I have built a torizon-minimal image with a custom recipe in which a pkg_postinst_ontarget:${PN}
script is defined. But this script is not executed at the first start. Now I wonder where this script is located in the Torizon file system.
In a Toradex reference image they are located in /var/lib/opkg/
. In the Torizon file system this directory is missing.
Markus
In TorizonCore, which is based on OSTree and container technologies, the traditional package management system found in standard Linux distributions (like opkg in the Yocto Project) is not used in the same way. This means that the directory /var/lib/opkg/
, where post-installation scripts (pkg_postinst_ontarget
) would typically be located in a Yocto-based system, does not exist.
For managing containers and deploying applications on TorizonCore, the recommended approach is to encapsulate your applications and their dependencies within Docker containers. If you need to execute scripts similar to pkg_postinst_ontarget
for application setup or configuration, you should include these scripts within your container and manage their execution through your container’s entrypoint script or command.
If your custom recipe needs to perform actions on the host system outside of a container, consider alternative approaches such as creating a systemd service within your container that interacts with the host system, or using TorizonCore Builder to customize the base TorizonCore image with necessary scripts or modifications.
Remember, the architecture of TorizonCore is designed to minimize direct interactions with the host file system to maintain system integrity and reliability, favoring containerized applications for most use cases.
Best regards, Toradex AI Assistant
Basic Linux Commands | Toradex Developer Center.
Hello @Mowlwurf,
The @ToradexAI provided a decent answer. Since TorizonOS is based on OSTree its filesystem is structured differently. Most likely you will indeed need to create a systemd service to perform your script. TorizonCore Builder will be difficult, since you are using the torizon-minimal image.
To create a script I recommend looking at the following entry on our developer page:
Please let me know how you fare with this.
Best regards
Collin
I believe the following recipe gets used to handle post-install scripts: run-postinsts « recipes-devtools « meta - openembedded-core - OpenEmbedded Core layer
As you can see there is a systemd service that runs one time and executes a script that executes all the post-install scripts found. In our case since Torizon does not have a package manager by default the scripts should be located in /etc/ipk-postinsts
. Now the problem is that if you look at the script that executes the post-install scripts: run-postinsts « run-postinsts « run-postinsts « recipes-devtools « meta - openembedded-core - OpenEmbedded Core layer
It looks like it deletes the post-install scripts after executing them. Makes it a bit difficult to debug after the fact. That said, I can say for sure this mechanism does work properly as we use it ourselves: meta-toradex-torizon/recipes-core/torizon-users/torizon-users_1.0.bb at kirkstone-6.x.y · torizon/meta-toradex-torizon · GitHub
This is how we enforce changing the password on first login.
Hello @collin.tx and @jeremias.tx,
thanks a lot for your answers.
@jeremias.tx When I build torizon-minimal and log in via ssh, I don’t have to change the password for the torizon user. I also do not see the directory /etc/ipkg-postinst
neither in the image file nor on the device.
Markus
That’s odd. Are you sure you’re building the torizon-minimal.bb
recipe in Yocto? Or maybe you did some changes already to the default build?
The torizon-users
recipe I linked prior should be a part of the torizon-minimal.bb
image by default. Also when you say you log in as the torizon user, without having to change the password, what is the password? The default torizon
password?
@jeremias.tx Your’re right. I just setup a clean build environment and build torizon-minimal
without changes.
In the image I found the directory /etc/ipkg-postinst
with the file 000-torizon-users
. When I flash it to my SOM and login in as torizon
I have to change the password.
So there must be a change I did that broke something.
Markus
Thank you for double-checking. That clears up any mysteries there then.
Hello @jeremias.tx and @drew.tx,
I’ve found my error.
In my image recipe I had the following:
IMAGE_FEATURES += "\
debug-tweaks \
package-management \
eclipse-debug \
tools-debug \
The package-management
is the problem. When I remove it, I get the post-install scripts in /etc/ipkg-postinst
like in the torizon-minimal
image.
Markus
image.
Oh that makes sense. If you look at the run-postinsts
script I referenced earlier in the thread you’ll see there are multiple locations post-install scripts can be found. If there is a package manager in your image then the scripts will be located in file paths relevant to those package managers. Otherwise if no package manager is on your image it defaults to /etc/ipkg-postinst
Glad to see you figured it out though.
