I’m struggling to bundle the docker images to Torizin with torizoncore-builder bundle. I have the image (called gaia_m) at the local registry. The registry is serving HTTP not HTTPS. Now the bundle command seems not to be able to handle this.
When I’m trying to run the command I get this error:
rahiram@fioulci1:~/temppitest/gaia-torizon-deployment/compose_configs/m_box$
–host-workdir=$(pwd) --platform=linux/arm/v7 --file docker-compose.yml An unexpected
Exception occured. Please provide the
following stack trace to the Toradex
TorizonCore support team:Traceback (most recent call last):
File
“/usr/local/lib/python3.9/dist-packages/docker/api/client.py”,
line 268, in _raise_for_status
response.raise_for_status() File “/usr/local/lib/python3.9/dist-packages/requests/models.py”, line 943, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 500
Server Error: Internal Server Error
for url:
https://127.0.0.1:22376/v1.40/images/create?tag=latest&fromImage=172.23.224.52%3A5000%2Fgaia_m&platform=linux%2Farm%2Fv7During handling of the above
exception, another exception occurred:Traceback (most recent call last):
File “/builder/torizoncore-builder”,
line 172, in
mainargs.func(mainargs) File “/builder/tcbuilder/cli/bundle.py”,
line 22, in bundle_containers
dockerbundle.download_containers_by_compose_file(
File “/builder/dockerbundle.py”, line
281, in
image = dind_client.images.pull(image,
platform=platform) File
“/usr/local/lib/python3.9/dist-packages/docker/models/images.py”,
line 446, in pull
pull_log = self.client.api.pull( File
“/usr/local/lib/python3.9/dist-packages/docker/api/image.py”,
line 430, in pull
self._raise_for_status(response) File
line 270, in _raise_for_status
raise create_api_error_from_http_exception(e)
File
“/usr/local/lib/python3.9/dist-packages/docker/errors.py”,
line 31, in
raise cls(e, response=response, explanation=explanation)
docker.errors.APIError: 500 Server
Error for
https://127.0.0.1:22376/v1.40/images/create?tag=latest&fromImage=172.23.224.52%3A5000%2Fgaia_m&platform=linux%2Farm%2Fv7:
Internal Server Error (“Get
https://172.23.224.52:5000/v2/: http:
server gave HTTP response to HTTPS
client”)
However, I can make it run by changing the /builder/dockerbundle.py a bit. I do that by creating my own dockger image out of the torizon/torizoncore-builder:2 image. Like this:
FROM torizon/torizoncore-builder:2
RUN sed -i -e ‘s/dind_client = manager.get_client()/dind_client = docker.from_env()/’ /builder/dockerbundle.py
As you see, I just simply override your docker client definition with simple docker.from_env(). This creates the bundle without errors. However, I have not tested yet if it works properly on the target.
Would be great to have this working out of the box.
One more thing. Do you have the dockerfile for torizoncore-builder and contained python codes available as open source somewhere?
