Hello Toradex team,
I hope you are all doing great!
Hardware:
Custom Carrier Board based on Verdin
uname:
- Linux verdin-imx8mp-XXXXXXX 5.15.148-6.8.0+git.8c5c2dcbf6ba #1-TorizonCore SMP PREEMPT Tue Aug 6 10:01:59 UTC 2024 aarch64 aarch64 aarch64 GNU/Linux
Images tested:
- torizon-core-docker-verdin-imx8mp-Tezi_6.8.4+build.40.tar (STABLE Release)
Guest OS:
macOS (M1 Pro ARM64)
Linux ubuntu (VM x86_64)
Issue:
I wanted to push the new update using the deploy command of torizoncore-builder. But it always timeout (see trace bellow).
I tried 2 differents ways:
- Directly connected to my Mac with an ethernet cable.
- Connecting the
verdinvia WiFi and doing the same command.
In both case it timeout after 90 seconds (?).
After further investigation, I can see that the code has changed recently:
Also interesting, the variable REMOTE_CMD_TIMEOUT = 30 but the error says: invoke.exceptions.CommandTimedOut: Command did not complete within 90 seconds!
I hope you will be able to help me find a solution quickly.
M
Trace:
$ torizoncore-builder deploy --remote-host 192.168.2.3 --remote-username torizon --remote-password 'password' --reboot
WARNING: Beware that artifacts not managed by OSTree (e.g. bootloader, container images, platform provisioning data, fuse values, U-Boot environment) will not be deployed by this operation.
Pulling OSTree with ref base (checksum d6eead88f5fd9965c75efe463d5d11b9ac7acd04818d6176efd069e51067edb1) from local archive repository...
Starting http server to serve OSTree.
OSTree server listening on "localhost:38707".
7da2d07a16cb9f4d1d1db46e21af494342baaf12d5932defbf4224b59f8d67c7
'verdin-imx8mp'
Starting OSTree pull on the device...
An unexpected Exception occurred. Please provide the following stack trace to
the Toradex TorizonCore support team:
Exception in thread Thread-548:
File "/usr/lib/python3.9/threading.py", line 954, in _bootstrap_inner
self.run()
File "/usr/lib/python3.9/threading.py", line 892, in run
self._target(*self._args, **self._kwargs)
File "/builder/tcbuilder/backend/rforward.py", line 53, in handler
chan.send(data)
File "/usr/lib/python3/dist-packages/paramiko/channel.py", line 801, in send
return self._send(s, m)
File "/usr/lib/python3/dist-packages/paramiko/channel.py", line 1198, in _send
raise socket.error("Socket is closed")
OSError: Socket is closed
Exception occurred during processing of request from ('127.0.0.1', 52084)
File "/builder/torizoncore-builder", line 232, in <module>
mainargs.func(mainargs)
File "/builder/tcbuilder/cli/deploy.py", line 234, in do_deploy
do_deploy_ostree_remote(args)
File "/builder/tcbuilder/cli/deploy.py", line 197, in do_deploy_ostree_remote
deploy_ostree_remote(storage_dir=args.storage_directory,
File "/builder/tcbuilder/cli/deploy.py", line 190, in deploy_ostree_remote
dbe.deploy_ostree_remote(remote_host, remote_username, remote_password,
File "/builder/tcbuilder/backend/deploy.py", line 560, in deploy_ostree_remote
run_command_with_sudo(
File "/builder/tcbuilder/backend/deploy.py", line 435, in run_command_with_sudo
result = ssh_connection.sudo(command, pty=True, hide=True, timeout=REMOTE_CMD_TIMEOUT)
File "/usr/local/lib/python3.9/dist-packages/decorator.py", line 235, in fun
return caller(func, *(extras + args), **kw)
File "/usr/local/lib/python3.9/dist-packages/fabric/connection.py", line 23, in opens
return method(self, *args, **kwargs)
File "/usr/local/lib/python3.9/dist-packages/fabric/connection.py", line 777, in sudo
return self._sudo(self._remote_runner(), command, **kwargs)
File "/usr/local/lib/python3.9/dist-packages/invoke/context.py", line 232, in _sudo
return runner.run(cmd_str, watchers=watchers, **kwargs)
File "/usr/local/lib/python3.9/dist-packages/fabric/runners.py", line 83, in run
return super().run(command, **kwargs)
File "/usr/local/lib/python3.9/dist-packages/invoke/runners.py", line 395, in run
return self._run_body(command, **kwargs)
File "/usr/local/lib/python3.9/dist-packages/invoke/runners.py", line 451, in _run_body
return self.make_promise() if self._asynchronous else self._finish()
File "/usr/local/lib/python3.9/dist-packages/invoke/runners.py", line 516, in _finish
raise CommandTimedOut(result, timeout=timeout)
Command: "sudo -S -p '[sudo] password: ' ostree pull tcbuilder:d6eead88f5fd9965c75efe463d5d11b9ac7acd04818d6176efd069e51067edb1"
Stdout:
[sudo] password:
Receiving objects: 26% (527/1960) 708.2 kB/s 63.0 MB
Stderr: n/a (PTYs have no stderr)
On the device:
Dec 16 09:57:56 verdin-imx8mp-XXXXXX systemd[1]: Started OpenSSH Per-Connection Daemon (192.168.129.138:58338).
Dec 16 09:57:56 verdin-imx8mp-XXXXXX sshd[2179]: Accepted password for torizon from 192.168.129.138 port 58338 ssh2
Dec 16 09:57:56 verdin-imx8mp-XXXXXX sshd[2179]: pam_unix(sshd:session): session opened for user torizon(uid=1000) by (uid=0)
Dec 16 09:57:56 verdin-imx8mp-XXXXXX systemd-logind[698]: New session c5 of user torizon.
Dec 16 09:57:56 verdin-imx8mp-XXXXXX systemd[1]: Started Session c5 of User torizon.
Dec 16 09:57:56 verdin-imx8mp-XXXXXX audit[2179]: SYSCALL arch=c00000b7 syscall=64 success=yes exit=4 a0=7 a1=ffffe7413220 a2=4 a3=ffffa2a58920 items=0 ppid=1 pid=2179 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=6 comm="sshd" exe="/usr/sbin/sshd" key=(null)
Dec 16 09:57:56 verdin-imx8mp-XXXXXX audit: PROCTITLE proctitle=737368643A20746F72697A6F6E205B707269765D
Dec 16 09:57:56 verdin-imx8mp-XXXXXX kernel: audit: type=1006 audit(1765875476.924:88): pid=2179 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=6 res=1
Dec 16 09:57:56 verdin-imx8mp-XXXXXX kernel: audit: type=1300 audit(1765875476.924:88): arch=c00000b7 syscall=64 success=yes exit=4 a0=7 a1=ffffe7413220 a2=4 a3=ffffa2a58920 items=0 ppid=1 pid=2179 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=6 comm="sshd" exe="/usr/sbin/sshd" key=(null)
Dec 16 09:57:56 verdin-imx8mp-XXXXXX kernel: audit: type=1327 audit(1765875476.924:88): proctitle=737368643A20746F72697A6F6E205B707269765D
Dec 16 09:57:57 verdin-imx8mp-XXXXXX sudo[2186]: torizon : TTY=pts/0 ; PWD=/var/rootdirs/home/torizon ; USER=root ; COMMAND=/usr/bin/ostree remote add --no-gpg-verify --force tcbuilder http://localhost:34667/
Dec 16 09:57:57 verdin-imx8mp-XXXXXX sudo[2189]: torizon : TTY=pts/0 ; PWD=/var/rootdirs/home/torizon ; USER=root ; COMMAND=/usr/bin/ostree pull tcbuilder:d6eead88f5fd9965c75efe463d5d11b9ac7acd04818d6176efd069e51067edb1
Dec 16 09:59:27 verdin-imx8mp-XXXXXX sshd[2179]: pam_unix(sshd:session): session closed for user torizon
Dec 16 09:59:27 verdin-imx8mp-XXXXXX systemd[1]: sshd@4-192.168.129.224:22-192.168.129.138:58338.service: Deactivated successfully.
Dec 16 09:59:27 verdin-imx8mp-XXXXXX systemd[1]: session-c5.scope: Deactivated successfully.
Dec 16 09:59:27 verdin-imx8mp-XXXXXX systemd-logind[698]: Removed session c5.
