Since the update (April 7, I believe…), I can sometimes use the hostname to SSH into the device, I can always use the IP address to SSH into the device, but I can never use the “scan for network devices” in the IDE extension, it always come up blank. It’s been 3 days and I’ve restarted the PC.
Can’t tell if this is a bug, or something is changed in my PC.
Hello!
It sounds like you’re able to SSH into your device, but the scanning feature isn’t working as expected. Here are some steps you can try to resolve this issue:
Manually Add the Device: You can manually add your device in Visual Studio Code by clicking the ‘+’ icon and entering the device’s IP address. This can sometimes bypass scanning issues. Learn more here.
Toggle Auto-Scan Feature: Try disabling and then re-enabling the auto-scan feature in VS Code:
Set torizon.autoScan to false in your VS Code settings.
If the issue persists, you can check the VS Code logs by opening the command palette and selecting ‘Developer: Toggle Developer Tools’. This can provide more insight into what’s happening. Here’s how to access the logs.
yep there. I cannot use the scan feature, but I can manually add using IP address. The problem will come up when the IP address of the verdin module changes, in which I’ll have to use the USB for serial communication and figure out the IP address there in order to connect to the docker via torizon ide.
