Trouble with pppd connection
I’m trying to use a quectel EC21 LTE module to access the internet using a SIM card. Using the pppd command I get to the point where i have a connection and I can access the internet, but in a limited way. For example, I can ping google using its IP ping 216.239.36.117 and it works fine, but if I try to ping it using ping google.com it says it’s a bad address and i can’t access it.
I’ve searched info about this and I’ve found that adding nameserver 8.8.8.8 on the file /etc/resolv.conf solves the problem, but it seems to me that a network manager should do that instead of me manually changing it after every boot.
Also, how can I make it so that pppd automatically starts a connection with the SIM card on boot?
Thanks in advance
HI @AlexPG
Thanks for writing to the Community!
Which connection manager are you using? Connman or network manager? Please check also this page for further information.
You may create a script which is started on boot of the module as explained here.
Hey @jaski.tx
Thanks for answering!
I have connman installed, but I’m not using it for this connection. If I type connmanctl services I see nothing, how can I do to configure a ppp connection such as this using connman?
ppp0      Link encap:Point-to-Point Protocol
          inet addr:10.165.112.157  P-t-P:10.64.64.64  Mask:255.255.255.255
          UP POINTOPOINT RUNNING NOARP MULTICAST  MTU:1500  Metric:1
          RX packets:14 errors:0 dropped:0 overruns:0 frame:0
          TX packets:14 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:3
          RX bytes:700 (700.0 B)  TX bytes:680 (680.0 B)
Thanks I did something similar yesterday which more or less works.
Thanks in advance,
Alex
Hi Alex,
Could you have a look here?
Hey Jaski,
thanks for the tip, I managed to make it run and created a service to enable it automatically.
The problem with the IPs was that I missed a file from quectel, once I added it it worked fine.
best regards,
Alex
Perfect that you found a solution. Thanks for the feedback.
