Going back to build some test images, and torizoncore-builder no longer works. This setup worked great about 2 months ago.
Poking around here it looks like it’s possibly an error with our private registry, but I’ve confirmed that the username and password in tcbuild.yml are correct and that my native docker can login just fine.
Updating TorizonCore image in place.
Bundling images to directory bundle_20230202162053_097191.tmp
Starting DIND container
Stopping DIND container
Removing output directory 'displayTest' due to build errors
An unexpected Exception occured. Please provide the following stack trace to
the Toradex TorizonCore support team:
File "/usr/local/lib/python3.9/dist-packages/docker/api/client.py", line 268, in _raise_for_status
response.raise_for_status()
File "/usr/local/lib/python3.9/dist-packages/requests/models.py", line 1021, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 409 Client Error: Conflict for url: http+docker://localhost/v1.41/containers/create?name=tcb-fetch-dind
During handling of the above exception, another exception occurred:
File "/builder/tcbuilder/backend/bundle.py", line 510, in download_containers_by_compose_file
manager.start(network, default_platform=platform, dind_params=dind_params)
File "/builder/tcbuilder/backend/bundle.py", line 252, in start
self.dind_container = self.host_client.containers.run(
File "/usr/local/lib/python3.9/dist-packages/docker/models/containers.py", line 811, in run
container = self.create(image=image, command=command,
File "/usr/local/lib/python3.9/dist-packages/docker/models/containers.py", line 870, in create
resp = self.client.api.create_container(**create_kwargs)
File "/usr/local/lib/python3.9/dist-packages/docker/api/container.py", line 430, in create_container
return self.create_container_from_config(config, name)
File "/usr/local/lib/python3.9/dist-packages/docker/api/container.py", line 441, in create_container_from_config
return self._result(res, True)
File "/usr/local/lib/python3.9/dist-packages/docker/api/client.py", line 274, in _result
self._raise_for_status(response)
File "/usr/local/lib/python3.9/dist-packages/docker/api/client.py", line 270, in _raise_for_status
raise create_api_error_from_http_exception(e)
File "/usr/local/lib/python3.9/dist-packages/docker/errors.py", line 31, in create_api_error_from_http_exception
raise cls(e, response=response, explanation=explanation)
docker.errors.APIError: 409 Client Error for http+docker://localhost/v1.41/containers/create?name=tcb-fetch-dind: Conflict ("Conflict. The container name "/tcb-fetch-dind" is already in
use by container "39f41a7d2ec808a6832084c5af7ad22911e23ef5a826e251577b1db8cd654308". You have to remove (or rename) that container to be able to reuse that name.")
The above exception was the direct cause of the following exception:
File "/builder/tcbuilder/backend/bundle.py", line 550, in download_containers_by_compose_file
raise OperationFailureError(
tcbuilder.errors.OperationFailureError: Error: container images download failed: 409 Client Error for http+docker://localhost/v1.41/containers/create?name=tcb-fetch-dind: Conflict ("Conflict. The container name "/tcb-fetch-dind" is already in use by container "39f41a7d2ec808a6832084c5af7ad22911e23ef5a826e251577b1db8cd654308". You have to remove (or rename) that container to be able to reuse that name.")
requests.exceptions.HTTPError: 409 Client Error: Conflict for url: http+docker://localhost/v1.41/volumes/dind-volume
File "/builder/torizoncore-builder", line 217, in <module>
mainargs.func(mainargs)
File "/builder/tcbuilder/cli/build.py", line 471, in do_build
build(args.config_fname, args.storage_directory,
File "/builder/tcbuilder/cli/build.py", line 457, in build
raise exc
File "/builder/tcbuilder/cli/build.py", line 446, in build
handle_output_section(
File "/builder/tcbuilder/cli/build.py", line 302, in handle_output_section
handle_bundle_output(
File "/builder/tcbuilder/cli/build.py", line 356, in handle_bundle_output
download_containers_by_compose_file(**download_params)
File "/builder/tcbuilder/backend/bundle.py", line 555, in download_containers_by_compose_file
manager.stop()
File "/builder/tcbuilder/backend/bundle.py", line 286, in stop
self.dind_volume.remove()
File "/usr/local/lib/python3.9/dist-packages/docker/models/volumes.py", line 25, in remove
return self.client.api.remove_volume(self.id, force=force)
File "/usr/local/lib/python3.9/dist-packages/docker/api/volume.py", line 161, in remove_volume
self._raise_for_status(resp)
docker.errors.APIError: 409 Client Error for http+docker://localhost/v1.41/volumes/dind-volume: Conflict ("remove dind-volume: volume is in use - [39f41a7d2ec808a6832084c5af7ad22911e23ef5a826e251577b1db8cd654308]")
