Hello.
Recently, when I try to add a device manually, it refuses to connect as if the ip address of the device wasn’t properly captured from the VSCode UI:
[05-30 17:35:31.588] Torizon IDE extension activated
[05-30 17:36:45.962] Trying to connect to 192.168.150.155
[05-30 17:36:48.987] ERROR :: Error trying to connect to : Host ip is not set or is empty
See that one log message has the proper ip but the second one has an empty string. Because of that, I can’t connect to the device.
It behaves the same with the stable 3.0.4 version and with 3.0.121
VSCode Version: 1.100.2
Thank you for providing the log details. The error message “Host ip is not set or is empty” suggests the Torizon IDE extension may not be correctly detecting your host machine’s IP address, even though the device IP appears in one log line.
To resolve this issue, here are some steps you can try:
Set overwriteHostIp Manually in VS Code
- Open the VS Code global settings.
- Search for
torizon.overwriteHostIp.
- Set it explicitly to your host (development PC) IP address.
- This setting helps when automatic detection doesn’t work correctly.
- Reference: Torizon VS Code Extension Troubleshooting
Verify Network Connectivity
Examine Extension Logs for More Details
- In VS Code, open the command palette (
Ctrl+Shift+P) and select Developer: Toggle Developer Tools.
- Switch to the
Console tab and review any detailed error logs for further clues.
- Reference: VS Code Extension Log Analysis
Verify Required Ports Accessibility
- Ensure the following ports are open and accessible between your PC and the device:
- 22 (SSH to device)
- 2375 (Docker API)
- 5002 (Local Docker Registry)
- 2222 (Container SSH)
- Reference: Port Requirements
Applying the above steps should resolve the connection and IP detection problem. If the issue persists, gathering and sharing the full console logs from the Developer Tools may help with further diagnosis.
None of this helps unfortunately. The connectivity is there though. When I set up proper data in settings.json manually:
"torizon_psswd": "**redacted**",
"torizon_login": "torizon",
"torizon_ip": "192.168.150.155",
"torizon_ssh_port": "22",
"host_ip": "10.0.20.2",
I can debug successfully. So it’s something with the extension
Greetings @mkosobucki_kdab,
Interesting, it seems like the extension wasn’t able to automatically this data.
Did you notice any error/warning messages when the extension was starting up after opening VSCode?
Is this reproducible for you?
Finally, did this work in the past and just recently started behaving like this?
Hi @mkosobucki_kdab did you have a chance to look at the questions from Jeremias above?
Hey.
Unfortunately we’re moving offices and I lost access to the device for some time. I’ll re-test once it’s available to me again.
