Torizon: Running a python program from another container
Hi team,
This is more of a Docker related question than nothing else, but it might be useful for someone else.
I’m working on a PoC with Torizon, that uses several containers. I’m using Flask for a simple website in one container, and a Python program and influxdb to get some sensors data on another one (I’ll probably change to Grafana at the end but since I want to add some bidirectional logic between the website and the python program, I don’t think Grafana would work for that)
Now I would like to have another Python program / container that controls the GPIO using gpiod.
Dockerfile:
ARG IMAGE_ARCH=arm64v8
# For Apalis iMX8 use IMAGE_ARCH=arm64v8
FROM torizon/$IMAGE_ARCH-debian-base:buster
RUN apt-get update \
    && apt-get install -y --no-install-recommends python3 \
    python3-setuptools \
    python3-pip \
    && apt-get clean && apt-get autoremove && rm -rf /var/lib/apt/lists/*
RUN apt-get update && apt-get install -y procps
RUN python3 -m pip install -U --user pip gpiod
COPY gpio-python.py /usr/bin
gpio-python.py simply uses gpiod to interact with the GPIOs. Nothing too fancy, but works.
# docker build -t gpio-python .
# docker run --rm -it --device /dev/gpiochip0 gpio-python /bin/bash
## python3 /usr/bin/gpio-python.py
I managed to make the script work individually, by launching the container and then the script inside it. A simply while True with a blinking logic, just to test this works on gpiochip0 (on the PoC one would pass the pin).
Now, I want to have a button in my Flask website that would make a call to this python script which is another container… but I have no idea on how to do route this or make this call.
Since this is a PoC, in the worst case scenario, the gpiod program and Flask could be in the same container, but I wanted to check if there was some other way that won’t involve any networking forwarding or something of the sort (like using influxdb for this as well and have the python script continuously checking for this… Doesn’t sound ideal).
Any ideas?
Thanks! Alvaro.
You have many solutions for this problem:
  1. Convert your gpio app to a REST
    server and make it communicate via
    REST API. This will require more
    effort, but would probably be the
    best approach in a real-world
    application (where the component
    will do more than GPIO toggling),
    keeping the different components
    separated and connected with clearly
    defined interfaces. This will allow
    you to update the different parts
    independently, as long as the
    “contract” defined by the REST API
    is not broken
  2. Share the docker
    socket /var/run/docker.sock inside
    the container and used docker API
    for python to run containers/apps
    inside containers. You need to
    ensure that the user running the
    flask app has the right to access
    docker socket (must be root or part
    of docker group, with GID=990). This
    is what some tools like portainer
    do.
  3. Share docker socket, install
    docker cli in the container, and run
    it from your app. This may be
    simpler for testing/demos, but using
    the API provides more control over
    errors and parameters. Main
    advantage would be that you could
    easily test from command line. Of
    course you can mix with previous
    option, using API from your app but
    also having a command line ready to
    do quick tests.
  4. Enable docker TCP
    interface and use it to access
    docker from running containers. This
    is technically doable but I would
    not suggest using it because the
    interface will be non-secure by
    default and, even if you enable
    HTTPs and certificates, will be
    exposed to the outside and may
    become a security concern. Sharing
    local socket will limit
    accessibility to local machine and
    allows you to perform the same
    operations.
  5. As you suggested, move
    both apps to the same container,
    maybe converting the gpio one to a
    python module. This may be more
    efficient from a resource usage
    point of view, but will force a
    tight integration that may not be
    too bad for a simple demo but may
    become an issue on productions
    systems where you have multiple
    components interacting (an “engine”
    controlling the HW, like your gpio
    sample, a web frontend and maybe
    also a local GUI) and you may not
    want to update all of them at the
    same time or having to manage
    intertwined dependencies.
Thanks @valter.tx! For the RESTful API should I use Flask again in my GPIO app or is any other better approach?
It will, of course, depend on the language.
Flask is a very good solution for simple APIs in Python.
If you want to define an API that can be easily accessed from different languages my suggestion is to use Swagger/OpenAPI. This will allow you to define your API using a yaml file and then generate servers/clients for the most popular development languages/frameworks.
In Python you may use connexion to load the swagger API definition and it will implement the “glue” logic between HTTP server and your code in a very easy way.
