I am trying to make work LVDS dual channel with the Apalis IMX6 and the Apalis Evaluation Board but I am not able to get any video.
This is my UBoot vidargs
vidargs=mxc_hdmi.only_cea=1 video=mxcfb0:dev=ldb, video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off fbmem=32M
And I also modified the device tree with the next:
--- a/arch/arm/boot/dts/imx6qdl-apalis.dtsi
+++ b/arch/arm/boot/dts/imx6qdl-apalis.dtsi
@@ -89,7 +89,7 @@
mxcfb1: fb@0 {
compatible = "fsl,mxc_sdc_fb";
disp_dev = "ldb";
- interface_pix_fmt = "RGB666";
+ interface_pix_fmt = "RGB24";
default_bpp = <16>;
int_clk = <0>;
late_init = <0>;
@@ -508,19 +508,32 @@
&ldb {
-// split-mode;
-// dual-mode;
+ split-mode;
lvds-channel@0 {
reg = <0>;
fsl,data-mapping = "spwg"; /* "jeida"; */
- fsl,data-width = <18>;
+ fsl,data-width = <24>;
crtc = "ipu2-di1";
primary;
display-timings {
- native-mode = <&timing_xga>;
+ native-mode = <&timing_widehd>;
+ timing_widehd: 1920x720 {
+ clock-frequency = <47500000>;
+ hactive = <1920>;
+ vactive = <720>;
+ hback-porch = <0>;
+ hfront-porch = <0>;
+ vback-porch = <0>;
+ vfront-porch = <0>;
+ hsync-len = <80>;
+ vsync-len = <40>;
+ /*hsync-active = <0>;
+ vsync-active = <0>;*/
+ pixelclk-active = <0>;
/* LDB-AM-800600LTNQW-A0H */
timing_svga: 800x600 {
clock-frequency = <55000000>;
The timing of my TFT is:
Info of linux version:
root@apalis-imx6:~# uname -a
Linux apalis-imx6 4.9.87-2.8.4+g3bb6e3284a1b #1 SMP Fri Nov 30 03:50:06 UTC 2018 armv7l GNU/Linux
fbset info:
root@apalis-imx6:~# fbset
mode "1920x720-31"
# D: 47.501 MHz, H: 23.751 kHz, V: 31.251 Hz
geometry 1920 720 1920 720 16
timings 21052 0 0 0 0 80 40
rgba 5/11,6/5,5/0,0/0
endmode
Can you help me to review it and see If I am missing something?
