While running a build, I got this error:
Starting DIND container
Using Docker host "tcp://127.0.0.1:22376"
Connecting to Docker Daemon at "tcp://127.0.0.1:22376"
Stopping DIND container
Removing output directory 'deploy' due to build errors
An unexpected Exception occured. Please provide the following stack trace to
the Toradex TorizonCore support team:
File "/usr/local/lib/python3.9/dist-packages/urllib3/connection.py", line 174, in _new_conn
conn = connection.create_connection(
File "/usr/local/lib/python3.9/dist-packages/urllib3/util/connection.py", line 95, in create_connection
raise err
File "/usr/local/lib/python3.9/dist-packages/urllib3/util/connection.py", line 85, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
During handling of the above exception, another exception occurred:
File "/usr/local/lib/python3.9/dist-packages/urllib3/connectionpool.py", line 703, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.9/dist-packages/urllib3/connectionpool.py", line 386, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.9/dist-packages/urllib3/connectionpool.py", line 1040, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.9/dist-packages/urllib3/connection.py", line 358, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.9/dist-packages/urllib3/connection.py", line 186, in _new_conn
raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0x7fccbada9220>: Failed to establish a new connection: [Errno 111] Connection refused
File "/usr/local/lib/python3.9/dist-packages/requests/adapters.py", line 440, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.9/dist-packages/urllib3/connectionpool.py", line 785, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.9/dist-packages/urllib3/util/retry.py", line 592, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='127.0.0.1', port=22376): Max retries exceeded with url: /version (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fccbada9220>: Failed to establish a new connection: [Errno 111] Connection refused'))
File "/usr/local/lib/python3.9/dist-packages/docker/api/client.py", line 214, in _retrieve_server_version
return self.version(api_version=False)["ApiVersion"]
File "/usr/local/lib/python3.9/dist-packages/docker/api/daemon.py", line 181, in version
return self._result(self._get(url), json=True)
File "/usr/local/lib/python3.9/dist-packages/docker/utils/decorators.py", line 46, in inner
return f(self, *args, **kwargs)
File "/usr/local/lib/python3.9/dist-packages/docker/api/client.py", line 237, in _get
return self.get(url, **self._set_request_timeout(kwargs))
File "/usr/local/lib/python3.9/dist-packages/requests/sessions.py", line 542, in get
return self.request('GET', url, **kwargs)
File "/usr/local/lib/python3.9/dist-packages/requests/sessions.py", line 529, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.9/dist-packages/requests/sessions.py", line 645, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.9/dist-packages/requests/adapters.py", line 519, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='127.0.0.1', port=22376): Max retries exceeded with url: /version (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fccbada9220>: Failed to establish a new connection: [Errno 111] Connection refused'))
File "/builder/torizoncore-builder", line 215, in <module>
mainargs.func(mainargs)
File "/builder/tcbuilder/cli/build.py", line 424, in do_build
build(args.config_fname, args.storage_directory,
File "/builder/tcbuilder/cli/build.py", line 410, in build
raise exc
File "/builder/tcbuilder/cli/build.py", line 399, in build
handle_output_section(
File "/builder/tcbuilder/cli/build.py", line 284, in handle_output_section
handle_bundle_output(
File "/builder/tcbuilder/cli/build.py", line 336, in handle_bundle_output
download_containers_by_compose_file(**download_params)
File "/builder/tcbuilder/backend/bundle.py", line 505, in download_containers_by_compose_file
dind_client = manager.get_client()
File "/builder/tcbuilder/backend/bundle.py", line 300, in get_client
dind_client = docker.DockerClient(base_url=self.docker_host, tls=tls_config)
File "/usr/local/lib/python3.9/dist-packages/docker/client.py", line 45, in __init__
self.api = APIClient(*args, **kwargs)
File "/usr/local/lib/python3.9/dist-packages/docker/api/client.py", line 197, in __init__
self._version = self._retrieve_server_version()
File "/usr/local/lib/python3.9/dist-packages/docker/api/client.py", line 221, in _retrieve_server_version
raise DockerException(
docker.errors.DockerException: Error while fetching server API version: HTTPSConnectionPool(host='127.0.0.1', port=22376): Max retries exceeded with url: /version (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fccbada9220>: Failed to establish a new connection: [Errno 111] Connection refused'))
