Torizon OS: Qt6 + touchscreen event
I working with a Carrier board Mallow + imx8mp verdin module. I have a Riverdi touchscreen of 12’’ connected to it. I want to interact with a QT application with the touch of the touchscreen.
I have problem to get the touch working with qt6 application. I cannot interact with the application with the touch, but with the mouse is working.
But I can see the touches event in the container with evtest. If I put the application in “Windowed” mode, I can move the application with the touch but I cannot interact with it
I did a test with torizon/chromium:3 and the touch works well.
Do you have any idea what I am missing to interact with my Qt application with the touch ?
I use Torizon 6.7.0 with the Linux toradex_5.15-2.2.x-imx as a baseline for the device tree.
For qt6, I created a container from the visual studio template c++/Qt 6. I have juste added some button using the “onClicked” events on Qt .
I have attached, the tcbuild, dockerfile, docker-compose and device tree that I use.
Dockerfile (4.8 KB)
Riverdi_12_inch_touch2.dtbo (2.6 KB)
docker-compose.yml (1.5 KB)
tcbuild.yaml (1.5 KB)
David
Software summary
Bootloader: U-Boot
Kernel version: 5.15.148-6.7.0+git.bfdbfb2c85fb #1-TorizonCore SMP PREEMPT Thu Jun 20 15:59:41 UTC 2024
Kernel command line: root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/a7d627eeb9c81a3b5c1b67800af2d176d70d20b5a3fd39d65304992d9ce19eef/0
Distro name: NAME=“TorizonCore”
Distro version: VERSION_ID=6.7.0-build.18
Distro variant: VARIANT=“Docker”
Hostname: verdin-imx8mp-15336641
Hardware info
HW model: Toradex Verdin iMX8M Plus WB on Mallow Board
Toradex version: 0064 V1.1A
Serial number: 15336641
Processor arch: aarch64
Hello!
It sounds like you’re encountering an issue where touch events are detected by the system but not by your Qt6 application. Let’s go through some steps to address this:
  1. Verify Touch Calibration: Use the weston-touch-calibrator to ensure your touch input is correctly calibrated. For the Verdin iMX8M Plus, you can run the following command:
    docker run -ti --rm --privileged -v /dev:/dev -v /run/udev/:/run/udev/ -v /etc/udev/rules.d:/etc/udev/rules.d torizon/weston-touch-calibrator:$CT_TAG_WESTON_TOUCH_CALIBRATOR
    This will help align the touch input with the display.
  2. Check Calibration Matrix: After calibration, confirm that the calibration matrix is applied by running:
    udevadm info /dev/input/event1
  3. Ensure Proper Permissions: Since your Qt6 application works with mouse input but not touch, ensure your Qt container has the necessary device permissions and mounts. The Weston container requires these permissions:
    --cap-add CAP_SYS_TTY_CONFIG \
    -v /dev:/dev -v /tmp:/tmp -v /run/udev/:/run/udev/ \
    --device-cgroup-rule="c 4:* rmw" --device-cgroup-rule="c 253:* rmw"
    Make sure these permissions are also applied to your Qt6 container. You may need to modify your docker-compose.yml to include these settings.
Since touch events work in Chromium, it indicates that the system captures them correctly, but there might be a configuration issue specific to your Qt6 container.
I hope this helps resolve the issue!
https://developer.toradex.com/torizon/application-development/use-cases/multimedia/touch-screen-calibration-torizon/#advanced-background
https://developer.toradex.com/torizon/application-development/use-cases/multimedia/setting-up-displays-with-torizon/#configure-toradex-displays.
Hello @davidcosta,
Can you send me the list of events that you get with the evtest container?
I think you may be missing some important events.
Another point which may be relevant is the event handling on Qt.
I am not sure if onClicked applies for touch events, so I recommend checking the Qt documentation on that.
Bruno
thanks for your answer, after a lot of testing. I could get it working.
I migrated from torizon OS 6.7.0. to 7.1.0. I have also changed the weston version from weston-vivante:3.4.0 to weston-imx8:4.4
I know it works. I don’t know where was the issue exactly, torizon OS or weston version.
Otherwise, the logs from the evtest I had:
Event: time 1651168772.855201, -------------- SYN_REPORT ------------
Event: time 1651168772.908712, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value 2368
Event: time 1651168772.908712, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 1156
Event: time 1651168772.908712, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 305
Event: time 1651168772.908712, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1651168772.908712, type 3 (EV_ABS), code 0 (ABS_X), value 1156
Event: time 1651168772.908712, type 3 (EV_ABS), code 1 (ABS_Y), value 305
Event: time 1651168772.908712, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 10
Hello @davidcosta,
Thanks for the update.
It is good to know that you were able to get this resolved.
Bruno
