I am trying to set up an iMX7 to accept a QT cross compile but I cannot seem to get the new image to boot.
I am following the instructions here:
and trying to use the QT5 for Xserver.
I follow the instructions and successfully create an image transfer it to an SD card, and then run the setup as described on this page:
Everything appears to complete successfully,
Colibri iMX7 # run setupdate
reading colibri_imx7/flash_blk.img
881 bytes read in 21 ms (40 KiB/s)
## Executing script at 80800000
enter "run update" to update the entire module
Colibri iMX7 #
Colibri iMX7 # run update
reading colibri_imx7/u-boot-nand.imx
524288 bytes read in 46 ms (10.9 MiB/s)
NAND erase.part: device 0 offset 0x80000, size 0x380000
Erasing at 0x80000 -- 3% complete.
Erasing at 0xa0000 -- 7% complete.
Erasing at 0xc0000 -- 10% complete.
Erasing at 0xe0000 -- 14% complete.
Erasing at 0x100000 -- 17% complete.
Erasing at 0x120000 -- 21% complete.
Erasing at 0x140000 -- 25% complete.
Erasing at 0x160000 -- 28% complete.
Erasing at 0x180000 -- 32% complete.
Erasing at 0x1a0000 -- 35% complete.
Erasing at 0x1c0000 -- 39% complete.
Erasing at 0x1e0000 -- 42% complete.
Erasing at 0x200000 -- 46% complete.
Erasing at 0x220000 -- 50% complete.
Erasing at 0x240000 -- 53% complete.
Erasing at 0x260000 -- 57% complete.
Erasing at 0x280000 -- 60% complete.
Erasing at 0x2a0000 -- 64% complete.
Erasing at 0x2c0000 -- 67% complete.
Erasing at 0x2e0000 -- 71% complete.
Erasing at 0x300000 -- 75% complete.
Erasing at 0x320000 -- 78% complete.
Erasing at 0x340000 -- 82% complete.
Erasing at 0x360000 -- 85% complete.
Erasing at 0x380000 -- 89% complete.
Erasing at 0x3a0000 -- 92% complete.
Erasing at 0x3c0000 -- 96% complete.
Erasing at 0x3e0000 -- 100% complete.
OK
NAND erase.part: device 0 offset 0x400000, size 0x80000
Erasing at 0x400000 -- 25% complete.
Erasing at 0x420000 -- 50% complete.
Erasing at 0x440000 -- 75% complete.
Erasing at 0x460000 -- 100% complete.
OK
Write bootloader...
Bootloader 655360 bytes written to 0x80000: OK
Bootloader 655360 bytes written to 0x200000: OK
reading colibri_imx7/ubifs.img
168497152 bytes read in 7339 ms (21.9 MiB/s)
UBI: default fastmap pool size: 200
UBI: default fastmap WL pool size: 25
UBI: attaching mtd1 to ubi0
UBI: attached by fastmap
UBI: fastmap pool size: 200
UBI: fastmap WL pool size: 25
UBI: attached mtd1 (name "mtd=3", size 507 MiB) to ubi0
UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
UBI: good PEBs: 4056, bad PEBs: 4, corrupted PEBs: 0
UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
UBI: max/mean erase counter: 5/1, WL threshold: 4096, image sequence number: 0
UBI: available PEBs: 0, total reserved PEBs: 4056, PEBs reserved for bad PEB handling: 76
168497152 bytes written to volume rootfs
resetting ...
But it does not reset.
if I reset or power cycle the board, it begins booting the Kernel but just stops at loading the USB Hub.
U-Boot 2015.04+fslc+ge1a48b2 (Jun 13 2016 - 11:15:49)
CPU: Freescale i.MX7D rev1.0 at 792 MHz
CPU: Temperature 41 C
Reset cause: POR
I2C: ready
DRAM: 256 MiB
PMIC: RN5T567 LSIVER=0x1 OTPVER=0xd
NAND: 512 MiB
MMC: FSL_SDHC: 0
*** Warning - bad CRC, using default environment
No panel detected: default to vga-rgb
Display: vga-rgb (640x480)
Video: 640x480x18
In: serial
Out: serial
Err: serial
Missing Toradex config block
Model: Toradex Colibri iMX7 Solo
Net: FEC0
Error: FEC0 address not set.
Normal Boot
Booting from NAND...
UBI: max/mean erase counter: 7/2, WL threshold: 4096, image sequence number: 0
Loading file '/boot/zImage' to addr 0x80800000 with size 5267872 (0x005061a0)...
Done
Loading file '/boot/imx7d-colibri.dtb' to addr 0x83000000 with size 39196 (0x0000991c)...
Done
Kernel image @ 0x80800000 [ 0x000000 - 0x5061a0 ]
## Flattened Device Tree blob at 83000000
Booting using the fdt blob at 0x83000000
Using Device Tree in place at 83000000, end 8300c91b
Starting kernel ...
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.14.52-v2.6b2+g9ace52b (greg@Embedded-Builder) (gcc version 5.2.1 20151005 (Linaro GCC 5.2-2015.11-2) ) #1 SMP Fri Jun 10 17:26:30 EDT 2016
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Toradex Colibri iMX7D on Colibri Evaluation Board V3
[ 0.000000] cma: CMA: reserved 128 MiB at 88000000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] PERCPU: Embedded 7 pages/cpu @87d8d000 s7936 r8192 d12544 u32768
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
[ 0.000000] Kernel command line: ubi.mtd=ubi root=ubi0:rootfs rootfstype=ubifs ubi.fm_autoconvert=1 console=tty1 console=ttymxc0,115200n8 consoleblank=0 mtdparts=gpmi-nand:512k(mx7-bcb),3584k(u-boot)ro,512k(u-boot-env),-(ubi)
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 118484K/262144K available (6659K kernel code, 308K rwdata, 2176K rodata, 287K init, 403K bss, 143660K reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0x90800000 - 0xff000000 (1768 MB)
[ 0.000000] lowmem : 0x80000000 - 0x90000000 ( 256 MB)
[ 0.000000] pkmap : 0x7fe00000 - 0x80000000 ( 2 MB)
[ 0.000000] modules : 0x7f000000 - 0x7fe00000 ( 14 MB)
[ 0.000000] .text : 0x80008000 - 0x808a914c (8837 kB)
[ 0.000000] .init : 0x808aa000 - 0x808f1f00 ( 288 kB)
[ 0.000000] .data : 0x808f2000 - 0x8093f240 ( 309 kB)
[ 0.000000] .bss : 0x8093f248 - 0x809a3e98 ( 404 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] .RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Switching to timer-based delay loop
[ 0.000010] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655765682ns
[ 0.000528] Architected cp15 timer(s) running at 8.00MHz (phys).
[ 0.000550] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2147483648000ns
[ 0.000558] Ignoring duplicate/late registration of read_current_timer delay
[ 0.001159] Console: colour dummy device 80x30
[ 0.001589] console [tty1] enabled
[ 0.001612] Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
[ 0.001641] pid_max: default: 32768 minimum: 301
[ 0.001802] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001824] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.006309] device-tree: Duplicate name in /soc/aips-bus@30400000/lcdif@30730000, renamed to "display#1"
[ 0.009618] Initializing cgroup subsys debug
[ 0.009648] Initializing cgroup subsys freezer
[ 0.009694] CPU: Testing write buffer coherency: ok
[ 0.009976] /cpus/cpu@0 missing clock-frequency property
[ 0.010003] /cpus/cpu@1 missing clock-frequency property
[ 0.010023] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.010062] Setting up static identity map for 0x8065b3d8 - 0x8065b430
[ 1.010865] CPU1: failed to come online
[ 1.010912] Brought up 1 CPUs
[ 1.010929] SMP: Total of 1 processors activated (6.00 BogoMIPS).
[ 1.010944] CPU: All CPU(s) started in SVC mode.
[ 1.011517] devtmpfs: initialized
[ 1.015708] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 1.016059] pinctrl core: initialized pinctrl subsystem
[ 1.016438] regulator-dummy: no parameters
[ 1.025765] device-tree: Duplicate name in lcdif@30730000, renamed to "display#1"
[ 1.030093] NET: Registered protocol family 16
[ 1.037005] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 1.037817] cpuidle: using governor ladder
[ 1.037839] cpuidle: using governor menu
[ 1.038032] Use WDOG1 as reset source
[ 1.046793] syscon 30340000.iomuxc-gpr: regmap [mem 0x30340000-0x3034ffff] registered
[ 1.047067] syscon 30350000.ocotp-ctrl: regmap [mem 0x30350000-0x3035ffff] registered
[ 1.047462] syscon 30360000.anatop: regmap [mem 0x30360000-0x3036ffff] registered
[ 1.048647] syscon 30390000.src: regmap [mem 0x30390000-0x3039ffff] registered
[ 1.050377] DDR type is DDR3!
[ 1.055857] failed to find ocotp node
[ 1.056004] failed to find ocotp node
[ 1.056196] imx7d_enet_clk_sel: failed to get enet_out clock, assuming ext. clock source
[ 1.056237] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 1.056258] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 1.056553] imx7d-pinctrl 302c0000.iomuxc-lpsr: initialized IMX pinctrl driver
[ 1.057825] imx7d-pinctrl 30330000.iomuxc: initialized IMX pinctrl driver
[ 1.058736] imx-gpcv2 303a0000.gpc: pcie regulator not ready.
[ 1.058772] platform 303a0000.gpc: Driver imx-gpcv2 requests probe deferral
[ 1.059228] MU is ready for cross core communication!
[ 1.066947] bio: create slab <bio-0> at 0
[ 1.069873] mxs-dma 33000000.dma-apbh: initialized
[ 1.070543] 3P3V: 3300 mV
[ 1.070818] usb_otg2_vbus: 5000 mV
[ 1.071057] vref-1v8: 1800 mV
[ 1.071814] SCSI subsystem initialized
[ 1.072128] usbcore: registered new interface driver usbfs
[ 1.072216] usbcore: registered new interface driver hub
[ 1.072363] usbcore: registered new device driver usb
[ 1.072581] usbphy_nop1.12 supply vcc not found, using dummy regulator
[ 1.072715] usbphy_nop2.13 supply vcc not found, using dummy regulator
[ 1.072840] platform usbphy_nop3.14: Driver usb_phy_gen_xceiv requests probe deferral
[ 1.074537] i2c i2c-0: IMX I2C adapter registered
[ 1.075196] i2c i2c-3: IMX I2C adapter registered
[ 1.075324] Linux video capture interface: v2.00
[ 1.075396] pps_core: LinuxPPS API ver. 1 registered
[ 1.075413] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.075455] PTP clock support registered
[ 1.075861] Advanced Linux Sound Architecture Driver Initialized.
[ 1.076715] Bluetooth: Core ver 2.18
[ 1.076770] NET: Registered protocol family 31
[ 1.076786] Bluetooth: HCI device and connection manager initialized
[ 1.076810] Bluetooth: HCI socket layer initialized
[ 1.076831] Bluetooth: L2CAP socket layer initialized
[ 1.076870] Bluetooth: SCO socket layer initialized
[ 1.077482] Switched to clocksource arch_sys_counter
[ 1.080896] cfg80211: Calling CRDA to update world regulatory domain
[ 1.087829] NET: Registered protocol family 2
[ 1.088682] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[ 1.088735] TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
[ 1.088788] TCP: Hash tables configured (established 2048 bind 2048)
[ 1.088854] TCP: reno registered
[ 1.088875] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 1.088915] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 1.089157] NET: Registered protocol family 1
[ 1.089446] RPC: Registered named UNIX socket transport module.
[ 1.089468] RPC: Registered udp transport module.
[ 1.089482] RPC: Registered tcp transport module.
[ 1.089497] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.091278] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 1.091388] imx rpmsg driver is registered.
[ 1.091909] Bus freq driver module loaded
[ 1.092717] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 1.100620] VFS: Disk quotas dquot_6.5.2
[ 1.100916] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.103320] NFS: Registering the id_resolver key type
[ 1.103385] Key type id_resolver registered
[ 1.103402] Key type id_legacy registered
[ 1.103449] jffs2: version 2.2. (NAND) .. 2001-2006 Red Hat, Inc.
[ 1.104215] fuse init (API version 7.22)
[ 1.104716] msgmni has been set to 487
[ 1.108031] io scheduler noop registered
[ 1.108056] io scheduler deadline registered
[ 1.108250] io scheduler cfq registered (default)
[ 1.110238] backlight.15 supply power not found, using dummy regulator
[ 1.112154] 30730000.lcdif supply lcd not found, using dummy regulator
[ 1.179207] mxsfb 30730000.lcdif: failed to find mxc display driver
[ 1.187394] Console: switching to colour frame buffer device 80x30
[ 1.204922] mxsfb 30730000.lcdif: initialized
[ 1.207576] imx-sdma 30bd0000.sdma: no event needs to be remapped
[ 1.209315] imx-sdma 30bd0000.sdma: loaded firmware 4.1
[ 1.214317] imx-sdma 30bd0000.sdma: initialized
[ 1.216340] Serial: IMX driver
[ 1.218501] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 58, base_baud = 1500000) is a IMX
[ 2.046935] console [ttymxc0] enabled
[ 2.052787] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 59, base_baud = 1500000) is a IMX
[ 2.065498] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 60, base_baud = 5000000) is a IMX
[ 2.078056] serial: Freescale lpuart driver
[ 2.084928] [drm] Initialized drm 1.1.0 20060810
[ 2.099875] brd: module loaded
[ 2.109291] loop: module loaded
[ 2.115844] DCDC1: 975 <--> 1125 mV at 1000 mV
[ 2.123366] DCDC2: 975 <--> 1125 mV at 1100 mV
[ 2.130831] DCDC3: 1775 <--> 1825 mV at 1800 mV
[ 2.138378] DCDC4: 1325 <--> 1375 mV at 1350 mV
[ 2.145893] LDO1: 1800 <--> 3300 mV at 3300 mV
[ 2.152810] LDO2: 1775 <--> 3325 mV at 3300 mV
[ 2.159682] LDO3: 3275 <--> 3325 mV at 3300 mV
[ 2.166461] LDO4: 1775 <--> 1825 mV at 1800 mV
[ 2.173222] LDO5: 1775 <--> 1825 mV at 3300 mV
[ 2.179891] LDORTC1: at 3000 mV
[ 2.185229] LDORTC2: at 900 mV
[ 2.189927] rn5t618 0-0033: probe finished ok: 0
[ 2.203751] nand: device found, Manufacturer ID: 0xc2, Chip ID: 0xdc
[ 2.211631] nand: Macronix MX30LF4G28AB
[ 2.216857] nand: 512MiB, SLC, page size: 2048, OOB size: 112
[ 2.224359] gpmi-nand 33002000.gpmi-nand: enable the asynchronous EDO mode 5
[ 2.233029] Bad block table found at page 262080, version 0x01
[ 2.240464] Bad block table found at page 262016, version 0x01
[ 2.247978] 4 cmdlinepart partitions found on MTD device gpmi-nand
[ 2.255471] Creating 4 MTD partitions on "gpmi-nand":
[ 2.261810] 0x000000000000-0x000000080000 : "mx7-bcb"
[ 2.268537] 0x000000080000-0x000000400000 : "u-boot"
[ 2.275055] 0x000000400000-0x000000480000 : "u-boot-env"
[ 2.281915] 0x000000480000-0x000020000000 : "ubi"
[ 2.288604] gpmi-nand 33002000.gpmi-nand: driver registered.
[ 2.297800] spi_imx 30840000.ecspi: probed
[ 2.303852] vcan: Virtual CAN interface driver
[ 2.309618] CAN device driver interface
[ 2.316843] pps pps0: new PPS source ptp0
[ 2.323565] fec 30be0000.ethernet (unregistered net_device): Invalid MAC address: 00:00:00:00:00:00
[ 2.335518] fec 30be0000.ethernet (unregistered net_device): Using random MAC address: 72:61:e3:8c:97:2b
[ 2.348781] libphy: fec_enet_mii_bus: probed
[ 2.356058] fec 30be0000.ethernet eth0: registered PHC device 0
[ 2.363913] usbcore: registered new interface driver asix
[ 2.371124] usbcore: registered new interface driver ax88179_178a
[ 2.378961] usbcore: registered new interface driver cdc_ether
[ 2.386448] usbcore: registered new interface driver net1080
[ 2.393764] usbcore: registered new interface driver cdc_subset
[ 2.401267] usbcore: registered new interface driver zaurus
[ 2.408416] usbcore: registered new interface driver cdc_ncm
[ 2.415512] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.423505] ehci-mxc: Freescale On-Chip EHCI Host driver
[ 2.430458] usbcore: registered new interface driver usb-storage
[ 2.438078] usbcore: registered new interface driver usbserial
[ 2.445406] usbcore: registered new interface driver usbserial_generic
[ 2.453448] usbserial: USB Serial support registered for generic
[ 2.461008] usbcore: registered new interface driver ftdi_sio
[ 2.468311] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.478656] usbcore: registered new interface driver pl2303
[ 2.485865] usbserial: USB Serial support registered for pl2303
[ 2.494410] 30b10200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 2.505124] 30b20200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 2.515824] 30b30200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 2.527214] 30b10000.usb supply vbus not found, using dummy regulator
[ 2.538204] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 2.544847] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 2.567538] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 2.575722] hub 1-0:1.0: USB hub found
[ 2.581412] hub 1-0:1.0: 1 port detected
[ 2.590685] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 2.597525] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[ 2.617506] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 2.625611] hub 2-0:1.0: USB hub found
[ 2.631299] hub 2-0:1.0: 1 port detected
Have I missed a step? are there known issues?
