I have HDMI display with resolution 800x600
Torizon set resolution much higher
To change resolution I follow
then
I run weston-terminal
apt update && apt install libdrm-tests
then
modetest -M imx-drm
I find there
Encoders:
id crtcs type
53 34 TMDS
55 41 none
Connectors:
id encoder name
54 53 HDMI-A-1
CRTCs:
id FB pos size
34 57 0,0 1280x720
41 60 0,0 800x480
To draw a Testpattern I need connector_id, crtc_id, mode. Where to get it?
By instruction I run
I try systemctl stop weston - weston service could not be found
If I run this not from container, but from ssh then
sudo systemctl stop weston
Failed to stop weston.service:
Unit weston.service not loaded.
Then from weston-terminal
modetest -M imx-drm -s 54@41:800x600-60.32
failed to set mode: permission denied
How to test and set resolution?
Greetings @Juzujka,
The recommended way to set a persistent resolution would be to provide the details in the weston.ini file as described here: Display Output, Resolution and Timings (Linux) | Toradex Developer Center
By default we provide an initial weston.ini in our weston containers as shown here: debian-docker-images/weston at buster · toradex/debian-docker-images · GitHub
You can replace this weston.ini at runtime with either a bindmount to overwrite it or rebuild the container with your weston.ini instead.
As for the modetest how did you start the weston container? Perhaps try adding the --privileged flag to the run command. This should resolve any permission issues.
I try Display Output, Resolution and Timings (Linux) | Toradex Developer Center before. But
!$ ls /etc/xdg/
systemd
there is no weston directory. Should I create directory and file weston.ini ? Or where can I find /etc/xdg/weston/ ?
A container’s file system is separate from the host system’s filesystem. You want to look in the container’s filesystem since that is where the entire weston stack is hosted. You must be looking in the host system’s filesystem which won’t have the weston.ini file.
I try with --privileged
on desktop:
ssh torizon@alapis-on-ixora
in ssh:
docker run --privileged -it --name test_display_w -v /var/run/dbus:/var/run/dbus -v /dev:/dev torizon/weston:2 bash
in the new container:
## apt update && apt install libdrm-tests
## modetest -M imx-drm
Encoders:
id crtc type possible crtcs possible clones
53 34 TMDS 0x0000000f 0x00000000
55 41 none 0x00000002 0xffffffff
Connectors:
id encoder status name size (mm) modes encoders
54 53 connected HDMI-A-1 220x140 9 53
modes:
index name refresh (Hz) hdisp hss hse htot vdisp vss vse vtot)
#0 1280x800 59.81 1280 1352 1480 1680 800 803 809 831 83500 flags: phsync, pvsync; type: preferred, driver
#4 800x600 60.32 800 840 968 1056 600 601 605 628 40000 flags: phsync, pvsync; type: driver
## apt-get install systemctl
## systemctl stop weston
ERROR:systemctl:Unit weston.service could not be found.
## modetest -M imx-drm -s 54@41:800x600-60.32
setting mode 800x600-60.32Hz on connectors 54, crtc 41
failed to set mode: Permission denied
about systemctl stop weston
in the
$ ssh torizon@alapis-on-ixora
run
## sudo systemctl stop weston
Failed to stop weston.service: Unit weston.service not loaded.
Hello, Jeremias
I have check the filesystem on the host:
$ du -a /etc/xdg/
0 /etc/xdg/systemd/user
4 /etc/xdg/systemd
8 /etc/xdg/
The weston.ini file is in the container filesystem not on the host filesystem. You want to copy your weston.ini file onto host with your changes for HDMI. Then when you run the weston container have a bindmount like so -v <path to your weston.ini on host>:/etc/xdg/weston/weston.ini. The method can be seen on this post here: How to rotate weston in torizon core - Technical Support - Toradex Community
If forcing the resolution doesn’t work via the weston.ini then perhaps the only reasonable way to force another resolution would be to inject an EDID binary. As described here: Display Output, Resolution and Timings (Linux) | Toradex Developer Center
It seems this method won’t work in the container. Please try the weston.ini method I detailed in my other comment.
I have started with running torizon_portainer_1. Others were stopped. No signal on the monitor after stopping the torizon_weston_1 container from the raw Torizon.
I follow Qt on Torizon OS | Toradex Developer Center and add your recommendation to bindmount -v <path to your weston.ini on host>:/etc/xdg/weston/weston.ini.
It was very useful to add “-it” (or use docker logs weston)
docker run -it --rm --name=weston --net=host --cap-add CAP_SYS_TTY_CONFIG -v /dev:/dev -v /tmp:/tmp -v /run/udev/:/run/udev/ -v /home/torizon/weston.ini:/etc/xdg/weston-dev/weston.ini --device-cgroup-rule='c 4:* rmw' --device-cgroup-rule='c 13:* rmw' --device-cgroup-rule='c 199:* rmw' --device-cgroup-rule='c 226:* rmw' torizon/weston:$CT_TAG_WESTON --developer weston-launch --tty=/dev/tty7 --user=torizon
Log appears in the terminal, it says
Using config file
‘/etc/xdg/weston-dev//weston.ini’
I have bindmount to ‘/etc/xdg/weston-dev//weston.ini’
docker run --rm --name=weston --net=host --cap-add CAP_SYS_TTY_CONFIG -v /dev:/dev -v /tmp:/tmp -v /run/udev/:/run/udev/ -v /home/torizon/weston.ini:/etc/xdg/weston-dev/weston.ini --device-cgroup-rule=‘c 4:* rmw’ --device-cgroup-rule=‘c 13:* rmw’ --device-cgroup-rule=‘c 199:* rmw’ --device-cgroup-rule=‘c 226:* rmw’ torizon/weston:$CT_TAG_WESTON --developer weston-launch --tty=/dev/tty7 --user=torizon
Image changes.
Now I need to understand when weston look into /etc/xdg/weston-dev/weston.ini and when into /etc/xdg/weston/weston.ini ?
The weston.ini path that is used depends on whether the --developer flag is passed during docker run. For example in the command you used you have torizon/weston:$CT_TAG_WESTON --developer. So the /etc/xdg/weston-dev/weston.ini path was used.
