] RUN apt-get -q -y update && apt-get -q -y install python3-minimal python3-pip python3-venv && apt-get clean && apt-get au 0.0s
=> CACHED [cam 3/7] RUN python3 -m venv /home/torizon/app/.venv --system-site-packages 0.0s
=> CACHED [cam 4/7] COPY requirements-release.txt /requirements-release.txt 0.0s
=> CACHED [cam 5/7] RUN . /home/torizon/app/.venv/bin/activate && pip3 install --upgrade pip && pip3 install -r requirements-release.txt && rm requiremen 0.0s
=> CACHED [cam 6/7] COPY ./src /home/torizon/app/src 0.0s
=> CACHED [cam 7/7] WORKDIR /home/torizon/app 0.0s
=> [cam] exporting to image 0.0s
=> => exporting layers 0.0s
=> => writing image sha256:6d976bf960a04596c00f3b607bc0730d0e981a204e6e512d51b739768eab9d41 0.0s
=> => naming to docker.io/torizon/cam:v0.0.0 0.0s
=> [cam] resolving provenance for metadata file 0.0s
Image rebuild and tagged
Pushing it torizon/cam:v0.0.0 …
Error response from daemon: Get “https://registry-1.docker.io/v2/”: unauthorized: incorrect username or password
NativeCommandExitException: /home/stryker/cam/.conf/createDockerComposeProduction.ps1:173:1
Line |
173 | Write-Output “$psswd” | docker login $registry -u $dockerLogin --pass …
| Program “docker” ended with non-zero exit code: 1.
- The terminal process “pwsh ‘-nop’, ‘/home/stryker/cam/.conf/createDockerComposeProduction.ps1’, ‘/home/stryker/cam’, ‘torizon’, ‘v0.0.0’, ‘registry-1.docker.io’, ‘cam’, ‘-imx8’” terminated with exit code: 1.
- Terminal will be reused by tasks, press any key to close it.
