I am using a new TK1 with Ixora board freshly flashed with ( Angstrom v2016.12 - Kernel 3.10.40-2.7.2+g0fd5295 - Apalis-TK1_LXDE-Image 2.7.2 20170410)
I dont have any displays connected to the system, but I have trouble because the touchscreen continuously sends events even though a touch screen does not exist.
evtest /dev/input/touchscreen0
Input driver version is 1.0.1
Input device ID: bus 0x0 vendor 0x0 product 0x0 version 0x0
Input device name: "apalis-tk1-k20-ts"
Supported events:
Event type 0 (EV_SYN)
Event type 1 (EV_KEY)
Event code 330 (BTN_TOUCH)
Event type 3 (EV_ABS)
Event code 0 (ABS_X)
Value 272
Min 0
Max 65535
Event code 1 (ABS_Y)
Value 264
Min 0
Max 65535
Event code 24 (ABS_PRESSURE)
Value 536
Min 0
Max 4095
Properties:
Testing ... (interrupt to exit)
Event: time 1491804086.746110, type 3 (EV_ABS), code 0 (ABS_X), value 270
Event: time 1491804086.746110, type 3 (EV_ABS), code 1 (ABS_Y), value 266
Event: time 1491804086.746110, -------------- SYN_REPORT ------------
Event: time 1491804086.787095, type 3 (EV_ABS), code 1 (ABS_Y), value 263
Event: time 1491804086.787095, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 533
Event: time 1491804086.787095, -------------- SYN_REPORT ------------
Event: time 1491804086.828067, type 3 (EV_ABS), code 0 (ABS_X), value 271
Event: time 1491804086.828067, type 3 (EV_ABS), code 1 (ABS_Y), value 264
Event: time 1491804086.828067, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 535
Event: time 1491804086.828067, -------------- SYN_REPORT ------------
Event: time 1491804086.869028, type 3 (EV_ABS), code 0 (ABS_X), value 276
Event: time 1491804086.869028, type 3 (EV_ABS), code 1 (ABS_Y), value 265
Event: time 1491804086.869028, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 541
Event: time 1491804086.869028, -------------- SYN_REPORT ------------
Event: time 1491804086.910085, type 3 (EV_ABS), code 0 (ABS_X), value 270
Event: time 1491804086.910085, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 536
Event: time 1491804086.910085, -------------- SYN_REPORT ------------
Event: time 1491804086.951071, type 3 (EV_ABS), code 0 (ABS_X), value 272
Event: time 1491804086.951071, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 538
Event: time 1491804086.951071, -------------- SYN_REPORT ------------
Event: time 1491804086.992080, type 3 (EV_ABS), code 0 (ABS_X), value 274
Event: time 1491804086.992080, type 3 (EV_ABS), code 1 (ABS_Y), value 266
Event: time 1491804086.992080, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 540
Event: time 1491804086.992080, -------------- SYN_REPORT ------------
Event: time 1491804087.033078, type 3 (EV_ABS), code 0 (ABS_X), value 271
Event: time 1491804087.033078, type 3 (EV_ABS), code 1 (ABS_Y), value 264
Event: time 1491804087.033078, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 535
Event: time 1491804087.033078, -------------- SYN_REPORT ------------
Event: time 1491804087.074102, type 3 (EV_ABS), code 0 (ABS_X), value 272
Event: time 1491804087.074102, type 3 (EV_ABS), code 1 (ABS_Y), value 265
Event: time 1491804087.074102, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 537
Event: time 1491804087.074102, -------------- SYN_REPORT ------------
Event: time 1491804087.115099, type 3 (EV_ABS), code 0 (ABS_X), value 271
Event: time 1491804087.115099, type 3 (EV_ABS), code 1 (ABS_Y), value 266
Event: tim[ 85.789882] EXT4-fs (mmcblk0p2): resizing filesystem from 4685824 to 4751360 blocks
e 1491804087.115099, -------------- SYN_REPORT ------------
Event: time 1491804087.156179, type 3 (EV_ABS), code 1 (ABS_Y), value 264
Event: time 1491804087.156179, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 535
Event: time 1491804087.156179, -------------- SYN_REPORT ------------
[ 85.839186] EXT4-fs (mmcblk0p2): resized filesystem to 4751360
Event: time 1491804087.197114, type 3 (EV_ABS), code 0 (ABS_X), value 273
Event: time 1491804087.197114, type 3 (EV_ABS), code 1 (ABS_Y), value 263
Event: time 1491804087.197114, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 537
Event: time 1491804087.197114, -------------- SYN_REPORT ------------
Event: time 1491804087.238086, type 3 (EV_ABS), code 0 (ABS_X), value 270
Event: time 1491804087.238086, type 3 (EV_ABS), code 1 (ABS_Y), value 265
Event: time 1491804087.238086, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 535
Event: time 1491804087.238086, -------------- SYN_REPORT ------------
Event: time 1491804087.279109, type 3 (EV_ABS), code 0 (ABS_X), value 272
Event: time 1491804087.279109, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 538
Event: time 1491804087.279109, -------------- SYN_REPORT ------------
Event: time 1491804087.360989, type 3 (EV_ABS), code 0 (ABS_X), value 271
Event: time 1491804087.360989, type 3 (EV_ABS), code 1 (ABS_Y), value 266
Event: time 1491804087.360989, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 537
Event: time 1491804087.360989, -------------- SYN_REPORT ------------
Event: time 1491804087.402268, type 3 (EV_ABS), code 0 (ABS_X), value 276
Event: time 1491804087.402268, type 3 (EV_ABS), code 1 (ABS_Y), value 264
Event: time 1491804087.402268, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 540
Event: time 1491804087.402268, -------------- SYN_REPORT ------------
Event: time 1491804087.443026, type 3 (EV_ABS), code 0 (ABS_X), value 272
Event: time 1491804087.443026, type 3 (EV_ABS), code 1 (ABS_Y), value 266
Event: time 1491804087.443026, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 538
Event: time 1491804087.443026, -------------- SYN_REPORT ------------
Event: time 1491804087.484038, type 3 (EV_ABS), code 0 (ABS_X), value 271
Event: time 1491804087.484038, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 537
Event: time 1491804087.484038, -------------- SYN_REPORT ------------
Event: time 1491804087.566069, type 3 (EV_ABS), code 1 (ABS_Y), value 264
Event: time 1491804087.566069, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 535
Event: time 1491804087.566069, -------------- SYN_REPORT ------------
Event: time 1491804087.607001, type 3 (EV_ABS), code 0 (ABS_X), value 270
Event: time 1491804087.607001, type 3 (EV_ABS), code 1 (ABS_Y), value 265
Event: time 1491804087.607001, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 536
Event: time 1491804087.607001, -------------- SYN_REPORT ------------
Event: time 1491804087.648200, type 3 (EV_ABS), code 0 (ABS_X), value 269
Event: time 1491804087.648200, type 3 (EV_ABS), code 1 (ABS_Y), value 266
Event: time 1491804087.648200, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 535
