I have an Apalis iMX6 with an Ixora dev board.
I want to change the functions of several pins. First I wanted to use GPIO1 9 and PWM as a GPIO pin and I did the following steps:
- On your (Linux) host machine, download the TorizonCore Builder setup script if you haven’t done so:
mkdir -p ~/tcbdir/ && cd ~/tcbdir/
wget https://raw.githubusercontent.com/toradex/tcb-env-setup/master/tcb-env-setup.sh
- Source the script to initialize TorizonCore Builder:
cd ~/tcbdir/
source tcb-env-setup.sh
- Inside
~/tcbdir
, clone Linux and the overlay repositories for TorizonCore 6:
git clone -b linux-6.0.y git://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git
git clone -b master git://git.toradex.com/device-tree-overlays.git device-trees
- Inside
~/tcbdir
create a directory namedimages
. Download TorizonCore 6.2 and put the .tar file in theimages
directory. - Inside
~/tcbdir
create a file namedapalis-imx6_enable_gpio1_2_overlay.dts
with the following content:
/dts-v1/;
/plugin/;
#include <arch/arm/boot/dts/imx6q-pinfunc.h>
compatible = "toradex,apalis_imx6q";
®_pcie_switch {
status = "disabled";
&pwm1 {
&iomuxc {
pinctrl-0 = <&pinctrl_apalis_gpio1 &pinctrl_apalis_gpio2
&pinctrl_apalis_gpio3 &pinctrl_apalis_gpio4
&pinctrl_apalis_gpio5 &pinctrl_apalis_gpio6
&pinctrl_apalis_gpio7 &pinctrl_apalis_gpio8
&pinctrl_apalis_gpio1_9
pinctrl_apalis_gpio1_9: apalisgpio1_9_grp {
fsl,pins = <
MX6QDL_PAD_GPIO_9__GPIO1_IO09 0x130b0
- Inside
~/tcbdir
create a file namedtcbuild.yaml
input:
easy-installer:
local: images/torizon-core-docker-apalis-imx6-Tezi_6.2.0+build.2.tar
customization:
device-tree:
include-dirs:
- linux/
overlays:
clear: false
add:
- apalis-imx6_enable_gpio1_2_overlay.dts
output:
easy-installer:
local: apalis_imx6_tc6.2_enable_gpio1_2
# >> Information used by Toradex Easy Installer:
name: "TorizonCore (UPSTREAM)"
description: "TorizonCore with GPIO1 pin 2 (MXM3 pin 15) enabled in Userspace"
Inside ~/tcbdir
run torizoncore-builder build
. It will generate a directory named apalis_imx6_tc6.2_enable_gpio1_2
. Copy this directory to a USB stick, plug it to your module then load the latest release of Toradex Easy Installer on your module
That worked and I was able to use the two pins as GPIO pins.
But now I have to also use PWM 2 and 3 as GPIOs so I tried adding the pins the following way in the dts file:
/dts-v1/;
/plugin/;
®_pcie_switch {
&pwm1 {
&pwm2 {
&pwm3 {
&iomuxc {
fsl,pins = <
pinctrl_apalis_gpio2_9: apalisgpio2_9_grp {
fsl,pins = <
MX6QDL_PAD_GPIO_9__GPIO2_IO09 0x130b0
pinctrl_apalis_gpio1_1: apalisgpio1_1_grp {
fsl,pins = <
MX6QDL_PAD_GPIO_1__GPIO1_IO01 0x130b0
With the same yaml file. But when I run torizoncore-builder build I get the following error:
Building image as per configuration file 'tcbuild.yaml'...
=>> Handling input section
Unpacking Toradex Easy Installer image.
An unexpected Exception occured. Please provide the following stack trace to
the Toradex TorizonCore support team:
File "/builder/torizoncore-builder", line 221, in <module>
mainargs.func(mainargs)
File "/builder/tcbuilder/cli/build.py", line 479, in do_build
build(args.config_fname, args.storage_directory,
File "/builder/tcbuilder/cli/build.py", line 446, in build
handle_input_section(config["input"], storage_dir=storage_dir)
File "/builder/tcbuilder/cli/build.py", line 98, in handle_input_section
handle_easy_installer_input(props["easy-installer"], **kwargs)
File "/builder/tcbuilder/cli/build.py", line 119, in handle_easy_installer_input
images_cli.images_unpack(
File "/builder/tcbuilder/cli/images.py", line 139, in images_unpack
images.import_local_image(image_dir, dir_list[0], dir_list[1], dir_list[2])
File "/builder/tcbuilder/backend/images.py", line 282, in import_local_image
subprocess.check_output(tarcmd, shell=True, stderr=subprocess.STDOUT)
File "/usr/lib/python3.9/subprocess.py", line 424, in check_output
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File "/usr/lib/python3.9/subprocess.py", line 528, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command 'cat /workdir/images/torizon-core-docker-apalis-imx6-Tezi_6.2.0+build.2.tar | cat | tar -xf - -C /storage/tezi.tmp' returned non-zero exit status 2.
How can this be fixed?
