- Verdin iMX8M Plus
- Dahlia rev1.1 carrier board
- Visual Studio Code version 1.63.2 (run as admin)
- Toradex Torizon Support extension v1.3.0
- Windows 11 2200.434
- Docker version 20.10.12
- WSL version 2 kernel version 5.10.16
- Connected to the board via SSH (wlan0)
- Using the unmodified Torizon Python 3 console application example, target platform set to arm64v8-debian-python3_bullseye
Full output is below but it looks like I have two issues at hand:
- I get a warning “The requested image’s platform (linux/arm64/v8) does not match the detected host platform (linux/amd64) and no specific platform was requested”
- Rsync error 127 (what does this mean?)
Any help is appreciated!
[00-20 12:07:20.468] Initializing Torizon Extension
[00-20 12:07:20.470] Checking system setup...
[00-20 12:07:21.983] Checking Moses ...
[00-20 12:07:21.983] Starting backend local instance running on port 5000
[00-20 12:07:29.132] Torizon Backend version 1.0 API version: 1.0
[00-20 12:07:29.133] Torizon IDE backend started
[00-20 12:07:29.133] Checking Docker ...
[00-20 12:07:29.163] Docker version 20.10.12 build 459d0df
[00-20 12:07:29.366] Trying connect to Toradex Verdin iMX8M Plus WB on Verdin Development Board(06965639)
[00-20 12:07:30.245] ARM emulation enabled.
[00-20 12:07:30.526] Active configuration has been selected 23804943-d425-40ed-938c-3909bfccf7f0, updating it.
[00-20 12:07:30.528] Initializing Torizon Python application.
[00-20 12:07:30.585] Torizon: Python 3 arm64v8 bullseye - test - 23804943-d425-40ed-938c-3909bfccf7f0
[00-20 12:07:30.596] LA_OPT_NXP_Software_License v5 January 2019 EULA accepted
[00-20 12:08:35.824] Trying connect to Toradex Verdin iMX8M Plus WB on Verdin Development Board(06965639)
[00-20 12:09:15.372] Toradex Verdin iMX8M Plus WB on Verdin Development Board(06965639) connected
[00-20 12:09:15.451] Toradex Verdin iMX8M Plus WB on Verdin Development Board(06965639) connected
[00-20 12:09:15.452] Torizon: all devices refreshed
[00-20 12:09:45.612] Preparing debug environment for Python application...
[00-20 12:09:45.612] No preLaunchTask configured.
[00-20 12:09:45.613] Selecting device...
[00-20 12:09:45.617] Device 06965639 selected.
[00-20 12:09:45.617] Updating app configuration...
[00-20 12:09:45.666] Image is not up to date, building it (this may take some time)...
[00-20 12:09:45.994] Step 1/16 : FROM --platform=linux/arm64 torizon/debian:2-bullseye
[00-20 12:09:46.395] ---> 09f59e511484
[00-20 12:09:46.399] Step 2/16 : EXPOSE 6502
[00-20 12:09:46.400] ---> Using cache
[00-20 12:09:46.400] ---> d13d57318ed1
[00-20 12:09:46.400] Step 3/16 : ARG SSHUSERNAME=torizon
[00-20 12:09:46.401] ---> Using cache
[00-20 12:09:46.401] ---> 3a37a471a55c
[00-20 12:09:46.401] Step 4/16 : ENV DEBIAN_FRONTEND="noninteractive"
[00-20 12:09:46.402] ---> Using cache
[00-20 12:09:46.403] ---> 3f8041464702
[00-20 12:09:46.404] Step 5/16 : RUN apt-get update && apt-get install -y --no-install-recommends dos2unix python3-minimal python3-pip python3-setuptools && rm -rf /var/lib/apt/lists/*
[00-20 12:09:46.404] ---> Using cache
[00-20 12:09:46.405] ---> 0a94b77f6cd7
[00-20 12:09:46.405] Step 6/16 : RUN pip3 install --upgrade pip
[00-20 12:09:46.405] ---> Using cache
[00-20 12:09:46.406] ---> bc1b45fd2910
[00-20 12:09:46.406] Step 7/16 : RUN pip3 install debugpy
[00-20 12:09:46.407] ---> Using cache
[00-20 12:09:46.408] ---> 3ef21eb3728e
[00-20 12:09:46.408] Step 8/16 : RUN if [ ! -z "" ]; then apt-get -q -y update && apt-get -q -y install && rm -rf /var/lib/apt/lists/* ; fi
[00-20 12:09:46.428] ---> [Warning] The requested image's platform (linux/arm64/v8) does not match the detected host platform (linux/amd64) and no specific platform was requested
[00-20 12:09:46.431] ---> Running in 4de812f5a2ab
[00-20 12:09:47.230] ---> b22f28d5ff1f
[00-20 12:09:47.234] Step 9/16 : COPY work/setup.sh /setup.sh
[00-20 12:09:47.359] ---> b85e849240b9
[00-20 12:09:47.362] Step 10/16 : COPY work/cleanup.sh /cleanup.sh
[00-20 12:09:47.478] ---> d82969c92fb3
[00-20 12:09:47.481] Step 11/16 : COPY work/requirements.txt /requirements.txt
[00-20 12:09:47.580] ---> 36daacbbd00d
[00-20 12:09:47.583] Step 12/16 : WORKDIR /
[00-20 12:09:47.606] ---> [Warning] The requested image's platform (linux/arm64/v8) does not match the detected host platform (linux/amd64) and no specific platform was requested
[00-20 12:09:47.609] ---> Running in a8ba8030d9fc
[00-20 12:09:47.669] ---> b17ec0407a7c
[00-20 12:09:47.674] Step 13/16 : RUN dos2unix /requirements.txt && dos2unix /setup.sh && dos2unix /cleanup.sh && chmod a+x /setup.sh && chmod a+x /cleanup.sh && /setup.sh debug && pip install -r /requirements.txt && /cleanup.sh debug
[00-20 12:09:47.709] ---> [Warning] The requested image's platform (linux/arm64/v8) does not match the detected host platform (linux/amd64) and no specific platform was requested
[00-20 12:09:47.712] ---> Running in 6b08e88b0b5b
[00-20 12:09:48.136] e[91mdos2unix: e[0m
[00-20 12:09:48.140] e[91mconverting file /requirements.txt to Unix format...
e[0m
[00-20 12:09:48.165] e[91mdos2unix: e[0m
[00-20 12:09:48.170] e[91mconverting file /setup.sh to Unix format...
e[0m
[00-20 12:09:48.195] e[91mdos2unix: e[0m
[00-20 12:09:48.199] e[91mconverting file /cleanup.sh to Unix format...
e[0m
[00-20 12:09:48.287] This is a debug build
[00-20 12:09:49.723] e[91mWARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
e[0m
[00-20 12:09:49.873] This is a debug build
[00-20 12:09:50.266] ---> 77fbbac2b0f2
[00-20 12:09:50.270] Step 14/16 : RUN echo "#!/bin/sh" > /startptvsd && echo "cd /test" >> /startptvsd && echo "echo \"running test\"" >> /startptvsd && echo "/usr/bin/python3 -m debugpy --listen 0.0.0.0:6502 --wait-for-client main.py " >> /startptvsd && chmod a+x /startptvsd
[00-20 12:09:50.296] ---> [Warning] The requested image's platform (linux/arm64/v8) does not match the detected host platform (linux/amd64) and no specific platform was requested
[00-20 12:09:50.299] ---> Running in 1275fb83cc9e
[00-20 12:09:51.130] ---> 48e8de177f3b
[00-20 12:09:51.134] Step 15/16 : USER torizon
[00-20 12:09:51.159] ---> [Warning] The requested image's platform (linux/arm64/v8) does not match the detected host platform (linux/amd64) and no specific platform was requested
[00-20 12:09:51.164] ---> Running in aa34ed2800e6
[00-20 12:09:51.224] ---> 12c23ef88af4
[00-20 12:09:51.226] Step 16/16 : CMD /startptvsd
[00-20 12:09:51.250] ---> [Warning] The requested image's platform (linux/arm64/v8) does not match the detected host platform (linux/amd64) and no specific platform was requested
[00-20 12:09:51.253] ---> Running in 842afdf58ee4
[00-20 12:09:51.308] ---> 972bd5331725
[00-20 12:09:51.310] Successfully built 972bd5331725
[00-20 12:09:51.315] Successfully tagged test_arm64v8-debian-python3_bullseye_debug_23804943-d425-40ed-938c-3909bfccf7f0:latest
[00-20 12:09:51.375] Deploying image to device (may take a few minutes)...
[00-20 12:09:51.594] Image not found on target device.
[00-20 12:09:51.594] Exporting local image.
[00-20 12:09:53.765] Image exported, deploying to the target.
[00-20 12:11:12.816] Loading layer - e6712d2ce998
[00-20 12:11:12.946] Loading layer - e6712d2ce998
[00-20 12:11:12.993] Loading layer - d5e0ab35c28e
[00-20 12:11:13.038] Loading layer - d5e0ab35c28e
[00-20 12:11:13.185] Loading layer - 99c32cfebcb3
[00-20 12:11:13.235] Loading layer - 99c32cfebcb3
[00-20 12:11:13.368] Loading layer - 634402ff7a02
[00-20 12:11:13.458] Loading layer - 634402ff7a02
[00-20 12:11:13.537] Loading layer - 8c44b5463896
[00-20 12:11:13.579] Loading layer - 8c44b5463896
[00-20 12:11:13.733] Loaded image ID: sha256:972bd53317254e8c7c9475868b1a7f0361f73f2a17ca59fa9fe0c5b2a58524b8
[00-20 12:11:13.912] Deploying application to device...
[00-20 12:11:14.167] Image deployed.
[00-20 12:11:14.252] Rsync cmd: wsl rsync -r --copy-unsafe-links -p -g -o -t -q --delete --exclude-from=/mnt/host/c/Users/jpwri/Documents/test/.rsync-exclude-list /mnt/host/c/Users/jpwri/Documents/test/ /mnt/host/c/Users/jpwri/Documents/test/appconfig_0/work/test/
[00-20 12:11:14.252] Rsync error: 127
[00-20 12:11:14.252] Rsync error 127
