I have a Colibri iMX6 with a Viola carrier board and an EDT 3.5" display with resistive touch. I built a console-trdx-image where I completely removed the X11 and wayland components. So the display is controlled by eglfs.
Now a running Qt application, which works fine, but the touch screen axes are inverted. As I don’t have a X11, I cannot calibrate the touch screen with xinput_calibrator. Also I cannot find the command ts_calibrate.
Just looked into the tslib recipe. The command line tool has been split out into its own package.
It seems that you also need the tslib-calibrate package.
@Max.tx
Thanks, now I can use ts_calibrate. However, my Qt application doesn’t make use of the calibration file. I read about some environment variables yesterday, but I can’t remember their names or the pages I found them. Or is it something different?
@Max.tx
I just got it. Had to set the QT_QPA_EVDEV_TOUCHSCREEN_PARAMETERS environment variable. So root@colibri-imx6:~# export QT_QPA_EVDEV_TOUCHSCREEN_PARAMETERS=rotate=180 will do it!
