At the moment I am trying to get a touch screen to run:
docker run -e ACCEPT_FSL_EULA=1 -ti --rm --privileged -v /dev:/dev -v /run/udev/:/run/udev/ -v /etc/udev/rules.d:/etc/udev/rules.d torizon/weston-touch-calibrator:$CT_TAG_WESTON_TOUCH_CALIBRATOR > log.txt
The file log.txt is attached to this mail. The weston-touch-calibratotor always fails with “weston-touch-calibrator error: “DPI-1” was not found.”
Elog.txt (9.5 KB)
vtest shows this:
apalis-imx8-06548606:~$ sudo evtest
Password:
No device specified, trying to scan all of /dev/input/event*
Available devices:
/dev/input/event0: sc-powerkey
/dev/input/event1: eGalax Inc. eGalaxTouch P80H32 7007 vJEO070RNB2 k4.10.142
/dev/input/event2: eGalax Inc. eGalaxTouch P80H32 7007 vJEO070RNB2 k4.10.142 UNKNOWN
Select the device event number [0-2]: 1
Input driver version is 1.0.1
Input device ID: bus 0x3 vendor 0xeef product 0xc002 version 0x111
Input device name: “eGalax Inc. eGalaxTouch P80H32 7007 vJEO070RNB2 k4.10.142”
Supported events:
Event type 0 (EV_SYN)
Event type 1 (EV_KEY)
Event code 330 (BTN_TOUCH)
Event type 3 (EV_ABS)
Event code 0 (ABS_X)
Value 0
Min 0
Max 16383
Resolution 108
Event code 1 (ABS_Y)
Value 0
Min 0
Max 16383
Resolution 181
Event code 47 (ABS_MT_SLOT)
Value 0
Min 0
Max 1
Event code 53 (ABS_MT_POSITION_X)
Value 0
Min 0
Max 16383
Resolution 108
Event code 54 (ABS_MT_POSITION_Y)
Value 0
Min 0
Max 16383
Resolution 181
Event code 57 (ABS_MT_TRACKING_ID)
Value 0
Min 0
Max 65535
Properties:
Property type 1 (INPUT_PROP_DIRECT)
Testing … (interrupt to exit)
Event: time 1630479372.1630479372, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value 0
Event: time 1630479372.1630479372, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 11849
Event: time 1630479372.1630479372, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 12889
Event: time 1630479372.1630479372, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1630479372.1630479372, type 3 (EV_ABS), code 0 (ABS_X), value 11849
Event: time 1630479372.1630479372, type 3 (EV_ABS), code 1 (ABS_Y), value 12889
Event: time 1630479372.1630479372, -------------- SYN_REPORT ------------
Event: time 1630479373.1630479373, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 11861
Event: time 1630479373.1630479373, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 12479
Event: time 1630479373.1630479373, type 3 (EV_ABS), code 0 (ABS_X), value 11861
Event: time 1630479373.1630479373, type 3 (EV_ABS), code 1 (ABS_Y), value 12479
Event: time 1630479373.1630479373, -------------- SYN_REPORT ------------
Event: time 1630479373.1630479373, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value -1
Event: time 1630479373.1630479373, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Seems that the touch is working properly but some configuration is missing?
Apalis iMX8qm
Ixora 1.1
Torizon 5.3.1
weston-vivante-2.2.0
