Hi all,
hope you are all well!
I am currently testing Torizon OS 6.4 and 6.5.0-develop with our customizations for our inhouse carrier board. In the TorizonCore 5.7.2 we were missing a driver for our touch controller, so I put the in-tree driver code into an out-of-tree kernel module, loaded it using torizoncore-builder
tool and later updated the driver by backporting the version from linux kernel 5.17 that we find is way more satisfying in scroll behavior.
Starting with Torizon OS 6.4, I suddenly observed a strange throwback in scroll behavior from pipeline builds and started to investigate why my local build still works perfectly fine. To be more clear, we use TEZI for first-time installation in production, but I use torizoncore-builder deploy
locally. I guess that my local build replaces the loaded modules on my device using ostree, whereas TEZI installation flashes the device. What I found out so far seems to be a pretty obvious clash in kernel module, as the Torizon OS 6.4 seems to already have a driver ready for our touch controller ili210x.ko
torizon@apalis-imx8-14798127:~$ ls /lib/modules/5.15.129-6.5.0-devel+git.6f32493eb88e/kernel/drivers/input/touchscreen/ -alh
total 732K
drwxr-xr-x 3 root root 4.0K Jan 1 1970 .
drwxr-xr-x 7 root root 4.0K Jan 1 1970 ..
-rw-r--r-- 2 root root 24K Jan 1 1970 ad7877.ko
-rw-r--r-- 2 root root 34K Jan 1 1970 ads7846.ko
-rw-r--r-- 2 root root 9.9K Jan 1 1970 ar1021_i2c.ko
-rw-r--r-- 2 root root 58K Jan 1 1970 atmel_mxt_ts.ko
-rw-r--r-- 2 root root 15K Jan 1 1970 colibri-vf50-ts.ko
-rw-r--r-- 2 root root 38K Jan 1 1970 edt-ft5x06.ko
-rw-r--r-- 2 root root 12K Jan 1 1970 eeti_ts.ko
-rw-r--r-- 2 root root 46K Jan 1 1970 elants_i2c.ko
-rw-r--r-- 2 root root 15K Jan 1 1970 elo.ko
-rw-r--r-- 2 root root 17K Jan 1 1970 exc3000.ko
-rw-r--r-- 2 root root 36K Jan 1 1970 goodix.ko
-rw-r--r-- 2 root root 19K Jan 1 1970 ili210x.ko
-rw-r--r-- 2 root root 23K Jan 1 1970 ilitek_ts_i2c.ko
-rw-r--r-- 2 root root 12K Jan 1 1970 max11801_ts.ko
-rw-r--r-- 2 root root 14K Jan 1 1970 mc13783_ts.ko
-rw-r--r-- 2 root root 11K Jan 1 1970 penmount.ko
-rw-r--r-- 2 root root 20K Jan 1 1970 pixcir_i2c_ts.ko
-rw-r--r-- 2 root root 30K Jan 1 1970 raydium_i2c_ts.ko
-rw-r--r-- 2 root root 13K Jan 1 1970 resistive-adc-touch.ko
-rw-r--r-- 2 root root 21K Jan 1 1970 rohm_bu21023.ko
-rw-r--r-- 2 root root 26K Jan 1 1970 silead.ko
-rw-r--r-- 2 root root 13K Jan 1 1970 sis_i2c.ko
-rw-r--r-- 2 root root 15K Jan 1 1970 st1232.ko
-rw-r--r-- 2 root root 25K Jan 1 1970 stmfts.ko
-rw-r--r-- 2 root root 23K Jan 1 1970 sx8654.ko
drwxr-xr-x 2 root root 4.0K Jan 1 1970 synaptics_dsx
-rw-r--r-- 2 root root 7.8K Jan 1 1970 tsc2004.ko
-rw-r--r-- 2 root root 8.1K Jan 1 1970 tsc2005.ko
-rw-r--r-- 2 root root 22K Jan 1 1970 tsc2007.ko
-rw-r--r-- 2 root root 22K Jan 1 1970 tsc200x-core.ko
-rw-r--r-- 2 root root 43K Jan 1 1970 usbtouchscreen.ko
torizon@apalis-imx8-14798127:~$ cat /etc/os-release
ID=torizon
NAME="TorizonCore"
VERSION="6.5.0-devel-202311+build.14 (kirkstone)"
VERSION_ID=6.5.0-devel-202311-build.14
PRETTY_NAME="TorizonCore 6.5.0-devel-202311+build.14 (kirkstone)"
DISTRO_CODENAME="kirkstone"
BUILD_ID="14"
ANSI_COLOR="1;34"
VARIANT="Docker"
And here comes my question: Is there an easy way to replace an existing module using torizoncore-builder tool? We really want to use the /drivers/input/touchscreen/ili210x.c
from kernel version v5.17
