We are pleased to announce the Torizon OS 6.6.1 quarterly release for Toradex’s System on Modules.
Torizon OS is our operating system that powers Torizon, a DevOps platform that simplifies the development and maintenance of embedded Linux software. Torizon OS is designed to be used out-of-the-box on devices requiring high reliability, allowing you to focus on your application instead of building and maintaining an operating system.
Torizon uses software containers, making it simple to add functionality to your system in a way that is both secure and easy to maintain. Torizon supports hardware acceleration in containers and graphical user interfaces.
This release includes all updates from the previous 6.x.y Torizon OS releases.
Updates and Highlights
Torizon OS
- Torizon OS with Evaluation Containers:
- Portainer was replaced with a Torizon Cloud provisioning app, Easy Pairing, to simplify the evaluation and allow users to test various demo applications.
- Secure boot:
- Implement composefs support for the images built with Extended Chain of Trust support and Ensure OTA updates work when composefs is enabled.
- Make /etc transient on Secure Boot images.
- Run Torizon Images on Emulators:
- Allow customers to run Torizon qemuarm64 and genericx86-64 images with QEMU.
- Torizon is Open-Source:
- Open development of meta-toradex-torizon (issues, pull requests, discussions) was moved to torizon/meta-toradex-torizon on GitHub.
- Device drivers included as a module:
- Important bug fixes:
- Updates from BSP 6.6.0:
- Please also note that Torizon OS is built on top of the Toradex BSP Layers for the Yocto Project. Read the BSP Layers and Reference Images for Yocto Project release news to learn more.
Debian Packages and Containers
- Debian Containers for Torizon:
- Containers rebuilt against the Debian 12.5 point release.
- Debian packages:
- VPU acceleration:
Intended Use
The Torizon OS 6.6.1 Quarterly Release is a production-grade release.
Therefore, if you are in production with TorizonCore 5 or earlier Torizon OS 6 releases, we recommend moving to this quarterly release. Read the details on our Torizon OS Upgrade Notes.
Hardware Support
A quarterly release is a production release, intended to be used in a production environment only with volume products, as long as they are supported by Torizon OS . We run a set of tests to validate them. Learn more about our release types from our Embedded Linux Support Strategy.
- Volume products: Verdin iMX8M Plus, Verdin iMX8M Mini, Apalis iMX6, Apalis iMX8, Colibri iMX6ULL 1GB, Colibri iMX6DL, Colibri iMX7D 1GB, and Colibri iMX8
This release is intended to be used in production on these modules. - Sample products: Verdin AM62
Due to the hardware status being “sample”, this release is intended for development.
For Verdin, only the second generation of Verdin products is supported.
For more details click here: Torizon OS 6.6.1 Quarterly Release
