TorizonCore Builder /var/lib
Hallo,
i am trying to use TorizonCore-Builder to create a base image for me and my colleges to work with during development.
One of the requirements is to setup a application data directory. As for the Filesystem Hierarchy under linux i want o use the ‘/var/lib’ for this. I created a tcbuild.yaml and added the filesystem to achive this.
tcbuild.yaml
input:
  easy-installer:
    remote: https://artifacts.toradex.com/artifactory/torizoncore-oe-prerelease-frankfurt/kirkstone-6.x.y/monthly/8/colibri-imx8x/torizon/torizon-core-docker/oedeploy/torizon-core-docker-colibri-imx8x-Tezi_6.3.0-devel-202306+build.8.tar
customization:
  filesystem:
    - appdata
output:
  easy-installer:
    local: output
  ostree:
    branch: image
    commit-subject: Image
Directory
├── appdata
│   └── var
│       └── lib
│           └── AppData
└── tcbuild.yaml
When i build the image everything seams fine
=>> Handling input section
Fetching URL 'https://artifacts.toradex.com/artifactory/torizoncore-oe-prerelease-frankfurt/kirkstone-6.x.y/monthly/8/colibri-imx8x/torizon/torizon-core-docker/oedeploy/torizon-core-docker-colibri-imx8x-Tezi_6.3.0-devel-202306+build.8.tar' into '/tmp/torizon-core-docker-colibri-imx8x-Tezi_6.3.0-devel-202306+build.8.tar'
Download Complete!
Downloaded file name: '/tmp/torizon-core-docker-colibri-imx8x-Tezi_6.3.0-devel-202306+build.8.tar'
No integrity check performed because checksum was not specified.
Unpacking Toradex Easy Installer image.
Copying Toradex Easy Installer image.
Unpacking TorizonCore Toradex Easy Installer image.
Importing OSTree revision 6c5ba030cf90f0ee46198f4fed7bb5b5979ea284d8aa02d1c1b2b13c56301941 from local repository...
940 metadata, 9191 content objects imported; 574.5 MB content written
Unpacked OSTree from Toradex Easy Installer image:
  Commit checksum: 6c5ba030cf90f0ee46198f4fed7bb5b5979ea284d8aa02d1c1b2b13c56301941
  TorizonCore Version: 6.3.0-devel-202306+build.8
=>> Handling customization section
=>> Handling output section
Applying changes from WORKDIR/appdata.
Commit ecb190680cb06002ca466312c22907983e5d9822dcf822513fdbb6b8b4e73957 has been generated for changes and is ready to be deployed.
Pulling OSTree with ref image from local archive repository...
  Commit checksum: ecb190680cb06002ca466312c22907983e5d9822dcf822513fdbb6b8b4e73957
  TorizonCore Version: 6.3.0-devel-202306+build.8-tcbuilder.20230627064842
  Default kernel arguments: quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3
941 metadata, 9191 content objects imported; 574.5 MB content written
Pulling done.
Deploying OSTree with checksum ecb190680cb06002ca466312c22907983e5d9822dcf822513fdbb6b8b4e73957
Deploying done.
Copy files not under OSTree control from original deployment.
Packing rootfs...
Packing rootfs done.
Updating TorizonCore image in place.
=>> Build command successfully executed!
Deploying commit ref: image
Also deploying works without an error
Pulling OSTree with ref image (checksum ecb190680cb06002ca466312c22907983e5d9822dcf822513fdbb6b8b4e73957) from local archive repository...
Starting http server to serve OSTree.
OSTree server listening on "localhost:45509".
Starting OSTree pull on the device...
Deploying new OSTree on the device...
Deploying successfully finished.
Please reboot the device to boot into the new deployment.
I reboot the board but i cannot find the directory that should be created → /var/lib/AppData
Is there something i am doing wrong?
Simon
Hello @SimonBaur ,
Unfortunately what you are trying to achieve is not possible with TorizonCore builder.
Since the update system is based on OSTree, you should read this documentation:
As an alternative you could use /etc/var/lib/AppData
These articles in the developer webpage might help you:
Josep
Hello @SimonBaur ,
Are there any updates on this topic? Were you able to solve your issue?
Josep
Hallo @josep.tx,
yes it did. Thanks
