TorizonCore opkg, dpkg, apt-get none are available
I installed the latest version of TorizonCore on my Apalis i.MX6 board.
I do have a problem that none of the packages I know for installing are available similar to apt-get.
Is there a specific package with that functionality that is present on the TorizonCore or a way to activate aa package like that because I am unable to install anything on the device and I need to add additional packages.
Hello @Svetoslav ,
You can you can build a Debian-based container image, where you can install the applications that you need.
The quickstart guide has a section that covers the use of containers, even with an example
Josep
Thank you for your response.
