Installed minimal BSP Reference Image 5.6.0+build.18. No boot on my PCB:
ÿ-Boot SPL 2020.07-5.6.0+git.266eb389dd1d (Feb 14 2022 - 17:14:43 +0000)
Our Debian image for the iMX7D-1G is just the kernel cloned from your Toradex repository as noted above.
The Aster boot:
Industrial temperature grade DDR3 timings, 64bit bus width.
Trying to boot from MMC1
U-Boot 2020.07-5.6.0+git.266eb389dd1d (Feb 14 2022 - 17:14:43 +0000)
CPU: Freescale i.MX6DL rev1.4 at 792MHz
CPU: Industrial temperature grade (-40C to 105C) at 32C
Reset cause: POR
DRAM: 512 MiB
PMIC: wait_for_sr_state: Arbitration lost sr=93 cr=80 state=2020
i2c_init_transfer: failed for chip 0x8 retry=0
i2c_init_transfer: failed for chip 0x8 retry=1
i2c_init_transfer: failed for chip 0x8 retry=2
i2c_init_transfer: give up i2c_regs=0x21a4000
failed to get device for PMIC at address 0x8
MMC: FSL_SDHC: 1, FSL_SDHC: 0
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX6 DualLite 512MB IT V1.1A, Serial# 10784400
Net: eth0: ethernet@2188000
MMC: no card present
switch to partitions #0, OK
Scanning mmc 0:1...
Found U-Boot script /boot.scr
5752 bytes read in 14 ms (400.4 KiB/s)
## Executing script at 17000000
Loading DeviceTree: imx6dl-colibri-eval-v3.dtb
72921 bytes read in 15 ms (4.6 MiB/s)
82 bytes read in 10 ms (7.8 KiB/s)
Applying Overlay: colibri-imx6_lcd-vga_overlay.dtbo
788 bytes read in 14 ms (54.7 KiB/s)
Applying Overlay: colibri-imx6_stmpe-ts_overlay.dtbo
402 bytes read in 13 ms (29.3 KiB/s)
6792304 bytes read in 253 ms (25.6 MiB/s)
Bootargs: enable_wait_mode=off galcore.contiguousSize=50331648 root=PARTUUID=034445c6-02 ro rootwait fec_mac=00:14:2d:a4:8e:90 consoleblank=0 no_console_suspend=1 console=tty1 console=ttymxc0,115200n8 fbmem=8M
## Flattened Device Tree blob at 12100000
Booting using the fdt blob at 0x12100000
Loading Device Tree to 1ffcb000, end 1fffffff ... OK
Starting kernel ...
[ 0.000000] Linux version 5.4.161-5.6.0+git.0f0011824921 (oe-user@oe-host) (gcc version 9.3.0 (GCC)) #1 SMP Fri Mar 25 14:27:29 UTC 2022
[ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Toradex Colibri iMX6DL/S on Colibri Evaluation Board V3
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x20000000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] percpu: Embedded 15 pages/cpu s32012 r8192 d21236 u61440
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 130048
[ 0.000000] Kernel command line: enable_wait_mode=off galcore.contiguousSize=50331648 root=PARTUUID=034445c6-02 ro rootwait fec_mac=00:14:2d:a4:8e:90 consoleblank=0 no_console_suspend=1 console=tty1 console=ttymxc0,115200n8 fbmem=8M
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 241564K/524288K available (9216K kernel code, 458K rwdata, 3144K rodata, 1024K init, 416K bss, 20580K reserved, 262144K cma-reserved, 0K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] L2C-310 erratum 769419 enabled
[ 0.000000] L2C-310 enabling early BRESP for Cortex-A9
[ 0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[ 0.000000] L2C-310 ID prefetch enabled, offset 16 lines
[ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[ 0.000000] L2C-310 cache controller enabled, 16 ways, 512 kB
[ 0.000000] L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76450001
[ 0.000000] Switching to timer-based delay loop, resolution 333ns
[ 0.000008] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns
[ 0.000031] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
[ 0.001375] Console: colour dummy device 80x30
[ 0.001739] printk: console [tty1] enabled
[ 0.001770] Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
[ 0.001802] pid_max: default: 32768 minimum: 301
[ 0.001932] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.001961] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.002650] CPU: Testing write buffer coherency: ok
[ 0.002698] CPU0: Spectre v2: using BPIALL workaround
[ 0.002952] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.003492] Setting up static identity map for 0x10100000 - 0x10100060
[ 0.003649] rcu: Hierarchical SRCU implementation.
[ 0.006137] smp: Bringing up secondary CPUs ...
[ 0.006826] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.006835] CPU1: Spectre v2: using BPIALL workaround
[ 0.006973] smp: Brought up 1 node, 2 CPUs
[ 0.006996] SMP: Total of 2 processors activated (12.00 BogoMIPS).
[ 0.007012] CPU: All CPU(s) started in SVC mode.
[ 0.007378] devtmpfs: initialized
[ 0.017837] random: get_random_u32 called from bucket_table_alloc+0x58/0x14c with crng_init=0
[ 0.018294] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 0.018561] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.018599] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.031763] pinctrl core: initialized pinctrl subsystem
[ 0.032705] NET: Registered protocol family 16
[ 0.039398] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.040319] cpuidle: using governor menu
[ 0.040596] CPU identified as i.MX6DL, silicon rev 1.4
[ 0.047577] vdd1p1: supplied by regulator-dummy
[ 0.048100] vdd3p0: supplied by regulator-dummy
[ 0.048555] vdd2p5: supplied by regulator-dummy
[ 0.049030] vddarm: supplied by regulator-dummy
[ 0.049687] vddpu: supplied by regulator-dummy
[ 0.050036] vddsoc: supplied by regulator-dummy
[ 0.050601] mxs_phy 20c9000.usbphy: 20c9000.usbphy supply phy-3p0 not found, using dummy regulator
[ 0.051046] mxs_phy 20ca000.usbphy: 20ca000.usbphy supply phy-3p0 not found, using dummy regulator
[ 0.060572] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[ 0.060603] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.061559] imx6dl-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[ 0.086128] SCSI subsystem initialized
[ 0.086378] usbcore: registered new interface driver usbfs
[ 0.086440] usbcore: registered new interface driver hub
[ 0.086493] usbcore: registered new device driver usb
[ 0.086641] usb_phy_generic usbphynop1: usbphynop1 supply vcc not found, using dummy regulator
[ 0.086866] usb_phy_generic usbphynop2: usbphynop2 supply vcc not found, using dummy regulator
[ 0.089765] i2c i2c-0: SCL is stuck low, exit recovery
[ 0.109706] i2c i2c-0: SCL is stuck low, exit recovery
[ 0.129696] i2c i2c-0: SCL is stuck low, exit recovery
[ 0.149696] i2c i2c-0: SCL is stuck low, exit recovery
[ 0.159685] stmpe-i2c 0-0041: failed to read regs 0x0: -11
[ 0.159732] stmpe-i2c: probe of 0-0041 failed with error -11
[ 0.159770] i2c i2c-0: IMX I2C adapter registered
[ 0.160547] i2c i2c-1: IMX I2C adapter registered
[ 0.160766] videodev: Linux video capture interface: v2.00
[ 0.160833] pps_core: LinuxPPS API ver. 1 registered
[ 0.160851] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.160897] PTP clock support registered
[ 0.189732] imx-ipuv3 2400000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
[ 0.191025] mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
[ 0.191620] MIPI CSI2 driver module loaded
[ 0.191684] Advanced Linux Sound Architecture Driver Initialized.
[ 0.193442] clocksource: Switched to clocksource mxc_timer1
[ 0.193615] VFS: Disk quotas dquot_6.6.0
[ 0.193698] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.202024] thermal_sys: Registered thermal governor 'step_wise'
[ 0.202382] NET: Registered protocol family 2
[ 0.202550] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.203168] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.203216] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.203273] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.203350] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.203514] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.203555] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.203740] NET: Registered protocol family 1
[ 0.204237] RPC: Registered named UNIX socket transport module.
[ 0.204260] RPC: Registered udp transport module.
[ 0.204274] RPC: Registered tcp transport module.
[ 0.204287] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.204865] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 0.205038] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
[ 0.206486] Bus freq driver module loaded
[ 0.207428] Initialise system trusted keyrings
[ 0.207632] workingset: timestamp_bits=30 max_order=17 bucket_order=0
[ 0.212727] NFS: Registering the id_resolver key type
[ 0.212770] Key type id_resolver registered
[ 0.212786] Key type id_legacy registered
[ 0.212810] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.212827] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.213577] Key type cifs.idmap registered
[ 0.213609] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.214018] fuse: init (API version 7.31)
[ 0.250582] Key type asymmetric registered
[ 0.250611] Asymmetric key parser 'x509' registered
[ 0.250638] io scheduler mq-deadline registered
[ 0.250654] io scheduler kyber registered
[ 0.252777] imx-weim 21b8000.weim: Driver registered.
[ 0.254931] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 0.257820] fbcvt: 640x480@60: CVT Name - .307M3
[ 0.257856] mxc_sdc_fb fb@0: registered mxc display driver lcd
[ 0.260558] mxc_sdc_fb fb@0: 640x480 h_sync,r,l: 64,16,80 v_sync,l,u: 4,3,13 pixclock=23750000 Hz
[ 0.317733] mxc_sdc_fb fb@0: 640x480 h_sync,r,l: 64,16,80 v_sync,l,u: 4,3,13 pixclock=23750000 Hz
[ 0.347055] Console: switching to colour frame buffer device 80x30
[ 0.387814] mxc_sdc_fb fb@1: NO mxc display driver found!
[ 0.392212] i2c i2c-0: SCL is stuck low, exit recovery
[ 0.394349] i2c i2c-0: SCL is stuck low, exit recovery
[ 0.396410] i2c i2c-0: SCL is stuck low, exit recovery
[ 0.398423] i2c i2c-0: SCL is stuck low, exit recovery
[ 0.400188] pfuze100-regulator 0-0008: unrecognized pfuze chip ID!
[ 0.401852] pfuze100-regulator: probe of 0-0008 failed with error -11
[ 0.404599] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 23, base_baud = 5000000) is a IMX
[ 1.277889] printk: console [ttymxc0] enabled
[ 1.284907] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 69, base_baud = 5000000) is a IMX
[ 1.297534] 21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 70, base_baud = 5000000) is a IMX
[ 1.322218] brd: module loaded
[ 1.334841] loop: module loaded
[ 1.341643] libphy: Fixed MDIO Bus: probed
[ 1.349155] pps pps0: new PPS source ptp0
[ 1.355984] libphy: fec_enet_mii_bus: probed
[ 1.363027] fec 2188000.ethernet eth0: registered PHC device 0
[ 1.370950] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.379203] ehci-mxc: Freescale On-Chip EHCI Host driver
[ 1.386314] usbcore: registered new interface driver usb-storage
[ 1.395839] imx_usb 2184000.usb: 2184000.usb supply vbus not found, using dummy regulator
[ 1.407488] imx_usb 2184200.usb: No over current polarity defined
[ 1.419110] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 1.425782] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 1.463467] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 1.470899] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 1.482813] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.493739] usb usb1: Product: EHCI Host Controller
[ 1.500479] usb usb1: Manufacturer: Linux 5.4.161-5.6.0+git.0f0011824921 ehci_hcd
[ 1.511638] usb usb1: SerialNumber: ci_hdrc.0
[ 1.518417] hub 1-0:1.0: USB hub found
[ 1.523994] hub 1-0:1.0: 1 port detected
[ 1.532951] snvs_rtc 20cc000.snvs:snvs-rtc-lp: registered as rtc1
[ 1.541103] i2c /dev entries driver
[ 1.547047] IR NEC protocol handler initialized
[ 1.553420] IR RC5(x/sz) protocol handler initialized
[ 1.560416] IR RC6 protocol handler initialized
[ 1.566830] IR JVC protocol handler initialized
[ 1.573112] IR Sony protocol handler initialized
[ 1.579481] IR SANYO protocol handler initialized
[ 1.585908] IR Sharp protocol handler initialized
[ 1.592245] IR MCE Keyboard/mouse protocol handler initialized
[ 1.599710] IR XMP protocol handler initialized
[ 1.606238] mxc_v4l2_output v4l2_out: V4L2 device registered as video16
[ 1.614668] mxc_v4l2_output v4l2_out: V4L2 device registered as video17
[ 1.624614] imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
[ 1.632677] sdhci: Secure Digital Host Controller Interface driver
[ 1.640472] sdhci: Copyright(c) Pierre Ossman
[ 1.646350] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.655517] sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
[ 1.694528] mmc0: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
[ 1.707155] caam 2100000.caam: Entropy delay = 3200
[ 1.726073] caam 2100000.caam: Instantiated RNG4 SH0
[ 1.738551] caam 2100000.caam: Instantiated RNG4 SH1
[ 1.745087] caam 2100000.caam: device ID = 0x0a16010000000100 (Era 4)
[ 1.752991] caam 2100000.caam: job rings = 2, qi = 0
[ 1.767083] caam algorithms registered in /proc/crypto
[ 1.774797] caam 2100000.caam: registering rng-caam
[ 1.781445] Device caam-keygen registered
[ 1.787844] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.794879] usbcore: registered new interface driver usbhid
[ 1.801914] usbhid: USB HID core driver
[ 1.805899] mmc0: new DDR MMC card at address 0001
[ 1.814245] mmcblk0: mmc0:0001 Q2J54A 3.59 GiB
[ 1.814606] mxc_vpu 2040000.vpu_fsl: VPU initialized
[ 1.820565] mmcblk0boot0: mmc0:0001 Q2J54A partition 1 16.0 MiB
[ 1.828891] fsl-ssi-dai 2028000.ssi: No cache defaults, reading back from HW
[ 1.834384] usb 1-1: new full-speed USB device number 2 using ci_hdrc
[ 1.844450] imx-sgtl5000 sound: ASoC: failed to init link HiFi: -517
[ 1.851329] mmcblk0boot1: mmc0:0001 Q2J54A partition 2 16.0 MiB
[ 1.860785] NET: Registered protocol family 10
[ 1.872715] random: fast init done
[ 1.872751] mmcblk0rpmb: mmc0:0001 Q2J54A partition 3 512 KiB, chardev (246:0)
[ 1.878661] Segment Routing with IPv6
[ 1.890321] random: crng init done
[ 1.893719] NET: Registered protocol family 17
[ 1.904406] Bridge firewalling registered
[ 1.904969] mmcblk0: p1 p2
[ 1.910042] 8021q: 802.1Q VLAN Support v1.8
[ 1.920415] Key type dns_resolver registered
[ 1.928358] Registering SWP/SWPB emulation handler
[ 1.934994] registered taskstats version 1
[ 1.940636] Loading compiled-in X.509 certificates
[ 1.961292] imx_epdc_fb 20f4000.epdc: can't get/select pinctrl
[ 1.987363] imx_usb 2184000.usb: 2184000.usb supply vbus not found, using dummy regulator
[ 2.002457] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 2.009047] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[ 2.053529] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 2.062597] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 2.074143] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.084660] usb usb2: Product: EHCI Host Controller
[ 2.091209] usb usb2: Manufacturer: Linux 5.4.161-5.6.0+git.0f0011824921 ehci_hcd
[ 2.094907] usb 1-1: New USB device found, idVendor=045e, idProduct=0745, bcdDevice= 6.56
[ 2.102064] usb usb2: SerialNumber: ci_hdrc.1
[ 2.113711] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.128834] usb 1-1: Product: Microsoft® 2.4GHz Transceiver v8.0
[ 2.136815] usb 1-1: Manufacturer: Microsoft
[ 2.143348] hub 2-0:1.0: USB hub found
[ 2.149085] hub 2-0:1.0: 1 port detected
[ 2.156048] input: Microsoft Microsoft® 2.4GHz Transceiver v8.0 as /devices/soc0/soc/2100000.aips-bus/2184200.usb/ci_hdrc.0/usb1/1-1/1-1:1.0/0003:045E:0745.0001/input/input0
[ 2.156563] imx_thermal tempmon: Industrial CPU temperature grade - max:105C critical:105C passive:95C
[ 2.192849] sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
[ 2.200782] imx-sgtl5000 sound: ASoC: failed to init link HiFi: -517
[ 2.211667] sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
[ 2.219591] imx-sgtl5000 sound: ASoC: failed to init link HiFi: -517
[ 2.229689] input: gpio-keys as /devices/soc0/gpio-keys/input/input1
[ 2.244076] hid-generic 0003:045E:0745.0001: input,hidraw0: USB HID v1.11 Keyboard [Microsoft Microsoft® 2.4GHz Transceiver v8.0] on usb-ci_hdrc.0-1/input0
[ 2.262588] hctosys: unable to open rtc device (rtc0)
[ 2.270389] ALSA device list:
[ 2.277681] sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
[ 2.284914] No soundcards found.
[ 2.285679] imx-sgtl5000 sound: ASoC: failed to init link HiFi: -517
[ 2.305207] input: Microsoft Microsoft® 2.4GHz Transceiver v8.0 Mouse as /devices/soc0/soc/2100000.aips-bus/2184200.usb/ci_hdrc.0/usb1/1-1/1-1:1.1/0003:045E:0745.0002/input/input2
[ 2.327611] input: Microsoft Microsoft® 2.4GHz Transceiver v8.0 Consumer Control as /devices/soc0/soc/2100000.aips-bus/2184200.usb/ci_hdrc.0/usb1/1-1/1-1:1.1/0003:045E:0745.0002/input/input3
[ 2.414086] hid-generic 0003:045E:0745.0002: input,hidraw1: USB HID v1.11 Mouse [Microsoft Microsoft® 2.4GHz Transceiver v8.0] on usb-ci_hdrc.0-1/input1
[ 2.441029] sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
[ 2.449219] imx-sgtl5000 sound: ASoC: failed to init link HiFi: -517
[ 2.461094] input: Microsoft Microsoft® 2.4GHz Transceiver v8.0 Consumer Control as /devices/soc0/soc/2100000.aips-bus/2184200.usb/ci_hdrc.0/usb1/1-1/1-1:1.2/0003:045E:0745.0003/input/input4
[ 2.553856] input: Microsoft Microsoft® 2.4GHz Transceiver v8.0 System Control as /devices/soc0/soc/2100000.aips-bus/2184200.usb/ci_hdrc.0/usb1/1-1/1-1:1.2/0003:045E:0745.0003/input/input6
[ 2.577852] hid-generic 0003:045E:0745.0003: input,hiddev96,hidraw2: USB HID v1.11 Device [Microsoft Microsoft® 2.4GHz Transceiver v8.0] on usb-ci_hdrc.0-1/input2
[ 2.601474] sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
[ 2.609922] imx-sgtl5000 sound: ASoC: failed to init link HiFi: -517
[ 2.623265] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 2.635193] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 2.827265] EXT4-fs (mmcblk0p2): recovery complete
[ 2.835028] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.847761] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.857692] devtmpfs: mounted
[ 2.864128] Freeing unused kernel memory: 1024K
[ 2.871164] Run /sbin/init as init process
[ 3.028258] systemd[1]: System time before build time, advancing clock.
[ 3.055586] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 3.086512] systemd[1]: Detected architecture arm.
Welcome to TDX Wayland with XWayland 5.6.0+build.18 (dunfell)!
[ 3.144515] systemd[1]: Set hostname to <colibri-imx6-10784400>.
[ 3.722570] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 3.765391] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 3.805050] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 3.843986] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ 3.884360] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ 3.934298] systemd[1]: Reached target Host and Network Name Lookups.
[ OK ] Reached target Host and Network Name Lookups.
[ 3.973685] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 4.013964] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 4.053930] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 4.093964] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 4.169317] systemd[1]: Listening on RPCbind Server Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 4.214082] systemd[1]: Reached target RPC Port Mapper.
[ OK ] Reached target RPC Port Mapper.
[ 4.261495] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 4.304629] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 4.370730] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 4.382923] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 4.425160] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 4.465488] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 4.504377] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 4.544706] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 4.584886] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 4.605333] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.650348] systemd[1]: Mounting Kernel Debug File System...
[ 4.706081] systemd[1]: Mounting Temporary Directory (/tmp)...
[ 4.750660] systemd[1]: Starting Export GPIOs to user space...
[ 4.799999] systemd[1]: Starting Create list of static device nodes for the current kernel...
Starting Create list of st…odes for the current kernel...
[ 4.850669] systemd[1]: Starting RPC Bind...
[ 4.886844] systemd[1]: Starting File System Check on Root Device...
[ 4.929444] systemd[1]: Starting Journal Service...
[ 4.949891] systemd[1]: Starting Load Kernel Modules...
[ 4.979000] systemd[1]: Starting udev Coldplug all Devices...
[ 5.001554] systemd[1]: Started RPC Bind.
[ OK ] Started RPC Bind[ 5.009134] systemd[1]: Mounted POSIX Message Queue File System.
[ OK ] Mounted POSIX Messag[ 5.023807] systemd[1]: Mounted Kernel Debug File System.
[ 5.035252] systemd[1]: Mounted Temporary Directory (/tmp).
[ OK ] Mounted 5.045337] systemd[1]: Started Export GPIOs to user space.
;39mKernel Debug File System.[ 5.055349] systemd[1]: Started Create list of static device nodes for the current kernel.
[ OK ] Mounted Temporary Directory (/tmp[ 5.073147] systemd[1]: Started Load Kernel Modules.
[ OK ] Started Export GPIOs to user space.
[ OK 5.087964] systemd[1]: Mounting FUSE Control File System...
m] Started Create list of sta… nodes for the current kernel.
[ OK ] Started Load Kernel [ 5.105735] systemd[1]: Mounting Kernel Configuration File System...
Modules.
[ 5.176764] systemd[1]: Starting Apply Kernel Variables...
[ 5.228486] systemd[1]: Started File System Check on Root Device.
[ OK ] Started File System Check on Root Device.
[ 5.264421] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Mounted FUSE Control File System.
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Apply Kernel Variables.
Starting Remount Root and Kernel File Systems...
[ 5.475337] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ OK ] Started Remount Root and Kernel File Systems.
Starting Flush Journal to Persistent Storage...
[ 5.557671] systemd-journald[164]: Received client request to flush runtime journal.
Starting Create Static Device Nodes in /dev...
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Reached target Local File Systems (Pre).
Mounting /var/volatile...
Starting udev Kernel Device Manager...
[ OK ] Mounted /var/volatile.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Create Volatile Files and Directories.
Starting Network Time Synchronization...
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Created slice system-systemd\x2dbacklight.slice.
Starting Load/Save Screen …ness of backlight:backlight...
[ OK ] Started Load/Save Screen B…htness of backlight:backlight.
[ 6.417695] caam-snvs 20cc000.caam-snvs: violation handlers armed - non-secure state
[ 6.472234] sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
[ 6.504509] imx-sgtl5000 sound: ASoC: failed to init link HiFi: -517
[ OK ] Reached target Hardware activated USB gadget.
[ 6.556753] sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
[ 6.587983] imx-sgtl5000 sound: ASoC: failed to init link HiFi: -517
[ 6.633848] imx-sdma 20ec000.sdma: loaded firmware 3.5
[ 6.654278] spi_imx 2014000.spi: probed
[ 6.661769] sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Initialization.
[ 6.734590] imx-sgtl5000 sound: ASoC: failed to init link HiFi: -517
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target System Time Set.
[ OK ] Reached target System Time Synchronized.
[ OK ] Reached target Timers.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Listening on dropbear.socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started Kernel Logging Service.
[ OK ] Started System Logging Service.
[ OK ] Started D-Bus System Message Bus.
Starting IPv6 Packet Filtering Framework...
Starting IPv4 Packet Filtering Framework...
Starting Telephony service...
Starting Login Service...
[ OK ] Started Timestamping service.
[ OK ] Started IPv6 Packet Filtering Framework.
[ OK ] Started IPv4 Packet Filtering Framework.
[ 7.960035] Bluetooth: Core ver 2.22
[ 8.040278] NET: Registered protocol family 31
[ 8.046702] Bluetooth: HCI device and connection manager initialized
[ 8.059332] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 8.118793] Bluetooth: HCI socket layer initialized
[ 8.162968] Bluetooth: L2CAP socket layer initialized
[ 8.202129] Bluetooth: SCO socket layer initialized
[ OK ] Started Telephony service.
[ 8.567299] CAN device driver interface
[ OK ] Started Login Service.
[ OK ] Reached target Network (Pre).
[ OK ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
Starting Connection service...
Starting Network Service...
[ OK ] Started Connection service.
[ OK ] Started Network Service.
[ OK ] Reached target Network.
Starting Avahi mDNS/DNS-SD Stack...
Starting Permit User Sessions...
[ 9.215924] Micrel KSZ8041 2188000.ethernet-1:00: attached PHY driver [Micrel KSZ8041] (mii_bus:phy_addr=2188000.ethernet-1:00, irq=POLL)
[ OK ] Started Permit User Sessions.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttymxc0.
[ OK ] Reached target Login Prompts.
[ OK ] Reached target Multi-User System.
Starting Hostname Service...
Starting Update UTMP about System Runlevel Changes...
Starting WPA supplicant...
[ 9.603652] mcp251x spi3.0: MCP251x didn't enter in conf mode after reset
[ 9.612461] mcp251x spi3.0: Probe failed, err=16
[ 9.633568] mcp251x: probe of spi3.0 failed with error -16
[ OK ] Started Update UTMP about System Runlevel Changes.
[ OK ] Started WPA supplicant.
[ OK ] Started Hostname Service.
TDX Wayland with XWayland 5.6.0+build.18 (dunfell) colibri-imx6-10784400 ttymxc0
Colibri-iMX6_Reference-Minimal-Image
colibri-imx6-10784400 login: [ 11.273928] fec 2188000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 11.282082] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
