Dear Toradex,
In our Azure DevOps pipeline we want to pre-provision our docker containers into our image. To do that we want to integrate the TorizonCore builder tool in the pipeline, it seems to work most of the time, however sometimes I run into the following error:
2024-08-26T10:36:13.2074689Z Starting DIND container
2024-08-26T10:36:13.2075125Z Using Docker host "tcp://127.0.0.1:22376"
2024-08-26T10:36:16.4930349Z Connecting to Docker Daemon at "tcp://127.0.0.1:22376"
2024-08-26T10:36:16.4942490Z Stopping DIND container
2024-08-26T10:36:17.6076582Z An unexpected Exception occurred. Please provide the following stack trace to
2024-08-26T10:36:17.6076932Z the Toradex TorizonCore support team:
2024-08-26T10:36:17.6076995Z
2024-08-26T10:36:17.6077034Z
2024-08-26T10:36:17.6193184Z Traceback (most recent call last):
2024-08-26T10:36:17.6193922Z File "/usr/local/lib/python3.9/dist-packages/urllib3/connection.py", line 198, in _new_conn
2024-08-26T10:36:17.6194501Z sock = connection.create_connection(
2024-08-26T10:36:17.6194850Z File "/usr/local/lib/python3.9/dist-packages/urllib3/util/connection.py", line 85, in create_connection
2024-08-26T10:36:17.6195050Z raise err
2024-08-26T10:36:17.6195297Z File "/usr/local/lib/python3.9/dist-packages/urllib3/util/connection.py", line 73, in create_connection
2024-08-26T10:36:17.6195461Z sock.connect(sa)
2024-08-26T10:36:17.6195604Z ConnectionRefusedError: [Errno 111] Connection refused
2024-08-26T10:36:17.6195681Z
2024-08-26T10:36:17.6195862Z The above exception was the direct cause of the following exception:
2024-08-26T10:36:17.6195946Z
2024-08-26T10:36:17.6202527Z Traceback (most recent call last):
2024-08-26T10:36:17.6203246Z File "/usr/local/lib/python3.9/dist-packages/urllib3/connectionpool.py", line 793, in urlopen
2024-08-26T10:36:17.6203570Z response = self._make_request(
2024-08-26T10:36:17.6203999Z File "/usr/local/lib/python3.9/dist-packages/urllib3/connectionpool.py", line 491, in _make_request
2024-08-26T10:36:17.6204267Z raise new_e
2024-08-26T10:36:17.6204663Z File "/usr/local/lib/python3.9/dist-packages/urllib3/connectionpool.py", line 467, in _make_request
2024-08-26T10:36:17.6205002Z self._validate_conn(conn)
2024-08-26T10:36:17.6205462Z File "/usr/local/lib/python3.9/dist-packages/urllib3/connectionpool.py", line 1099, in _validate_conn
2024-08-26T10:36:17.6205718Z conn.connect()
2024-08-26T10:36:17.6206148Z File "/usr/local/lib/python3.9/dist-packages/urllib3/connection.py", line 616, in connect
2024-08-26T10:36:17.6206429Z self.sock = sock = self._new_conn()
2024-08-26T10:36:17.6206794Z File "/usr/local/lib/python3.9/dist-packages/urllib3/connection.py", line 213, in _new_conn
2024-08-26T10:36:17.6206944Z raise NewConnectionError(
2024-08-26T10:36:17.6207159Z urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0x7fe9cc910f10>: Failed to establish a new connection: [Errno 111] Connection refused
2024-08-26T10:36:17.6207299Z
2024-08-26T10:36:17.6207423Z The above exception was the direct cause of the following exception:
2024-08-26T10:36:17.6207489Z
2024-08-26T10:36:17.6207579Z Traceback (most recent call last):
2024-08-26T10:36:17.6207800Z File "/usr/local/lib/python3.9/dist-packages/requests/adapters.py", line 486, in send
2024-08-26T10:36:17.6207921Z resp = conn.urlopen(
2024-08-26T10:36:17.6208108Z File "/usr/local/lib/python3.9/dist-packages/urllib3/connectionpool.py", line 847, in urlopen
2024-08-26T10:36:17.6208231Z retries = retries.increment(
2024-08-26T10:36:17.6208425Z File "/usr/local/lib/python3.9/dist-packages/urllib3/util/retry.py", line 515, in increment
2024-08-26T10:36:17.6208627Z raise MaxRetryError(_pool, url, reason) from reason # type: ignore[arg-type]
2024-08-26T10:36:17.6209034Z urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='127.0.0.1', port=22376): Max retries exceeded with url: /version (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fe9cc910f10>: Failed to establish a new connection: [Errno 111] Connection refused'))
2024-08-26T10:36:17.6209211Z
2024-08-26T10:36:17.6209356Z During handling of the above exception, another exception occurred:
2024-08-26T10:36:17.6209466Z
2024-08-26T10:36:17.6209605Z Traceback (most recent call last):
2024-08-26T10:36:17.6209979Z File "/usr/local/lib/python3.9/dist-packages/docker/api/client.py", line 214, in _retrieve_server_version
2024-08-26T10:36:17.6210229Z return self.version(api_version=False)["ApiVersion"]
2024-08-26T10:36:17.6210533Z File "/usr/local/lib/python3.9/dist-packages/docker/api/daemon.py", line 181, in version
2024-08-26T10:36:17.6210672Z return self._result(self._get(url), json=True)
2024-08-26T10:36:17.6210866Z File "/usr/local/lib/python3.9/dist-packages/docker/utils/decorators.py", line 46, in inner
2024-08-26T10:36:17.6210994Z return f(self, *args, **kwargs)
2024-08-26T10:36:17.6211175Z File "/usr/local/lib/python3.9/dist-packages/docker/api/client.py", line 237, in _get
2024-08-26T10:36:17.6211304Z return self.get(url, **self._set_request_timeout(kwargs))
2024-08-26T10:36:17.6211509Z File "/usr/local/lib/python3.9/dist-packages/requests/sessions.py", line 602, in get
2024-08-26T10:36:17.6211630Z return self.request("GET", url, **kwargs)
2024-08-26T10:36:17.6211827Z File "/usr/local/lib/python3.9/dist-packages/requests/sessions.py", line 589, in request
2024-08-26T10:36:17.6211949Z resp = self.send(prep, **send_kwargs)
2024-08-26T10:36:17.6212146Z File "/usr/local/lib/python3.9/dist-packages/requests/sessions.py", line 703, in send
2024-08-26T10:36:17.6212263Z r = adapter.send(request, **kwargs)
2024-08-26T10:36:17.6212446Z File "/usr/local/lib/python3.9/dist-packages/requests/adapters.py", line 519, in send
2024-08-26T10:36:17.6212576Z raise ConnectionError(e, request=request)
2024-08-26T10:36:17.6212952Z requests.exceptions.ConnectionError: HTTPSConnectionPool(host='127.0.0.1', port=22376): Max retries exceeded with url: /version (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fe9cc910f10>: Failed to establish a new connection: [Errno 111] Connection refused'))
2024-08-26T10:36:17.6213161Z
2024-08-26T10:36:17.6213258Z During handling of the above exception, another exception occurred:
2024-08-26T10:36:17.6213316Z
2024-08-26T10:36:17.6213459Z Traceback (most recent call last):
2024-08-26T10:36:17.6213864Z File "/builder/torizoncore-builder", line 222, in <module>
2024-08-26T10:36:17.6214059Z mainargs.func(mainargs)
2024-08-26T10:36:17.6214251Z File "/builder/tcbuilder/cli/bundle.py", line 97, in do_bundle
2024-08-26T10:36:17.6214461Z bundle(bundle_dir=args.bundle_directory,
2024-08-26T10:36:17.6214617Z File "/builder/tcbuilder/cli/bundle.py", line 49, in bundle
2024-08-26T10:36:17.6214729Z bundle_be.download_containers_by_compose_file(
2024-08-26T10:36:17.6214864Z File "/builder/tcbuilder/backend/bundle.py", line 556, in download_containers_by_compose_file
2024-08-26T10:36:17.6214984Z dind_client = manager.get_client()
2024-08-26T10:36:17.6215102Z File "/builder/tcbuilder/backend/bundle.py", line 321, in get_client
2024-08-26T10:36:17.6215256Z dind_client = docker.DockerClient(base_url=self.docker_host, tls=tls_config)
2024-08-26T10:36:17.6215469Z File "/usr/local/lib/python3.9/dist-packages/docker/client.py", line 45, in __init__
2024-08-26T10:36:17.6215592Z self.api = APIClient(*args, **kwargs)
2024-08-26T10:36:17.6215779Z File "/usr/local/lib/python3.9/dist-packages/docker/api/client.py", line 197, in __init__
2024-08-26T10:36:17.6215916Z self._version = self._retrieve_server_version()
2024-08-26T10:36:17.6216123Z File "/usr/local/lib/python3.9/dist-packages/docker/api/client.py", line 221, in _retrieve_server_version
2024-08-26T10:36:17.6216251Z raise DockerException(
2024-08-26T10:36:17.6216661Z docker.errors.DockerException: Error while fetching server API version: HTTPSConnectionPool(host='127.0.0.1', port=22376): Max retries exceeded with url: /version (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fe9cc910f10>: Failed to establish a new connection: [Errno 111] Connection refused'))
The pipeline script looks like this:
shopt -s expand_aliases # enable aliasses
source tcb-env-setup.sh -a remote
eval $(alias torizoncore-builder | sed "s/-it /-i --privileged /") # remove interactive mode tag in alias add privileged mode
torizoncore-builder bundle --platform=linux/arm/v7 docker-compose.yml --bundle-directory bundle --dind-param="--privileged" --login-to docker.io * *
