We are pleased to announce the Torizon OS 7.2.0 quarterly release for Toradex’s System on Modules.
Torizon OS is our operating system that powers Torizon, a DevOps platform that simplifies the development and maintenance of embedded Linux software. Torizon OS is designed to be used out-of-the-box on devices requiring high reliability, allowing you to focus on your application instead of building and maintaining an operating system.
Torizon uses software containers, making it simple to add functionality to your system in a way that is both secure and easy to maintain. Torizon supports hardware acceleration in containers and graphical user interfaces.
Updates and Highlights
Torizon OS
Device drivers included as a module:
Improved Secure Boot and Fuse Management
- Add support for pushing fuse-type packages to Torizon Cloud on TorizonCore Builder, enabling in-field secure boot provisioning.
- Adapt the U-Boot command whitelisting configuration to allow fusing at scale
- Together, these features simplify migration to secure boot-enabled devices.
Bug Fixes:
- Fix the Auto-provisioning reliability to power-cuts
- Fix Aquila AM69 not booting due to ‘Error: “bootcmd_mmc0” not defined’
- Fix Access Point not working on Aquila AM69
- Fix Verdin AM62 Torizon OS rollback failing
- Fix U-Boot self-overwrite protection is not working on some machines (secure boot-enabled images only)
Updates from BSP 7.2.0:
- Please also note that Torizon OS is built on top of the Toradex BSP Layers for the Yocto Project. Read the BSP Layers and Reference Images for Yocto Project release news to learn more.
Debian Packages and Containers
- Debian Containers for Torizon:
- Rebuild all containers against the Debian 12.10 point release
- Minor fixes
Hardware Support
A quarterly release is a production release, intended to be used in a production environment only with volume products, as long as they are supported by Torizon OS. We run a set of tests to validate them. Learn more about our release types from our Embedded Linux Support Strategy.
- Volume products: Verdin AM62,Verdin iMX8M Plus, Verdin iMX8M Mini, Apalis iMX6, Apalis iMX8, Colibri iMX6ULL 1GB, Colibri iMX6DL, and Colibri iMX7D 1GB, and Colibri iMX8X
This release is intended to be used in production on these modules. - Sample products: Aquila AM69
Due to the hardware status being “sample”, this release is intended for evaluation and development.
Have questions or feedback? We value your insights! Join the discussion on our community forum to connect with other developers and share your thoughts on Torizon OS 7.2.0.
For more details click here: Torizon OS 7.2.0 Quarterly Release
